Блокировка входящих вызовов Freepbx
jakarta
Re: Блокировка входящих вызовов Freepbx
Сообщение jakarta »
Создал маршрут с номером вида 7911XXXXXXX , для того что затестить с мобилы. Увы, ничего не изменилось, отправляет на IVR.
 Using SIP RTP TOS bits 184
    -- Executing [7812номерокАТС@from-trunk-sip-Beeline:1] Set("SIP/Beeline-000003c6", "GROUP()=OUT_2") in new stack
    -- Executing [7812номерокАТС@from-trunk-sip-Beeline:2] Goto("SIP/Beeline-000003c6", "from-trunk,7812номерокАТС,1") in new stack
    -- Goto (from-trunk,78124497869,1)
    -- Executing [7812номерокАТС@from-trunk:1] Set("SIP/Beeline-000003c6", "__FROM_DID=7812номерокАТС") in new stack
    -- Executing [7812номерокАТС@from-trunk:2] Gosub("SIP/Beeline-000003c6", "sub-record-check,s,1(in,7812номерокАТС,dontcare)") in new stack
    -- Executing [s@sub-record-check:1] GotoIf("SIP/Beeline-000003c6", "0?initialized") in new stack
    -- Executing [s@sub-record-check:2] Set("SIP/Beeline-000003c6", "__REC_STATUS=INITIALIZED") in new stack
    -- Executing [s@sub-record-check:3] Set("SIP/Beeline-000003c6", "NOW=1426760052") in new stack
    -- Executing [s@sub-record-check:4] Set("SIP/Beeline-000003c6", "__DAY=19") in new stack
    -- Executing [s@sub-record-check:5] Set("SIP/Beeline-000003c6", "__MONTH=03") in new stack
    -- Executing [s@sub-record-check:6] Set("SIP/Beeline-000003c6", "__YEAR=2015") in new stack
    -- Executing [s@sub-record-check:7] Set("SIP/Beeline-000003c6", "__TIMESTR=20150319-101412") in new stack
    -- Executing [s@sub-record-check:8] Set("SIP/Beeline-000003c6", "__FROMEXTEN=unknown") in new stack
    -- Executing [s@sub-record-check:9] Set("SIP/Beeline-000003c6", "__MON_FMT=wav") in new stack
    -- Executing [s@sub-record-check:10] NoOp("SIP/Beeline-000003c6", "Recordings initialized") in new stack
    -- Executing [s@sub-record-check:11] ExecIf("SIP/Beeline-000003c6", "0?Set(ARG3=dontcare)") in new stack
    -- Executing [s@sub-record-check:12] Set("SIP/Beeline-000003c6", "REC_POLICY_MODE_SAVE=") in new stack
    -- Executing [s@sub-record-check:13] ExecIf("SIP/Beeline-000003c6", "0?Set(REC_STATUS=NO)") in new stack
    -- Executing [s@sub-record-check:14] GotoIf("SIP/Beeline-000003c6", "2?checkaction") in new stack
    -- Executing [s@sub-record-check:17] GotoIf("SIP/Beeline-000003c6", "1?sub-record-check,in,1") in new stack
    -- Goto (sub-record-check,in,1)
    -- Executing [in@sub-record-check:1] NoOp("SIP/Beeline-000003c6", "Inbound Recording Check to 7812номерокАТС") in new stack
    -- Executing [in@sub-record-check:2] Set("SIP/Beeline-000003c6", "FROMEXTEN=unknown") in new stack
    -- Executing [in@sub-record-check:3] ExecIf("SIP/Beeline-000003c6", "11?Set(FROMEXTEN=7911мой-номерок)") in new stack
    -- Executing [in@sub-record-check:4] Gosub("SIP/Beeline-000003c6", "recordcheck,1(dontcare,in,7812номерокАТС)") in new stack
    -- Executing [recordcheck@sub-record-check:1] NoOp("SIP/Beeline-000003c6", "Starting recording check against dontcare") in new stack
    -- Executing [recordcheck@sub-record-check:2] Goto("SIP/Beeline-000003c6", "dontcare") in new stack
    -- Goto (sub-record-check,recordcheck,3)
