Исходящие работают, входящий "занято"
pogreb
Re: Исходящие работают, входящий "занято"
Сообщение pogreb »
2109 позвонил 2406 (это тестовый звонок, с номером 2406 все норм)
Сделал команду:
localhost*CLI> core show channel SIP/2109-00018dbb
 -- General --
           Type: SIP
       UniqueID: 1444654209.101902
       LinkedID: 1444654209.101902
      Caller ID: 2109
 Caller ID Name: ГНВ
Connected Line ID: 2406
Connected Line ID Name: ЧАИ
    DNID Digits: 2406
       Language: ru
          State: Ring (4)
          Rings: 0
  NativeFormats: 0x8 (alaw)
    WriteFormat: 0x8 (alaw)
     ReadFormat: 0x8 (alaw)
 WriteTranscode: No
  ReadTranscode: No
1st File Descriptor: 54
      Frames in: 0
     Frames out: 0
 Time to Hangup: 0
   Elapsed Time: 0h0m2s
  Direct Bridge: <none>
Indirect Bridge: <none>
 --   PBX   --
        Context: dial
      Extension: 2406
       Priority: 52
     Call Group: 2
   Pickup Group: 2
    Application: Dial
           Data: SIP/2406,100,Ttg
    Blocking in: ast_waitfor_nandfds
      Variables:
MACRO_DEPTH=0
callingnum=2406
DIALEDTIME=
ANSWEREDTIME=
DIALEDPEERNAME=
DIALEDPEERNUMBER=
DIALSTATUS=
SIPADDHEADER01=
CALLED_PARTY_ANNOUNCE=
DB_RESULT=moh-1
CFDirectId=1444654209.101902
ThisCallOptions=Tt
TRANSFER_CONTEXT=transfered-context
THISTIMEOUT=100
GOSUB_RETVAL=
MIXMONITOR_FILENAME=/var/calls/20151012-155009-2109-2406-1444654209-101902.wav
CallMonitorFilename=20151012-155009-2109-2406-1444654209-101902
CallerAgentExt=""
CalledMonitor=yes
CallForwardType=absolute
CalledNumCos=1
CalledPort=2406
Called=Port
CallType=INTERNAL
ARG2=
ARG3=
DialTimeout=
ARG1=
CalledNum=2406
ARGC=2
CallerMonitor=yes
NumCos=6
OurName=ГНВ
OurNum=2109
PortName=ГНВ
PortNum=2109
CallerType=Port
CONNECTED_LINE_CALLEE_SEND_MACRO=find-agent-connectedline
CONNECTED_LINE_CALLER_SEND_MACRO=find-agent-connectedline
CallUniqueId=1444654209.101902
PhoneForward=0
FilteredExten=2406
SIPCALLID=424138593-7172-195@BA.ED.HJ.F
SIPDOMAIN=10.3.0.246
SIPURI=sip:2109@10.xx.xx.5:7172
  CDR Variables:
level 1: dnid=2406
level 1: clid="ГНВ" <2109>
level 1: src=2109
level 1: dst=2406
level 1: dcontext=internal
level 1: channel=SIP/2109-00018dbb
level 1: dstchannel=SIP/2406-00018dbc
level 1: lastapp=MacroExit
level 1: start=2015-10-12 15:50:09
level 1: duration=1
level 1: billsec=0
level 1: disposition=NO ANSWER
level 1: amaflags=DOCUMENTATION
level 1: uniqueid=1444654209.101902
level 1: linkedid=1444654209.101902
level 1: userfield=Internal
level 1: sequence=134041
На что здесь смотреть, если вызываемый абонент проблемный?
Спасибо!
nickel82
Сообщение nickel82 »
смотреть нет ли зависшего звонка! если по телефону не говорят, а канал занят делать hangup ...!
core show channels verbose
и сбоку общее время
pogreb
Сообщение pogreb »
Как понять, что канал занят?
yur4ik
Сообщение yur4ik »
awsswa писал(а):core show channels verbose
и сбоку общее время
nickel82 писал(а):смотреть нет ли зависшего звонка! если по телефону не говорят, а канал занят делать hangup ...!
pogreb
Сообщение pogreb »
делать hangup
Подскажите как?
nickel82
делай на ощупь, по тойже схеме hangup(TAB)
или кардинальный метод, reboot
nickel82
да и темку думаю надо было как минимум не в этой витки писать, как и все вами открытые предыдущие, и кстати google тоже бы во многом помог!
короче честно одни эмоции лезут вместо букв!
простой тест:
cd /var/calls
ls
Вангую, что минут на 20 "зависон" обеспечен!
pogreb
Сообщение pogreb »
Почему?
