Вылетает Asterisk при использвании перенаправления звонков.
Re: Вылетает Asterisk при использвании перенаправления звонк
пробуйте сконвертить
asterisk -r
file convert /opt/var/lib/asterisk/moh/macroform-cold_day.ulaw /opt/var/lib/asterisk/moh/macroform-cold_day.alaw
file convert /opt/var/lib/asterisk/moh/macroform-cold_day.ulaw /opt/var/lib/asterisk/moh/macroform-cold_day.raw
file convert /opt/var/lib/asterisk/moh/macroform-cold_day.ulaw /opt/var/lib/asterisk/moh/macroform-cold_day.sln
file convert /opt/var/lib/asterisk/moh/macroform-robot_dity.ulaw /opt/var/lib/asterisk/moh/macroform-robot_dity.alaw
file convert /opt/var/lib/asterisk/moh/macroform-robot_dity.ulaw /opt/var/lib/asterisk/moh/macroform-robot_dity.raw
file convert /opt/var/lib/asterisk/moh/macroform-robot_dity.ulaw /opt/var/lib/asterisk/moh/macroform-robot_dity.sln
file convert /opt/var/lib/asterisk/moh/macroform-the_simplicity.ulaw /opt/var/lib/asterisk/moh/macroform-the_simplicity.alaw
file convert /opt/var/lib/asterisk/moh/macroform-the_simplicity.ulaw /opt/var/lib/asterisk/moh/macroform-the_simplicity.raw
file convert /opt/var/lib/asterisk/moh/macroform-the_simplicity.ulaw /opt/var/lib/asterisk/moh/macroform-the_simplicity.sln
file convert /opt/var/lib/asterisk/moh/manolo_camp-morning_coffee.ulaw /opt/var/lib/asterisk/moh/manolo_camp-morning_coffee.alaw
file convert /opt/var/lib/asterisk/moh/manolo_camp-morning_coffee.ulaw /opt/var/lib/asterisk/moh/manolo_camp-morning_coffee.raw
file convert /opt/var/lib/asterisk/moh/manolo_camp-morning_coffee.ulaw /opt/var/lib/asterisk/moh/manolo_camp-morning_coffee.sln
file convert /opt/var/lib/asterisk/moh/reno_project-system.ulaw /opt/var/lib/asterisk/moh/reno_project-system.alaw
file convert /opt/var/lib/asterisk/moh/reno_project-system.ulaw /opt/var/lib/asterisk/moh/reno_project-system.raw
file convert /opt/var/lib/asterisk/moh/reno_project-system.ulaw /opt/var/lib/asterisk/moh/reno_project-system.sln
ccoll
Сообщение ccoll »
Сконвертировал файлы:
Converted /opt/var/lib/asterisk/moh/reno_project-system.ulaw to /opt/var/lib/asterisk/moh/reno_project-system.sln in 2859ms
CLI>
Class: default
        Mode: files
        Directory: /opt/var/lib/asterisk/moh
Class: default
        File: /opt/var/lib/asterisk/moh/macroform-cold_day
        File: /opt/var/lib/asterisk/moh/macroform-robot_dity
        File: /opt/var/lib/asterisk/moh/macroform-the_simplicity
        File: /opt/var/lib/asterisk/moh/manolo_camp-morning_coffee
        File: /opt/var/lib/asterisk/moh/reno_project-system
musiconhold.conf:
[default]
mode=files
directory=/opt/var/lib/asterisk/moh
Не помогло, вылетает Asterisk.
попробуйте FreeSWITCH накатить
телепаты в отпуске:
1. Опишите конкретно на какой номер трансферите этот SIP/users. если в город - там НЕТ tT в Dial. От этого и ануслинг.
2. canreinvite УСТАРЕЛ. используем directmedia=no
3. Наконец покажите SIP debug. Также включите set core verbose и debug побольше.
4. не вижу секцию general у sip.conf
5. callerid=users-hello у пира = записки школьника. УЧИМ матчасть.
P.S> Самое то главное пропустил:
"Asterisk 1.8.25.0" установлен на "ASUS WL-500G Premium V2"
отключаем все кодеки кроме alaw, ищем вообще Астеру памяти то хватает на зверьке, молимся тайпейскому гиганту чтоп хватило)
Vlad1983 писал(а):попробуйте FreeSWITCH накатить
фокус не прокатит в последнем релизе выпилен
честно я вообще не понимаю зачем вы скрутили дефолтный каталог /var/lib/asterisk/moh
все что надо было сделать это создать его - по умолчанию он отсуствует
ccoll
Сообщение ccoll »
Zavr2008 писал(а):телепаты в отпуске:
1. Звоню пользователем andy - users. Подымаю трубку пользователем users и нажимаю клавишу # после чего asterisk вылетает. Хотел перевести звонок на пользователя 55555.
2. Заменил на directmedia=no.
3. Дебаг включил:
/opt/sbin/asterisk -rx "sip set debug on"
CLI> core set verbose 5
Set remote console verbosity to 5
CLI> core set debug 5
Core debug was 0 and is now 5
sip.conf:
[andy]
secret=andy
nat=yes
videosupport=yes
directmedia=no
defaultuser=andy
dtmfmode=rfc2833
allow=all
context=sip-dialout
callgroup=1
pickupgroup=1
[users]
secret=users
nat=yes
videosupport=yes
directmedia=no
defaultuser=users
dtmfmode=rfc2833
allow=all
context=sip-dialout
callgroup=1
pickupgroup=1
[55555]
secret=1
dtmfmode=rfc2833
directmedia=no
context=sip-dialout
nat=no
defaultuser=55555
transport=udp
allow=all
callgroup=1
pickupgroup=1
[SPA31]
secret=SPA
dtmfmode=rfc2833
directmedia=no
context=sip-dialout
nat=no
defaultuser=SPA31
transport=udp
allow=all
t38pt_udptl=yes,maxdatagram=400
callgroup=1
pickupgroup=1
extensions.conf:
[sip-dialout]
exten => andy,1,Dial(SIP/andy,,tT)
exten => 3,1,Dial(SIP/andy,,tT) ; короткий номер
exten => users,1,Dial(SIP/users,,tT)
exten => 1,1,Dial(SIP/users,,tT) ; короткий номер
exten => 55555,1,Dial(SIP/55555,,tT)
exten => 888,1,Dial(SIP/andy,,t&SIP/users,,t) ; входящий звонок c Linksys spa3102.
exten => _7777777!,1,Dial(SIP/SPA31,,D(${EXTEN})) ; звонок в город на определенный номер
нет секции general.
ccoll
Сообщение ccoll »
Лог1:
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 46]: OPTIONS sip:users@192.168.100.232:5060 SIP/2.0
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 65]: Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK749f355a;rport
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 16]: Max-Forwards: 70
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 61]: From: "asterisk" <sip:asterisk@192.168.100.19>;tag=as63c1596e
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 36]: To: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 43]: Contact: <sip:asterisk@192.168.100.19:5060>
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 61]: Call-ID: 66b1a96203d7ac6f69ce58d94faa8128@192.168.100.19:5060
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 31]: User-Agent: Asterisk PBX 11.7.0
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 35]: Date: Wed, 25 Feb 2015 00:24:03 GMT
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 10 [ 81]: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, P   UBLISH
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 11 [ 26]: Supported: replaces, timer
Reliably Transmitting (NAT) to 192.168.100.232:5060:
CSeq: 102 OPTIONS
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #56
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'OPTIONS sip' onto UDP socket destined for 192.168.100.232:5060
<--- SIP read from UDP:192.168.100.232:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK749f355a;rport=5060
To: <sip:users@192.168.100.232:5060>;tag=007af7fabfbae41198937571a1da2b4c
CSeq: 102 OPTIONS
Contact: <sip:users@192.168.100.232:5060>
Allow: INVITE, OPTIONS, ACK, BYE, CANCEL, INFO, NOTIFY, MESSAGE, UPDATE
Server: SIPPER for PhonerLite
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 14]: SIP/2.0 200 OK
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 70]: Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK749f355a;rport=5060
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 61]: From: "asterisk" <sip:asterisk@192.168.100.19>;tag=as63c1596e
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 73]: To: <sip:users@192.168.100.232:5060>;tag=007af7fabfbae41198937571a1da2b4c
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 61]: Call-ID: 66b1a96203d7ac6f69ce58d94faa8128@192.168.100.19:5060
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 41]: Contact: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 71]: Allow: INVITE, OPTIONS, ACK, BYE, CANCEL, INFO, NOTIFY, MESSAGE, UPDATE
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 29]: Server: SIPPER for PhonerLite
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 17]: Content-Length: 0
--- (10 headers 0 lines) ---
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 66b1a96203d7ac6f69ce58d94faa8128@192.168.100.19:5060 (Checking To) --From    tag as63c1596e --To-tag 007af7fabfbae41198937571a1da2b4c
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:4534 __sip_ack: ** SIP TIMER: Cancelling retransmit of packet (reply received) Retransid #56
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:4567 __sip_ack: Stopping retransmission on '66b1a96203d7ac6f69ce58d94faa8128@192.168.100.19:5060' of Request 102:    Match Found
[Feb 25 00:24:03] DEBUG[2154]: chan_sip.c:6828 sip_destroy: Destroying SIP dialog 66b1a96203d7ac6f69ce58d94faa8128@192.168.100.19:5060
Really destroying SIP dialog '66b1a96203d7ac6f69ce58d94faa8128@192.168.100.19:5060' Method: OPTIONS
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:8770 sip_alloc: Allocating new SIP dialog for 19948d3468775d5d5b35b3b112587eb8@[c0a8:6413:a04a:ff7f::]:5060 - OPT   IONS (No RTP)
[Feb 25 00:24:15] DEBUG[2154]: acl.c:979 ast_ouraddrfor: For destination '192.168.10.101', our source address is '192.168.10.180'.