    -- Executing [recordcheck@sub-record-check:3] Return("SIP/Beeline-000003c6", "") in new stack
    -- Executing [in@sub-record-check:5] Return("SIP/Beeline-000003c6", "") in new stack
    -- Executing [7812номерокАТС@from-trunk:3] Gosub("SIP/Beeline-000003c6", "app-blacklist-check,s,1()") in new stack
    -- Executing [s@app-blacklist-check:1] GotoIf("SIP/Beeline-000003c6", "0?blacklisted") in new stack
    -- Executing [s@app-blacklist-check:2] Set("SIP/Beeline-000003c6", "CALLED_BLACKLIST=1") in new stack
    -- Executing [s@app-blacklist-check:3] Return("SIP/Beeline-000003c6", "") in new stack
    -- Executing [7812номерокАТС@from-trunk:4] Set("SIP/Beeline-000003c6", "CDR(did)=7812номерокАТС") in new stack
    -- Executing [7812номерокАТС@from-trunk:5] ExecIf("SIP/Beeline-000003c6", "1 ?Set(CALLERID(name)=79118755036)") in new stack
    -- Executing [7812номерокАТС@from-trunk:6] Set("SIP/Beeline-000003c6", "CHANNEL(musicclass)=default") in new stack
    -- Executing [7812номерокАТС@from-trunk:7] Set("SIP/Beeline-000003c6", "__MOHCLASS=default") in new stack
[2015-03-19 10:14:12] WARNING[28849][C-00008934]: func_channel.c:538 func_channel_read: Unknown or unavailable item requested: 'reversecharge'
    -- Executing [7812номерокАТС@from-trunk:8] GotoIf("SIP/Beeline-000003c6", "0?macro-hangupcall") in new stack
    -- Executing [7812номерокАТС@from-trunk:9] Set("SIP/Beeline-000003c6", "__CALLINGPRES_SV=allowed_not_screened") in new stack
    -- Executing [7812номерокАТС@from-trunk:10] Set("SIP/Beeline-000003c6", "CALLERPRES()=allowed_not_screened") in new stack
    -- Executing [7812номерокАТС@from-trunk:11] Goto("SIP/Beeline-000003c6", "ivr-1,s,1") in new stack
    -- Goto (ivr-1,s,1)
    -- Executing [s@ivr-1:1] Set("SIP/Beeline-000003c6", "TIMEOUT_LOOPCOUNT=0") in new stack
    -- Executing [s@ivr-1:2] Set("SIP/Beeline-000003c6", "INVALID_LOOPCOUNT=0") in new stack
    -- Executing [s@ivr-1:3] Set("SIP/Beeline-000003c6", "_IVR_CONTEXT_ivr-1=") in new stack
    -- Executing [s@ivr-1:4] Set("SIP/Beeline-000003c6", "_IVR_CONTEXT=ivr-1") in new stack
    -- Executing [s@ivr-1:5] Set("SIP/Beeline-000003c6", "__IVR_RETVM=") in new stack
    -- Executing [s@ivr-1:6] GotoIf("SIP/Beeline-000003c6", "0?skip") in new stack
    -- Executing [s@ivr-1:7] Answer("SIP/Beeline-000003c6", "") in new stack
    -- Executing [s@ivr-1:8] Wait("SIP/Beeline-000003c6", "1") in new stack
    -- Executing [s@ivr-1:9] Set("SIP/Beeline-000003c6", "IVR_MSG=custom/Privetstvie") in new stack
    -- Executing [s@ivr-1:10] Set("SIP/Beeline-000003c6", "TIMEOUT(digit)=3") in new stack
    -- Digit timeout set to 3.000
    -- Executing [s@ivr-1:11] ExecIf("SIP/Beeline-000003c6", "1?Background(custom/Privetstvie)") in new stack
    -- <SIP/Beeline-000003c6> Playing 'custom/Privetstvie.slin' (language 'en')
  == Spawn extension (ivr-1, s, 11) exited non-zero on 'SIP/Beeline-000003c6'
    -- Executing [h@ivr-1:1] Hangup("SIP/Beeline-000003c6", "") in new stack
  == Spawn extension (ivr-1, h, 1) exited non-zero on 'SIP/Beeline-000003c6'
Надо с номером вида _7911XXXXXXX (подчеркивающая впереди, признак шаблона)
То есть DID = 7812номерокАТС / CID = _7911XXXXXXX
jakarta
Сообщение jakarta »
Огромное спасибо! Заработало!