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:4032 ast_sip_ouraddrfor: Setting SIP_TRANSPORT_UDP with address 192.168.10.180:5060
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:8565 change_callid_pvt: SIP call-id changed from '19948d3468775d5d5b35b3b112587eb8@[c0a8:6413:a04a:ff7f::]:5060'    to '6d5ee43e21534d5e08f8e3a64e9fe2f6@192.168.10.180:5060'
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:3518 initialize_initreq: Initializing initreq for method OPTIONS - callid 6d5ee43e21534d5e08f8e3a64e9fe2f6@192.16   8.10.180:5060
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 45]: OPTIONS sip:55555@192.168.10.101:5060 SIP/2.0
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 59]: Via: SIP/2.0/UDP 192.168.10.180:5060;branch=z9hG4bK3849d0e4
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 16]: Max-Forwards: 70
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 61]: From: "asterisk" <sip:asterisk@192.168.10.180>;tag=as1578bbab
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 35]: To: <sip:55555@192.168.10.101:5060>
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 43]: Contact: <sip:asterisk@192.168.10.180:5060>
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 61]: Call-ID: 6d5ee43e21534d5e08f8e3a64e9fe2f6@192.168.10.180:5060
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 31]: User-Agent: Asterisk PBX 11.7.0
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 35]: Date: Wed, 25 Feb 2015 00:24:15 GMT
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 10 [ 81]: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, P   UBLISH
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 11 [ 26]: Supported: replaces, timer
Reliably Transmitting (no NAT) to 192.168.10.101:5060:
CSeq: 102 OPTIONS
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #59
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'OPTIONS sip' onto UDP socket destined for 192.168.10.101:5060
<--- SIP read from UDP:192.168.10.101:5060 --->
SIP/2.0 200 OK
To: <sip:55555@192.168.10.101:5060>;tag=61d3b64dfc71aaa3i0
CSeq: 102 OPTIONS
Server: Linksys/SPA3102-5.2.13(GW002)
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 14]: SIP/2.0 200 OK
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 58]: To: <sip:55555@192.168.10.101:5060>;tag=61d3b64dfc71aaa3i0
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 61]: From: "asterisk" <sip:asterisk@192.168.10.180>;tag=as1578bbab
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 61]: Call-ID: 6d5ee43e21534d5e08f8e3a64e9fe2f6@192.168.10.180:5060
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 59]: Via: SIP/2.0/UDP 192.168.10.180:5060;branch=z9hG4bK3849d0e4
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 37]: Server: Linksys/SPA3102-5.2.13(GW002)
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 17]: Content-Length: 0
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 61]: Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 29]: Supported: x-sipura, replaces
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 6d5ee43e21534d5e08f8e3a64e9fe2f6@192.168.10.180:5060 (Checking To) --From    tag as1578bbab --To-tag 61d3b64dfc71aaa3i0
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:4534 __sip_ack: ** SIP TIMER: Cancelling retransmit of packet (reply received) Retransid #59
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:4567 __sip_ack: Stopping retransmission on '6d5ee43e21534d5e08f8e3a64e9fe2f6@192.168.10.180:5060' of Request 102:    Match Found
[Feb 25 00:24:15] DEBUG[2154]: chan_sip.c:6828 sip_destroy: Destroying SIP dialog 6d5ee43e21534d5e08f8e3a64e9fe2f6@192.168.10.180:5060
Really destroying SIP dialog '6d5ee43e21534d5e08f8e3a64e9fe2f6@192.168.10.180:5060' Method: OPTIONS
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:8770 sip_alloc: Allocating new SIP dialog for 1b9e5085018417457b4da6326520c87b@[c0a8:6413:a04a:ff7f::]:5060 - OPT   IONS (No RTP)
[Feb 25 00:24:23] DEBUG[2154]: acl.c:979 ast_ouraddrfor: For destination '192.168.10.43', our source address is '192.168.10.180'.
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:4032 ast_sip_ouraddrfor: Setting SIP_TRANSPORT_UDP with address 192.168.10.180:5060
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:8565 change_callid_pvt: SIP call-id changed from '1b9e5085018417457b4da6326520c87b@[c0a8:6413:a04a:ff7f::]:5060'    to '2e07f2f2060fcc045d15848746730671@192.168.10.180:5060'
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:3518 initialize_initreq: Initializing initreq for method OPTIONS - callid 2e07f2f2060fcc045d15848746730671@192.16   8.10.180:5060
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 38]: OPTIONS sip:andy@192.168.10.43 SIP/2.0
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 65]: Via: SIP/2.0/UDP 192.168.10.180:5060;branch=z9hG4bK38983840;rport
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 16]: Max-Forwards: 70
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 61]: From: "asterisk" <sip:asterisk@192.168.10.180>;tag=as6603b223
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 28]: To: <sip:andy@192.168.10.43>
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 43]: Contact: <sip:asterisk@192.168.10.180:5060>
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 61]: Call-ID: 2e07f2f2060fcc045d15848746730671@192.168.10.180:5060
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 31]: User-Agent: Asterisk PBX 11.7.0
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 35]: Date: Wed, 25 Feb 2015 00:24:23 GMT
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 10 [ 81]: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, P   UBLISH
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 11 [ 26]: Supported: replaces, timer
Reliably Transmitting (NAT) to 192.168.10.43:5060:
CSeq: 102 OPTIONS
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #62
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'OPTIONS sip' onto UDP socket destined for 192.168.10.43:5060
<--- SIP read from UDP:192.168.10.43:5060 --->
SIP/2.0 200 Ok
To: <sip:andy@192.168.10.43>;tag=M5Q-C
CSeq: 102 OPTIONS
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 14]: SIP/2.0 200 Ok
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 61]: From: "asterisk" <sip:asterisk@192.168.10.180>;tag=as6603b223
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 38]: To: <sip:andy@192.168.10.43>;tag=M5Q-C
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 61]: Call-ID: 2e07f2f2060fcc045d15848746730671@192.168.10.180:5060
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 17]: CSeq: 102 OPTIONS
--- (6 headers 0 lines) ---
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 2e07f2f2060fcc045d15848746730671@192.168.10.180:5060 (Checking To) --From    tag as6603b223 --To-tag M5Q-C
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:4534 __sip_ack: ** SIP TIMER: Cancelling retransmit of packet (reply received) Retransid #62
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:4567 __sip_ack: Stopping retransmission on '2e07f2f2060fcc045d15848746730671@192.168.10.180:5060' of Request 102:    Match Found
[Feb 25 00:24:23] DEBUG[2154]: chan_sip.c:6828 sip_destroy: Destroying SIP dialog 2e07f2f2060fcc045d15848746730671@192.168.10.180:5060
Really destroying SIP dialog '2e07f2f2060fcc045d15848746730671@192.168.10.180:5060' Method: OPTIONS
[Feb 25 00:24:26] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [  0]:
INVITE sip:users@192.168.10.180 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.BnrBdc6Jp;rport
To: sip:users@192.168.10.180
CSeq: 20 INVITE
Call-ID: QnoZcB0b4t
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Content-Length: 175
User-Agent: LinphoneAndroid/2.2.1.1 (belle-sip/1.2.4)
Contact: <sip:andy@192.168.10.43>;+sip.instance="<urn:uuid:af2e5b37-4eae-47ba-b166-af1e3b364580>"
v=0
o=andy 2300 2717 IN IP4 192.168.10.43
s=Talk
c=IN IP4 192.168.10.43
b=AS:380
t=0 0
m=audio 7076 RTP/AVP 9 3 101
a=fmtp:101 0-11
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 39]: INVITE sip:users@192.168.10.180 SIP/2.0
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 66]: Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.BnrBdc6Jp;rport
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 45]: From: <sip:andy@192.168.10.180>;tag=1LEjyHs5q
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 28]: To: sip:users@192.168.10.180
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 15]: CSeq: 20 INVITE
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 19]: Call-ID: QnoZcB0b4t
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 16]: Max-Forwards: 70
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 81]: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE   , INFO
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 29]: Content-Type: application/sdp
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 19]: Content-Length: 175
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 10 [ 53]: User-Agent: LinphoneAndroid/2.2.1.1 (belle-sip/1.2.4)
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 11 [ 97]: Contact: <sip:andy@192.168.10.43>;+sip.instance="<urn:uuid:af2e5b37-4eae-47   ba-b166-af1e3b364580>"
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 12 [  0]:
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  0 [  3]: v=0
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  1 [ 37]: o=andy 2300 2717 IN IP4 192.168.10.43
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  2 [  6]: s=Talk
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  3 [ 22]: c=IN IP4 192.168.10.43
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  4 [  8]: b=AS:380
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  5 [  5]: t=0 0
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  6 [ 28]: m=audio 7076 RTP/AVP 9 3 101
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  7 [ 33]: a=rtpmap:101 telephone-event/8000
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9654 parse_request:    Body  8 [ 15]: a=fmtp:101 0-11
--- (12 headers 9 lines) ---
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: QnoZcB0b4t (Checking From) --From tag 1LEjyHs5q --To-tag
[Feb 25 00:24:38] DEBUG[2154]: acl.c:979 ast_ouraddrfor: For destination '192.168.10.43', our source address is '192.168.10.180'.
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:4032 ast_sip_ouraddrfor: Setting SIP_TRANSPORT_UDP with address 192.168.10.180:5060
[Feb 25 00:24:38] DEBUG[2154]: netsock2.c:138 ast_sockaddr_split_hostport: Splitting '192.168.10.43:5060' into...
[Feb 25 00:24:38] DEBUG[2154]: netsock2.c:192 ast_sockaddr_split_hostport: ...host '192.168.10.43' and port '5060'.
Sending to 192.168.10.43:5060 (no NAT)
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:8770 sip_alloc: Allocating new SIP dialog for QnoZcB0b4t - INVITE (No RTP)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:28146 handle_incoming: **** Received INVITE (5) - Command in SIP INVITE
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: netsock2.c:138 ast_sockaddr_split_hostport: Splitting '192.168.10.43:5060' into...
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: netsock2.c:192 ast_sockaddr_split_hostport: ...host '192.168.10.43' and port '5060'.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:25270 handle_request_invite: Initializing initreq for method INVITE - callid QnoZcB0b4t
Using INVITE request as basis request - QnoZcB0b4t
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: netsock2.c:138 ast_sockaddr_split_hostport: Splitting '192.168.10.180' into...
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: netsock2.c:192 ast_sockaddr_split_hostport: ...host '192.168.10.180' and port ''.
Found peer 'andy' for 'andy' from 192.168.10.43:5060
<--- Reliably Transmitting (NAT) to 192.168.10.43:5060 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.BnrBdc6Jp;received=192.168.10.43;rport=5060
To: sip:users@192.168.10.180;tag=as23e352d2
Call-ID: QnoZcB0b4t
CSeq: 20 INVITE
Server: Asterisk PBX 11.7.0
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="07eb8ddc"
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #65
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:3875 __sip_xmit: Trying to put 'SIP/2.0 401' onto UDP socket destined for 192.168.10.43:5060
Scheduling destruction of SIP dialog 'QnoZcB0b4t' in 6400 ms (Method: INVITE)
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:4119 retrans_pkt: SIP TIMER: Rescheduling retransmission #65 (1) SIP/2.0 - 1
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:4139 retrans_pkt: ** SIP timers: Rescheduling retransmission 2 to 200 ms (t1 100 ms (Retrans id #65))
Retransmitting #1 (NAT) to 192.168.10.43:5060:
Call-ID: QnoZcB0b4t
CSeq: 20 INVITE
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'SIP/2.0 401' onto UDP socket destined for 192.168.10.43:5060
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:4119 retrans_pkt: SIP TIMER: Rescheduling retransmission #65 (2) SIP/2.0 - 1
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:4139 retrans_pkt: ** SIP timers: Rescheduling retransmission 3 to 400 ms (t1 100 ms (Retrans id #65))
Retransmitting #2 (NAT) to 192.168.10.43:5060:
Call-ID: QnoZcB0b4t
CSeq: 20 INVITE
ACK sip:users@192.168.10.180 SIP/2.0
Call-ID: QnoZcB0b4t
To: <sip:users@192.168.10.180>;tag=as23e352d2
CSeq: 20 ACK
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 36]: ACK sip:users@192.168.10.180 SIP/2.0
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 19]: Call-ID: QnoZcB0b4t
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 45]: From: <sip:andy@192.168.10.180>;tag=1LEjyHs5q
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 45]: To: <sip:users@192.168.10.180>;tag=as23e352d2
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 97]: Contact: <sip:andy@192.168.10.43>;+sip.instance="<urn:uuid:af2e5b37-4eae-47   ba-b166-af1e3b364580>"
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 12]: CSeq: 20 ACK
--- (8 headers 0 lines) ---
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: QnoZcB0b4t (Checking From) --From tag 1LEjyHs5q --To-tag as23e352d2
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:28146 handle_incoming: **** Received ACK (6) - Command in SIP ACK
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:4534 __sip_ack: ** SIP TIMER: Cancelling retransmit of packet (reply received) Retransid #65
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:4567 __sip_ack: Stopping retransmission on 'QnoZcB0b4t' of Response 20: Match Found
Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.Vmq1qAKcq;rport
CSeq: 21 INVITE
Call-ID: QnoZcB0b4t
Content-Length: 175
Authorization: Digest realm="asterisk", nonce="07eb8ddc", username="andy", uri="sip:users@192.168.10.180", response="145dc6508356c27fa639be3f31aca31e"
v=0
s=Talk
b=AS:380
t=0 0
a=fmtp:101 0-11
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 66]: Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.Vmq1qAKcq;rport
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 15]: CSeq: 21 INVITE
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 12 [150]: Authorization: Digest realm="asterisk", nonce="07eb8ddc", username="andy",    uri="sip:users@192.168.10.180", response="145dc6508356c27fa639be3f31aca31e"
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 13 [  0]:
--- (13 headers 9 lines) ---
[Feb 25 00:24:38] DEBUG[2154]: netsock2.c:138 ast_sockaddr_split_hostport: Splitting '192.168.10.180' into...
[Feb 25 00:24:38] DEBUG[2154]: netsock2.c:192 ast_sockaddr_split_hostport: ...host '192.168.10.180' and port ''.
Sending to 192.168.10.43:5060 (NAT)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:283 ast_rtp_instance_new: Using engine 'asterisk' for RTP instance '0x7ec83c'
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:1808 ast_rtp_new: Allocated port 18170 for RTP instance '0x7ec83c'
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:292 ast_rtp_instance_new: RTP instance '0x7ec83c' is setup and ready to go
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:283 ast_rtp_instance_new: Using engine 'asterisk' for RTP instance '0x7dfb44'
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:1808 ast_rtp_new: Allocated port 18952 for RTP instance '0x7dfb44'
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:292 ast_rtp_instance_new: RTP instance '0x7dfb44' is setup and ready to go
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3947 ast_rtp_prop_set: Setup RTCP on RTP instance '0x7dfb44'
  == Using SIP VIDEO CoS mark 6
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3947 ast_rtp_prop_set: Setup RTCP on RTP instance '0x7ec83c'
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:5736 do_setnat: Setting NAT on RTP to On
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:5740 do_setnat: Setting NAT on VRTP to On
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP v=0... UNSUPPORTED OR FAILED.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP o=andy 2300 2717 IN IP4 192.168.10.43... OK.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP s=Talk... UNSUPPORTED OR FAILED.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: netsock2.c:138 ast_sockaddr_split_hostport: Splitting '192.168.10.43' into...
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: netsock2.c:192 ast_sockaddr_split_hostport: ...host '192.168.10.43' and port ''.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP c=IN IP4 192.168.10.43... OK.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP b=AS:380... UNSUPPORTED OR FAILED.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP t=0 0... UNSUPPORTED OR FAILED.
Found RTP audio format 9
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:557 ast_rtp_codecs_payloads_set_m_type: Setting payload 9 based on m type on 0x7d9ec77c
Found RTP audio format 3
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:557 ast_rtp_codecs_payloads_set_m_type: Setting payload 3 based on m type on 0x7d9ec77c
Found RTP audio format 101
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:557 ast_rtp_codecs_payloads_set_m_type: Setting payload 101 based on m type on 0x7d9ec77c
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=rtpmap:101 telephone-event/8000... OK.
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=fmtp:101 0-11... UNSUPPORTED OR FAILED.
Capabilities: us - (gsm|ulaw|alaw|h263|testlaw), peer - audio=(gsm|g722)/video=(nothing)/text=(nothing), combined - (gsm)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3994 ast_rtp_remote_address_set: Setting RTCP address on RTP instance '0x7ec83c'
Peer audio RTP is at port 192.168.10.43:7076
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:515 ast_rtp_codecs_payloads_copy: Copying payload 3 from 0x7d9ec77c to 0x7ec9e8
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:515 ast_rtp_codecs_payloads_copy: Copying payload 9 from 0x7d9ec77c to 0x7ec9e8
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: rtp_engine.c:515 ast_rtp_codecs_payloads_copy: Copying payload 101 from 0x7d9ec77c to 0x7ec9e8
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3913 ast_rtp_prop_set: Ignoring duplicate RTCP property on RTP instance '0x7ec83c'
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3994 ast_rtp_remote_address_set: Setting RTCP address on RTP instance '0x7dfb44'
Peer doesn't provide video
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:10753 process_sdp: We're settling with these formats: (gsm)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:25403 handle_request_invite: Checking SIP call limits for device andy
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:6680 update_call_counter: Updating call counter for incoming call
Looking for users in sip-dialout (domain 192.168.10.180)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: format_pref.c:339 ast_codec_choose: Could not find preferred codec - Going for the best codec
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:7951 sip_new: *** Our native formats are (gsm)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:7952 sip_new: *** Joint capabilities are (gsm)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:7953 sip_new: *** Our capabilities are (gsm|ulaw|alaw|h263|testlaw)
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:7954 sip_new: *** AST_CODEC_CHOOSE formats are gsm
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:7980 sip_new: This channel can handle video! HOLLYWOOD next!
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:16241 build_route: build_route: Contact hop: <sip:andy@192.168.10.43>;+sip.instance="<urn:uuid:af2e5b   37-4eae-47ba-b166-af1e3b364580>"
list_route: hop: <sip:andy@192.168.10.43>
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:25715 handle_request_invite: SIP/andy-00000000: New call is still down.... Trying...
<--- Transmitting (NAT) to 192.168.10.43:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.Vmq1qAKcq;received=192.168.10.43;rport=5060
Call-ID: QnoZcB0b4t
CSeq: 21 INVITE
Contact: <sip:users@192.168.10.180:5060>
[Feb 25 00:24:38] DEBUG[2154][C-00000000]: chan_sip.c:3875 __sip_xmit: Trying to put 'SIP/2.0 100' onto UDP socket destined for 192.168.10.43:5060
[Feb 25 00:24:38] DEBUG[2144]: devicestate.c:344 _ast_device_state: No provider found, checking channel drivers for SIP - andy
[Feb 25 00:24:38] DEBUG[2144]: chan_sip.c:29602 sip_devicestate: Checking device state for peer andy
[Feb 25 00:24:38] DEBUG[2144]: devicestate.c:467 do_state_change: Changing state for SIP/andy - state 1 (Not in use)
[Feb 25 00:24:38] DEBUG[2144]: devicestate.c:442 devstate_event: device 'SIP/andy' state '1'
Call-ID: QnoZcB0b4t
CSeq: 20 ACK
[Feb 25 00:24:38] DEBUG[2154]: chan_sip.c:28422 handle_request_do: Invalid SIP message - rejected , no callid, len 344
Call-ID: QnoZcB0b4t
CSeq: 20 ACK
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: pbx.c:4890 pbx_extension_helper: Launching 'Dial'
    -- Executing [users@sip-dialout:1] Dial("SIP/andy-00000000", "SIP/users,,tT") in new stack
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: chan_sip.c:29707 sip_request_call: Asked to create a SIP channel with formats: (gsm)
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: chan_sip.c:8770 sip_alloc: Allocating new SIP dialog for 4b3db63057de03b1056906827e9f8dcd@[c0a8:6413:a04a:ff7f::   ]:5060 - INVITE (No RTP)
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: rtp_engine.c:283 ast_rtp_instance_new: Using engine 'asterisk' for RTP instance '0x810404'
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:1808 ast_rtp_new: Allocated port 14582 for RTP instance '0x810404'
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: rtp_engine.c:292 ast_rtp_instance_new: RTP instance '0x810404' is setup and ready to go
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: rtp_engine.c:283 ast_rtp_instance_new: Using engine 'asterisk' for RTP instance '0x81bb34'
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:1808 ast_rtp_new: Allocated port 10946 for RTP instance '0x81bb34'
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: rtp_engine.c:292 ast_rtp_instance_new: RTP instance '0x81bb34' is setup and ready to go
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3947 ast_rtp_prop_set: Setup RTCP on RTP instance '0x81bb34'
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3947 ast_rtp_prop_set: Setup RTCP on RTP instance '0x810404'
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: chan_sip.c:5736 do_setnat: Setting NAT on RTP to On
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: chan_sip.c:5740 do_setnat: Setting NAT on VRTP to On
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: chan_sip.c:3642 obproxy_get: OBPROXY: Not applying OBproxy to this call
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: acl.c:979 ast_ouraddrfor: For destination '192.168.100.232', our source address is '192.168.100.19'.
[Feb 25 00:24:38] DEBUG[2181][C-00000000]: chan_sip.c:4032 ast_sip_ouraddrfor: Setting SIP_TRANSPORT_UDP with address 192.168.100.19:5060
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:8565 change_callid_pvt: SIP call-id changed from '4b3db63057de03b1056906827e9f8dcd@[c0a8:6413:a04a:ff   7f::]:5060' to '45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060'
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: format_pref.c:339 ast_codec_choose: Could not find preferred codec - Going for the best codec
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:7951 sip_new: *** Our native formats are (gsm)
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:7952 sip_new: *** Joint capabilities are (gsm)
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:7953 sip_new: *** Our capabilities are (gsm|ulaw|alaw|h263|testlaw)
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:7954 sip_new: *** AST_CODEC_CHOOSE formats are gsm
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:7956 sip_new: *** Our preferred formats from the incoming channel are (gsm)
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:7980 sip_new: This channel can handle video! HOLLYWOOD next!
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel_internal_api.c:882 ast_channel_callid_set: Channel Call ID changing from [C-00000000] to [C-00000000]
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable DIALEDTIME.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable ANSWEREDTIME.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable DIALEDPEERNAME.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable DIALEDPEERNUMBER.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable DIALSTATUS.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable SIPCALLID.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable SIPDOMAIN.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: channel.c:6507 ast_channel_inherit_variables: Not copying variable SIPURI.
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:6356 sip_call: Outgoing Call for users
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:6680 update_call_counter: Updating call counter for outgoing call
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:13101 add_sdp: This call needs video offers!
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:13151 add_sdp: ** Our capability: (gsm|ulaw|alaw|h263|testlaw) Video flag: False Text flag: False
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:13152 add_sdp: ** Our prefcodec: (gsm)
ccoll
Сообщение ccoll »
Продолжение, Лог2:
Audio is at 14582
Video is at 192.168.100.19:10946
Adding codec 100002 (gsm) to SDP
Adding codec 100003 (ulaw) to SDP
Adding codec 100017 (testlaw) to SDP
Adding video codec 200002 (h263) to SDP
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:13288 add_sdp: -- Done with adding codecs to SDP
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:13482 add_sdp: Done building SDP. Settling with this capability: (gsm|ulaw|alaw|h263|testlaw)
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:3518 initialize_initreq: Initializing initreq for method INVITE - callid 45cb22644fd8103673bb63087ba6   f0e4@192.168.100.19:5060
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  0 [ 45]: INVITE sip:users@192.168.100.232:5060 SIP/2.0
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  1 [ 65]: Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK632b5235;rpo   rt
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  2 [ 16]: Max-Forwards: 70
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  3 [ 46]: From: <sip:andy@192.168.100.19>;tag=as5c9d91ca
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  4 [ 36]: To: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  5 [ 39]: Contact: <sip:andy@192.168.100.19:5060>
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  6 [ 61]: Call-ID: 45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  7 [ 16]: CSeq: 102 INVITE
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  8 [ 31]: User-Agent: Asterisk PBX 11.7.0
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header  9 [ 35]: Date: Wed, 25 Feb 2015 00:24:39 GMT
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header 10 [ 81]: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOT   IFY, INFO, PUBLISH
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header 11 [ 26]: Supported: replaces, timer
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:9617 parse_request:  Header 12 [ 29]: Content-Type: application/sdp
Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK632b5235;rport
CSeq: 102 INVITE
Content-Length: 432
v=0
o=root 1314845379 1314845379 IN IP4 192.168.100.19
s=Asterisk PBX 11.7.0
c=IN IP4 192.168.100.19
b=CT:384
t=0 0
m=audio 14582 RTP/AVP 3 8 0 101
a=rtpmap:3 GSM/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
m=video 10946 RTP/AVP 34
a=rtpmap:34 H263/90000
a=fmtp:34 F=0;I=0;J=0;T=0;K=0;N=0;BPP=0;HRD=0
a=sendrecv
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #68
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:3875 __sip_xmit: Trying to put 'INVITE sip:' onto UDP socket destined for 192.168.100.232:5060
    -- Called SIP/users
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK632b5235;rport=5060
CSeq: 102 INVITE
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 18]: SIP/2.0 100 Trying
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 70]: Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK632b5235;rport=5060
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 46]: From: <sip:andy@192.168.100.19>;tag=as5c9d91ca
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 36]: To: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 61]: Call-ID: 45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 16]: CSeq: 102 INVITE
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 71]: Allow: INVITE, OPTIONS, ACK, BYE, CANCEL, INFO, NOTIFY, MESSAGE, UPDATE
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 29]: Server: SIPPER for PhonerLite
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 17]: Content-Length: 0
--- (9 headers 0 lines) ---
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060 (Checking To) --From    tag as5c9d91ca --To-tag
[Feb 25 00:24:39] DEBUG[2154][C-00000000]: chan_sip.c:4601 __sip_semi_ack: *** SIP TIMER: Cancelling retransmission #68 - INVITE (got response)
[Feb 25 00:24:39] DEBUG[2154][C-00000000]: chan_sip.c:4608 __sip_semi_ack: (Provisional) Stopping retransmission (but retaining packet) on '45cb22644fd8103   673bb63087ba6f0e4@192.168.100.19:5060' Request 102: Found
[Feb 25 00:24:39] DEBUG[2154][C-00000000]: chan_sip.c:22601 handle_response_invite: SIP response 100 to standard invite
SIP/2.0 180 Ringing
To: <sip:users@192.168.100.232:5060>;tag=00a46c10c0bae41198937571a1da2b4c
CSeq: 102 INVITE
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 19]: SIP/2.0 180 Ringing
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 73]: To: <sip:users@192.168.100.232:5060>;tag=00a46c10c0bae41198937571a1da2b4c
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 41]: Contact: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 71]: Allow: INVITE, OPTIONS, ACK, BYE, CANCEL, INFO, NOTIFY, MESSAGE, UPDATE
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 29]: Server: SIPPER for PhonerLite
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 17]: Content-Length: 0
[Feb 25 00:24:39] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060 (Checking To) --From    tag as5c9d91ca --To-tag 00a46c10c0bae41198937571a1da2b4c
[Feb 25 00:24:39] DEBUG[2154][C-00000000]: chan_sip.c:22601 handle_response_invite: SIP response 180 to standard invite
[Feb 25 00:24:39] DEBUG[2154][C-00000000]: chan_sip.c:16241 build_route: build_route: Contact hop: <sip:users@192.168.100.232:5060>
list_route: hop: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:39] DEBUG[2144]: devicestate.c:344 _ast_device_state: No provider found, checking channel drivers for SIP - users
[Feb 25 00:24:39] DEBUG[2144]: chan_sip.c:29602 sip_devicestate: Checking device state for peer users
[Feb 25 00:24:39] DEBUG[2144]: devicestate.c:467 do_state_change: Changing state for SIP/users - state 1 (Not in use)
[Feb 25 00:24:39] DEBUG[2144]: devicestate.c:442 devstate_event: device 'SIP/users' state '1'
    -- SIP/users-00000001 is ringing
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: rtp_engine.c:1805 ast_rtp_instance_early_bridge: Setting early bridge SDP of 'SIP/andy-00000000' with that of 'S   IP/users-00000001'
SIP/2.0 180 Ringing
To: sip:users@192.168.10.180;tag=as6925596a
Call-ID: QnoZcB0b4t
CSeq: 21 INVITE
[Feb 25 00:24:39] DEBUG[2181][C-00000000]: chan_sip.c:3875 __sip_xmit: Trying to put 'SIP/2.0 180' onto UDP socket destined for 192.168.10.43:5060
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces, from-change
Content-Length: 305
v=0
o=- 2751694236 1 IN IP4 192.168.100.232
s=SIPPER for PhonerLite
c=IN IP4 192.168.100.232
t=0 0
m=audio 5062 RTP/AVP 3 8 0 101
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ssrc:554319825
a=sendrecv
m=video 0 RTP/AVP 34
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 14]: SIP/2.0 200 OK
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 70]: Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK632b5235;rport=5060
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 46]: From: <sip:andy@192.168.100.19>;tag=as5c9d91ca
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 73]: To: <sip:users@192.168.100.232:5060>;tag=00a46c10c0bae41198937571a1da2b4c
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 61]: Call-ID: 45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 16]: CSeq: 102 INVITE
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 60 bytes
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3581 ast_rtp_read: 0x814f80 -- Probation learning mode pass with source address 192.168.100.2   32:5062
       > 0x814f80 -- Probation passed - setting RTP source address to 192.168.100.232:5062
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3994 ast_rtp_remote_address_set: Setting RTCP address on RTP instance '0x810404'
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 41]: Contact: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 29]: Content-Type: application/sdp
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 71]: Allow: INVITE, OPTIONS, ACK, BYE, CANCEL, INFO, NOTIFY, MESSAGE, UPDATE
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 32]: Supported: replaces, from-change
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 10 [ 29]: Server: SIPPER for PhonerLite
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 11 [ 19]: Content-Length: 305
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 12 [  0]:
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  0 [  3]: v=0
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  1 [ 39]: o=- 2751694236 1 IN IP4 192.168.100.232
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  2 [ 23]: s=SIPPER for PhonerLite
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  3 [ 24]: c=IN IP4 192.168.100.232
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  4 [  5]: t=0 0
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  5 [ 30]: m=audio 5062 RTP/AVP 3 8 0 101
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  6 [ 19]: a=rtpmap:3 GSM/8000
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  7 [ 20]: a=rtpmap:8 PCMA/8000
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  8 [ 20]: a=rtpmap:0 PCMU/8000
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body  9 [ 33]: a=rtpmap:101 telephone-event/8000
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body 10 [ 15]: a=fmtp:101 0-16
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body 11 [ 16]: a=ssrc:554319825
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9617 parse_request:    Body 12 [ 10]: a=sendrecv
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9654 parse_request:    Body 13 [ 20]: m=video 0 RTP/AVP 34
--- (12 headers 14 lines) ---
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060 (Checking To) --From    tag as5c9d91ca --To-tag 00a46c10c0bae41198937571a1da2b4c
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:4529 __sip_ack: Acked pending invite 102
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:4567 __sip_ack: Stopping retransmission on '45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:5060' of    Request 102: Match Found
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:22601 handle_response_invite: SIP response 200 to standard invite
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP v=0... UNSUPPORTED OR FAILED.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP o=- 2751694236 1 IN IP4 192.168.100.232... OK.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP s=SIPPER for PhonerLite... UNSUPPORTED OR FAILED.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: netsock2.c:138 ast_sockaddr_split_hostport: Splitting '192.168.100.232' into...
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: netsock2.c:192 ast_sockaddr_split_hostport: ...host '192.168.100.232' and port ''.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP c=IN IP4 192.168.100.232... OK.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10049 process_sdp: Processing session-level SDP t=0 0... UNSUPPORTED OR FAILED.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:557 ast_rtp_codecs_payloads_set_m_type: Setting payload 3 based on m type on 0x7d9ebe4c
Found RTP audio format 8
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:557 ast_rtp_codecs_payloads_set_m_type: Setting payload 8 based on m type on 0x7d9ebe4c
Found RTP audio format 0
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:557 ast_rtp_codecs_payloads_set_m_type: Setting payload 0 based on m type on 0x7d9ebe4c
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:557 ast_rtp_codecs_payloads_set_m_type: Setting payload 101 based on m type on 0x7d9ebe4c
Found audio description format GSM for ID 3
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=rtpmap:3 GSM/8000... OK.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=rtpmap:8 PCMA/8000... OK.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=rtpmap:0 PCMU/8000... OK.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=rtpmap:101 telephone-event/8000... OK.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=fmtp:101 0-16... UNSUPPORTED OR FAILED.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=ssrc:554319825... UNSUPPORTED OR FAILED.
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10482 process_sdp: Processing media-level (audio) SDP a=sendrecv... OK.
[Feb 25 00:24:43] WARNING[2154][C-00000000]: chan_sip.c:10207 process_sdp: Ignoring video stream offer because port number is zero
Capabilities: us - (gsm|ulaw|alaw|h263|testlaw), peer - audio=(gsm|ulaw|alaw)/video=(nothing)/text=(nothing), combined - (gsm|ulaw|alaw)
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3994 ast_rtp_remote_address_set: Setting RTCP address on RTP instance '0x810404'
Peer audio RTP is at port 192.168.100.232:5062
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:515 ast_rtp_codecs_payloads_copy: Copying payload 0 from 0x7d9ebe4c to 0x8105b0
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:515 ast_rtp_codecs_payloads_copy: Copying payload 3 from 0x7d9ebe4c to 0x8105b0
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:515 ast_rtp_codecs_payloads_copy: Copying payload 8 from 0x7d9ebe4c to 0x8105b0
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: rtp_engine.c:515 ast_rtp_codecs_payloads_copy: Copying payload 101 from 0x7d9ebe4c to 0x8105b0
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3913 ast_rtp_prop_set: Ignoring duplicate RTCP property on RTP instance '0x810404'
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: res_rtp_asterisk.c:3994 ast_rtp_remote_address_set: Setting RTCP address on RTP instance '0x81bb34'
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10753 process_sdp: We're settling with these formats: (gsm|ulaw|alaw)
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10760 process_sdp: We have an owner, now see if we need to change this call
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:10766 process_sdp: Setting native formats after processing SDP. peer joint formats (gsm|ulaw|alaw), o   ld nativeformats (gsm)
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: channel.c:5361 set_format: Set channel SIP/users-00000001 to read format gsm
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: channel.c:5361 set_format: Set channel SIP/users-00000001 to write format gsm
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:6680 update_call_counter: Updating call counter for outgoing call
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:16241 build_route: build_route: Contact hop: <sip:users@192.168.100.232:5060>
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:11898 reqprep: Strict routing enforced for session 45cb22644fd8103673bb63087ba6f0e4@192.168.100.19:50   60
set_destination: Parsing <sip:users@192.168.100.232:5060> for address/port to send to
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: netsock2.c:138 ast_sockaddr_split_hostport: Splitting '192.168.100.232:5060' into...
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: netsock2.c:192 ast_sockaddr_split_hostport: ...host '192.168.100.232' and port '5060'.
set_destination: set destination to 192.168.100.232:5060
ACK sip:users@192.168.100.232:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK3ce4a04b;rport
CSeq: 102 ACK
[Feb 25 00:24:43] DEBUG[2154][C-00000000]: chan_sip.c:3875 __sip_xmit: Trying to put 'ACK sip:use' onto UDP socket destined for 192.168.100.232:5060
[Feb 25 00:24:43] DEBUG[2144]: devicestate.c:344 _ast_device_state: No provider found, checking channel drivers for SIP - users
[Feb 25 00:24:43] DEBUG[2144]: chan_sip.c:29602 sip_devicestate: Checking device state for peer users
[Feb 25 00:24:43] DEBUG[2144]: devicestate.c:467 do_state_change: Changing state for SIP/users - state 1 (Not in use)
[Feb 25 00:24:43] DEBUG[2144]: devicestate.c:442 devstate_event: device 'SIP/users' state '1'
    -- SIP/users-00000001 answered SIP/andy-00000000
[Feb 25 00:24:43] DEBUG[2144]: devicestate.c:344 _ast_device_state: No provider found, checking channel drivers for SIP - andy
[Feb 25 00:24:43] DEBUG[2144]: chan_sip.c:29602 sip_devicestate: Checking device state for peer andy
[Feb 25 00:24:43] DEBUG[2144]: devicestate.c:467 do_state_change: Changing state for SIP/andy - state 1 (Not in use)
[Feb 25 00:24:43] DEBUG[2144]: devicestate.c:442 devstate_event: device 'SIP/andy' state '1'
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:7277 sip_answer: SIP answering channel: SIP/andy-00000000
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2175 ast_rtp_update_source: Setting the marker bit due to a source update
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:13596 transmit_response_with_sdp: Setting framing from config on incoming call
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:13151 add_sdp: ** Our capability: (gsm) Video flag: True Text flag: True
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:13152 add_sdp: ** Our prefcodec: (nothing)
Audio is at 18170
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:13288 add_sdp: -- Done with adding codecs to SDP
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:13482 add_sdp: Done building SDP. Settling with this capability: (gsm)
SIP/2.0 200 OK
Call-ID: QnoZcB0b4t
CSeq: 21 INVITE
Content-Length: 265
v=0
o=root 1105373035 1105373035 IN IP4 192.168.10.180
c=IN IP4 192.168.10.180
t=0 0
m=audio 18170 RTP/AVP 3 101
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #72
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:3875 __sip_xmit: Trying to put 'SIP/2.0 200' onto UDP socket destined for 192.168.10.43:5060
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: features.c:4429 ast_bridge_call: bridge answer set, chan answer set
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: features.c:4250 clear_dialed_interfaces: Removing dialed interfaces datastore on SIP/users-00000001 since we're    bridging
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: chan_sip.c:8392 sip_rtp_read: Oooh, format changed to gsm
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: channel.c:5361 set_format: Set channel SIP/users-00000001 to read format gsm
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: channel.c:5361 set_format: Set channel SIP/users-00000001 to write format gsm
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2707 ast_rtp_write: Ooh, format changed from unknown to gsm
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2742 ast_rtp_write: Created smoother: format: gsm ms: 20 len: 33
[Feb 25 00:24:43] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2600 ast_rtp_raw_write: Starting RTCP transmission on RTP instance '0x7ec83c'
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:4119 retrans_pkt: SIP TIMER: Rescheduling retransmission #72 (1) SIP/2.0 - 1
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:4139 retrans_pkt: ** SIP timers: Rescheduling retransmission 2 to 200 ms (t1 100 ms (Retrans id #72))
SIP/2.0 200 OK
Call-ID: QnoZcB0b4t
CSeq: 21 INVITE
Content-Length: 265
v=0
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'SIP/2.0 200' onto UDP socket destined for 192.168.10.43:5060
[Feb 25 00:24:43] DEBUG[2154]: chan_sip.c:4119 retrans_pkt: SIP TIMER: Rescheduling retransmission #72 (2) SIP/2.0 - 1
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:4139 retrans_pkt: ** SIP timers: Rescheduling retransmission 3 to 400 ms (t1 100 ms (Retrans id #72))
SIP/2.0 200 OK
Call-ID: QnoZcB0b4t
CSeq: 21 INVITE
Content-Length: 265
v=0
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'SIP/2.0 200' onto UDP socket destined for 192.168.10.43:5060
ACK sip:users@192.168.10.180:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.43:5060;rport;branch=z9hG4bK.Hlx0r1wTj
To: <sip:users@192.168.10.180>;tag=as6925596a
CSeq: 21 ACK
Call-ID: QnoZcB0b4t
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 41]: ACK sip:users@192.168.10.180:5060 SIP/2.0
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 66]: Via: SIP/2.0/UDP 192.168.10.43:5060;rport;branch=z9hG4bK.Hlx0r1wTj
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 45]: From: <sip:andy@192.168.10.180>;tag=1LEjyHs5q
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 45]: To: <sip:users@192.168.10.180>;tag=as6925596a
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 12]: CSeq: 21 ACK
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 19]: Call-ID: QnoZcB0b4t
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 16]: Max-Forwards: 70
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [150]: Authorization: Digest realm="asterisk", nonce="07eb8ddc", username="andy",    uri="sip:users@192.168.10.180", response="145dc6508356c27fa639be3f31aca31e"
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: QnoZcB0b4t (Checking From) --From tag 1LEjyHs5q --To-tag as6925596a
[Feb 25 00:24:44] DEBUG[2154][C-00000000]: chan_sip.c:28146 handle_incoming: **** Received ACK (6) - Command in SIP ACK
[Feb 25 00:24:44] DEBUG[2154][C-00000000]: chan_sip.c:4534 __sip_ack: ** SIP TIMER: Cancelling retransmit of packet (reply received) Retransid #72
[Feb 25 00:24:44] DEBUG[2154][C-00000000]: chan_sip.c:4567 __sip_ack: Stopping retransmission on 'QnoZcB0b4t' of Response 21: Match Found
[Feb 25 00:24:44] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3581 ast_rtp_read: 0x7fdfa0 -- Probation learning mode pass with source address 192.168.10.43   :7076
       > 0x7fdfa0 -- Probation passed - setting RTP source address to 192.168.10.43:7076
[Feb 25 00:24:44] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2707 ast_rtp_write: Ooh, format changed from unknown to gsm
[Feb 25 00:24:44] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2742 ast_rtp_write: Created smoother: format: gsm ms: 20 len: 33
Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.Hlx0r1wTj;rport
CSeq: 21 ACK
Call-ID: QnoZcB0b4t
[Feb 25 00:24:44] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 66]: Via: SIP/2.0/UDP 192.168.10.43:5060;branch=z9hG4bK.Hlx0r1wTj;rport
CSeq: 21 ACK
Call-ID: QnoZcB0b4t
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:8770 sip_alloc: Allocating new SIP dialog for 7f53e8b771fdfd101b9dde2c5cd5bd7e@[c0a8:6413:a04a:ff7f::]:5060 - OPT   IONS (No RTP)
[Feb 25 00:24:45] DEBUG[2154]: acl.c:979 ast_ouraddrfor: For destination '192.168.10.101', our source address is '192.168.10.180'.
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:4032 ast_sip_ouraddrfor: Setting SIP_TRANSPORT_UDP with address 192.168.10.180:5060
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:8565 change_callid_pvt: SIP call-id changed from '7f53e8b771fdfd101b9dde2c5cd5bd7e@[c0a8:6413:a04a:ff7f::]:5060'    to '471fc8e37ccb18fe3f173c120cb987bb@192.168.10.180:5060'
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:3518 initialize_initreq: Initializing initreq for method OPTIONS - callid 471fc8e37ccb18fe3f173c120cb987bb@192.16   8.10.180:5060
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 45]: OPTIONS sip:SPA31@192.168.10.101:5060 SIP/2.0
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 59]: Via: SIP/2.0/UDP 192.168.10.180:5060;branch=z9hG4bK42bb6616
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 16]: Max-Forwards: 70
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 61]: From: "asterisk" <sip:asterisk@192.168.10.180>;tag=as222b0efb
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 35]: To: <sip:SPA31@192.168.10.101:5060>
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 43]: Contact: <sip:asterisk@192.168.10.180:5060>
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 61]: Call-ID: 471fc8e37ccb18fe3f173c120cb987bb@192.168.10.180:5060
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 31]: User-Agent: Asterisk PBX 11.7.0
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 35]: Date: Wed, 25 Feb 2015 00:24:45 GMT
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 10 [ 81]: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, P   UBLISH
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 11 [ 26]: Supported: replaces, timer
CSeq: 102 OPTIONS
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #74
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'OPTIONS sip' onto UDP socket destined for 192.168.10.101:5060
SIP/2.0 200 OK
To: <sip:SPA31@192.168.10.101:5060>;tag=e8a8c8fd324837b3i1
CSeq: 102 OPTIONS
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 14]: SIP/2.0 200 OK
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 58]: To: <sip:SPA31@192.168.10.101:5060>;tag=e8a8c8fd324837b3i1
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 61]: From: "asterisk" <sip:asterisk@192.168.10.180>;tag=as222b0efb
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 61]: Call-ID: 471fc8e37ccb18fe3f173c120cb987bb@192.168.10.180:5060
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 59]: Via: SIP/2.0/UDP 192.168.10.180:5060;branch=z9hG4bK42bb6616
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 37]: Server: Linksys/SPA3102-5.2.13(GW002)
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 17]: Content-Length: 0
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 61]: Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 29]: Supported: x-sipura, replaces
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 471fc8e37ccb18fe3f173c120cb987bb@192.168.10.180:5060 (Checking To) --From    tag as222b0efb --To-tag e8a8c8fd324837b3i1
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:4534 __sip_ack: ** SIP TIMER: Cancelling retransmit of packet (reply received) Retransid #74
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:4567 __sip_ack: Stopping retransmission on '471fc8e37ccb18fe3f173c120cb987bb@192.168.10.180:5060' of Request 102:    Match Found
[Feb 25 00:24:45] DEBUG[2154]: chan_sip.c:6828 sip_destroy: Destroying SIP dialog 471fc8e37ccb18fe3f173c120cb987bb@192.168.10.180:5060
Really destroying SIP dialog '471fc8e37ccb18fe3f173c120cb987bb@192.168.10.180:5060' Method: OPTIONS
[Feb 25 00:24:46] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 124 bytes
[Feb 25 00:24:49] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 124 bytes
[Feb 25 00:24:51] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 124 bytes
[Feb 25 00:24:52] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 84 bytes
[Feb 25 00:24:54] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 124 bytes
[Feb 25 00:24:56] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 124 bytes
[Feb 25 00:24:56] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [  0]:
[Feb 25 00:24:59] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 124 bytes
[Feb 25 00:25:02] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 84 bytes
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:8770 sip_alloc: Allocating new SIP dialog for 5454d6473d7a2fb13656680d12f3f9d7@[c0a8:6413:a04a:ff7f::]:5060 - OPT   IONS (No RTP)
[Feb 25 00:25:03] DEBUG[2154]: acl.c:979 ast_ouraddrfor: For destination '192.168.100.232', our source address is '192.168.100.19'.
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:4032 ast_sip_ouraddrfor: Setting SIP_TRANSPORT_UDP with address 192.168.100.19:5060
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:8565 change_callid_pvt: SIP call-id changed from '5454d6473d7a2fb13656680d12f3f9d7@[c0a8:6413:a04a:ff7f::]:5060'    to '5e31b007360fb3b83b78ba3a3a184807@192.168.100.19:5060'
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:3518 initialize_initreq: Initializing initreq for method OPTIONS - callid 5e31b007360fb3b83b78ba3a3a184807@192.16   8.100.19:5060
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 46]: OPTIONS sip:users@192.168.100.232:5060 SIP/2.0
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 65]: Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK352ebb5f;rport
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 16]: Max-Forwards: 70
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 61]: From: "asterisk" <sip:asterisk@192.168.100.19>;tag=as4d14e09d
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 36]: To: <sip:users@192.168.100.232:5060>
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 43]: Contact: <sip:asterisk@192.168.100.19:5060>
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 61]: Call-ID: 5e31b007360fb3b83b78ba3a3a184807@192.168.100.19:5060
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 31]: User-Agent: Asterisk PBX 11.7.0
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 35]: Date: Wed, 25 Feb 2015 00:25:03 GMT
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 10 [ 81]: Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, P   UBLISH
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header 11 [ 26]: Supported: replaces, timer
Reliably Transmitting (NAT) to 192.168.100.232:5060:
CSeq: 102 OPTIONS
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:4335 __sip_reliable_xmit: *** SIP TIMER: Initializing retransmit timer on packet: Id  #77
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:3875 __sip_xmit: Trying to put 'OPTIONS sip' onto UDP socket destined for 192.168.100.232:5060
<--- SIP read from UDP:192.168.100.232:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK352ebb5f;rport=5060
To: <sip:users@192.168.100.232:5060>;tag=8056531fc0bae41198937571a1da2b4c
CSeq: 102 OPTIONS
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  0 [ 14]: SIP/2.0 200 OK
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  1 [ 70]: Via: SIP/2.0/UDP 192.168.100.19:5060;branch=z9hG4bK352ebb5f;rport=5060
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  2 [ 61]: From: "asterisk" <sip:asterisk@192.168.100.19>;tag=as4d14e09d
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  3 [ 73]: To: <sip:users@192.168.100.232:5060>;tag=8056531fc0bae41198937571a1da2b4c
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  4 [ 61]: Call-ID: 5e31b007360fb3b83b78ba3a3a184807@192.168.100.19:5060
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  5 [ 17]: CSeq: 102 OPTIONS
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  6 [ 41]: Contact: <sip:users@192.168.100.232:5060>
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  7 [ 71]: Allow: INVITE, OPTIONS, ACK, BYE, CANCEL, INFO, NOTIFY, MESSAGE, UPDATE
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  8 [ 29]: Server: SIPPER for PhonerLite
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9617 parse_request:  Header  9 [ 17]: Content-Length: 0
--- (10 headers 0 lines) ---
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:9167 find_call: = Looking for  Call ID: 5e31b007360fb3b83b78ba3a3a184807@192.168.100.19:5060 (Checking To) --From    tag as4d14e09d --To-tag 8056531fc0bae41198937571a1da2b4c
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:4534 __sip_ack: ** SIP TIMER: Cancelling retransmit of packet (reply received) Retransid #77
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:4567 __sip_ack: Stopping retransmission on '5e31b007360fb3b83b78ba3a3a184807@192.168.100.19:5060' of Request 102:    Match Found
[Feb 25 00:25:03] DEBUG[2154]: chan_sip.c:6828 sip_destroy: Destroying SIP dialog 5e31b007360fb3b83b78ba3a3a184807@192.168.100.19:5060
Really destroying SIP dialog '5e31b007360fb3b83b78ba3a3a184807@192.168.100.19:5060' Method: OPTIONS
[Feb 25 00:25:04] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:3184 ast_rtcp_read: Got RTCP report of 124 bytes
[Feb 25 00:25:04] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2852 create_dtmf_frame: Creating BEGIN DTMF Frame: 35 (#), at 192.168.100.232:5062
[Feb 25 00:25:04] DTMF[2181][C-00000000]: channel.c:4170 __ast_read: DTMF begin '#' received on SIP/users-00000001
[Feb 25 00:25:04] DTMF[2181][C-00000000]: channel.c:4181 __ast_read: DTMF begin passthrough '#' on SIP/users-00000001
[Feb 25 00:25:04] DEBUG[2181][C-00000000]: channel.c:7649 ast_generic_bridge: Got DTMF begin on channel (SIP/users-00000001)
[Feb 25 00:25:04] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2175 ast_rtp_update_source: Setting the marker bit due to a source update
[Feb 25 00:25:04] DEBUG[2181][C-00000000]: channel.c:8069 ast_channel_bridge: Bridge stops bridging channels SIP/andy-00000000 and SIP/users-00000001
[Feb 25 00:25:04] DEBUG[2181][C-00000000]: features.c:3611 feature_interpret_helper: Feature detected: fname=Blind Transfer sname=blindxfer exten=#
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: features.c:4646 ast_bridge_call: Not passing DTMF through, since it may be a feature code
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2175 ast_rtp_update_source: Setting the marker bit due to a source update
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: res_rtp_asterisk.c:2852 create_dtmf_frame: Creating END DTMF Frame: 35 (#), at 192.168.100.232:5062
[Feb 25 00:25:05] DTMF[2181][C-00000000]: channel.c:4084 __ast_read: DTMF end '#' received on SIP/users-00000001, duration 80 ms
[Feb 25 00:25:05] DTMF[2181][C-00000000]: channel.c:4125 __ast_read: DTMF end accepted with begin '#' on SIP/users-00000001
[Feb 25 00:25:05] DTMF[2181][C-00000000]: channel.c:4140 __ast_read: DTMF end '#' detected to have actual duration 60 on the wire, emulation will be trigge   red on SIP/users-00000001
[Feb 25 00:25:05] DTMF[2181][C-00000000]: channel.c:4147 __ast_read: DTMF end '#' has duration 60 but want minimum 80, emulating on SIP/users-00000001
[Feb 25 00:25:05] DTMF[2181][C-00000000]: channel.c:4204 __ast_read: DTMF end emulation of '#' queued on SIP/users-00000001
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: channel.c:7649 ast_generic_bridge: Got DTMF end on channel (SIP/users-00000001)
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: channel.c:8069 ast_channel_bridge: Bridge stops bridging channels SIP/andy-00000000 and SIP/users-00000001
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: features.c:3740 feature_interpret: Feature interpret: chan=SIP/andy-00000000, peer=SIP/users-00000001, code=#, s   ense=2, features=2, dynamic=#
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: features.c:3611 feature_interpret_helper: Feature detected: fname=Blind Transfer sname=blindxfer exten=#
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: features.c:2521 builtin_blindtransfer: Executing Blind Transfer SIP/andy-00000000, SIP/users-00000001 (sense=2)
    -- Started music on hold, class 'default', on SIP/andy-00000000
[Feb 25 00:25:05] DEBUG[2181][C-00000000]: channel.c:3577 ast_settimeout: Scheduling timer at (50 requested / 50 actual) timer ticks per second
CLI>
Disconnected from Asterisk server
Asterisk cleanly ending (0).
Executing last minute cleanups
Re: Вылетает Asterisk при использвании перенаправления звонк
ded писал(а):Ваш Asus не может проиграть музыку, которую туда ему засунули.
Для начала уберите музыку в ожидании качестве КПВ - гудков вызова.
Потом убедитесь, что вы подсунули годный файл музыки. МР3 не нужно, нужен некомпрессированный wav, и не стерео, а моно, РСМб 8Кгц.
Вы пробовали так? Проигнорировали. У вас такая палитра кодеков в скромном по ресурсам устройстве, зачем Вы усложняете ему задачу?
У вас предпочтительный выбор идёт кодек gsm
Не хотите попробовать capability: (ulaw|alaw) ??
да ещё и звоните с софтфона с видео поддержкой!
Может сначала упростите опыт?
Dial(SIP/andy,,t&SIP/users,,t)
Это Вы где такое подсмотрели?
В УЧЕБНИК однозначно..
учимся писАть правильно:
Dial(SIP/andy&SIP/users,,tT)
И учимся указывать верные данные в секции [general] в sip*.conf. Также и читаем до просветления про формат поля callerid у пиров sip.
Музыку также можно попробовать потестить отдельно:
exten => 6000,1,Answer
exten => 6000,2,MusicOnHold()
