Panasonic TDA600(PRI)- ASTERISK(libpri) и CALLERID
Re: Panasonic TDA600(PRI)- ASTERISK(libpri) и CALLERID
I - Asterisk will ignore any connected line update requests or any redirecting party update requests it may receive on this dial attempt.
интересно..
Вы можете выложить инвайты для обоих случаев?
1g0r
Сообщение 1g0r »
С ключем [ I ]
<--- SIP read from UDP:192.168.15.209:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.0.1:5060;received=192.168.0.1;branch=z9hG4bK2d87d8e7
Call-ID: 04b2721315920d120dcf7b29442d27a1@local
To: <sip:7071@192.168.15.209;ob>;tag=neNN5pGTFqcPk8woMuijqo1x.yM.nbS-
CSeq: 102 INVITE
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
User-Agent: Digium D70 1_4_2_0_63880
Contact: "Ололо <7071>" <sip:7071@192.168.15.209:5060;ob>
Supported: replaces, 100rel, timer, norefersub
Content-Length: 251
v=0
o=- 123168657 123168658 IN IP4 192.168.15.209
s=digphn
c=IN IP4 192.168.15.209
t=0 0
a=X-nat:0
m=audio 4062 RTP/AVP 8 96
a=rtcp:4063 IN IP4 192.168.15.209
a=rtpmap:8 PCMA/8000
a=sendrecv
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
--- (13 headers 12 lines) ---
  == Using UDPTL CoS mark 5
Found RTP audio format 8
Found RTP audio format 96
Found audio description format telephone-event for ID 96
Capabilities: us - 0x8 (alaw), peer - audio=0x8 (alaw)/video=0x0 (nothing)/text=0x0 (nothing), combined - 0x8 (alaw)
Peer audio RTP is at port 192.168.15.209:4062
list_route: hop: <sip:7071@192.168.15.209:5060;ob>
set_destination: Parsing <sip:7071@192.168.15.209:5060;ob> for address/port to send to
set_destination: set destination to 192.168.15.209:5060
Transmitting (no NAT) to 192.168.15.209:5060:
ACK sip:7071@192.168.15.209:5060;ob SIP/2.0
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK05f0480a
To: <sip:7071@192.168.15.209:5060;ob>;tag=neNN5pGTFqcPk8woMuijqo1x.yM.nbS-
Contact: <sip:1070@192.168.0.1:5060>
CSeq: 102 ACK
User-Agent: Asterisk PBX
    -- Connected line update to DAHDI/i1/1070-2e9f prevented.
    -- SIP/7071-0000181a answered DAHDI/i1/1070-2e9f
Reliably Transmitting (no NAT) to 192.168.15.209:5060:
NOTIFY sip:7071@192.168.15.209:5060;ob SIP/2.0
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK7d83e46d;rport
To: "Ололо <7071>" <sip:7071@192.168.0.1>;tag=26OuB30H4KU6z5.w4kUiOpH7luy.Oedx
Contact: <sip:7071@192.168.0.1:5060>
Call-ID: UMg5Jr5aVnlJWgqWXzaBZCOs7MZfs.XC
CSeq: 107 NOTIFY
Subscription-State: active
Event: presence
Content-Type: application/pidf+xml
Content-Length: 530
<?xml version="1.0" encoding="ISO-8859-1"?>
<presence xmlns="urn:ietf:params:xml:ns:pidf"
xmlns:pp="urn:ietf:params:xml:ns:pidf:person"
xmlns:es="urn:ietf:params:xml:ns:pidf:rpid:status:rpid-status"
xmlns:ep="urn:ietf:params:xml:ns:pidf:rpid:rpid-person"
entity="sip:7071@192.168.0.1">
<pp:person><status>
<ep:activities><ep:busy/></ep:activities>
</status></pp:person>
<note>On the phone</note>
<tuple id="7071">
<contact priority="1">sip:7071@192.168.0.1</contact>
<status><basic>open</basic></status>
</tuple>
</presence>
  == Extension Changed 7071[SUBSCRIPTIONS] new state InUse for Notify User 7071
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.0.1:5060;rport=5060;received=192.168.0.1;branch=z9hG4bK7d83e46d
CSeq: 107 NOTIFY
Без ключика [ I ]
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.0.1:5060;received=192.168.0.1;branch=z9hG4bK42f7e037
Call-ID: 7ad974686d13c11b26c48ec841f4b47f@local
To: <sip:7071@192.168.15.209;ob>;tag=vIj.WaaemCIkwLsBIjcc0xvndhCtg2UD
CSeq: 102 INVITE
Content-Length: 251
v=0
o=- 123168982 123168983 IN IP4 192.168.15.209
s=digphn
t=0 0
a=X-nat:0
m=audio 4002 RTP/AVP 8 96
a=rtcp:4003 IN IP4 192.168.15.209
a=sendrecv
a=fmtp:96 0-15
Peer audio RTP is at port 192.168.15.209:4002
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK79f075fd
To: <sip:7071@192.168.15.209:5060;ob>;tag=vIj.WaaemCIkwLsBIjcc0xvndhCtg2UD
CSeq: 102 ACK
    -- SIP/7071-0000181f answered DAHDI/i1/1070-2ec3
Via: SIP/2.0/UDP 192.168.0.1:5060;branch=z9hG4bK23a18715;rport
CSeq: 113 NOTIFY
Event: presence
Content-Length: 530
<pp:person><status>
<tuple id="7071">
</tuple>
</presence>
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.0.1:5060;rport=5060;received=192.168.0.1;branch=z9hG4bK23a18715
CSeq: 113 NOTIFY
Paguk
Сообщение Paguk »
Прошу автора (если не секрет) выложить настройки платы Pri на
- asterisk (в виде файлов настройки (chan_dahdi.conf и system.conf))
- panasonic в виде скринов настройки платы Pri.
Проблема следующая:
- при звонках из panasonic в астериск какие-то кракозябры передаются (но это меня устраивает, меняю имя в астере)
- при звонке из астериск в panasonic передаёт только номер. (нет даже кракозяб)
Заранее спасибо...
1g0r
Сообщение 1g0r »
Paguk писал(а):Прошу автора (если не секрет) выложить настройки платы Pri на
Проблема следующая:
Заранее спасибо...
ОК. через пол часика выложу....
Панасоник CALLERID передает в Windows1251, а ваш астериск ожидает его в системной кодировке (я не знаю какая у вас UTF? KOI8R?) поэтому и кракозябры. Решается так
Set(CALLERID(name)=${ICONV(WINDOWS-1251,UTF-8,${CALLERID(name)})});
для того что бы был CALLERID при звонке необходимо сделать то что я описал в первом посте.
Если звонить с Астериска на Panasonic то системные телефоны не отображают callerid, только номер....
В трасировке PRI панасоник отправляет callerid (name) в кодировке cp1251 и с facility начинающей1ся на 0x91... Астериск же отправляет CAllerid с facility 0x9f при указанной опции switchtype=qsig.
Для исправдения ситуации пришлось модифицировать rose.c в libpri...
строка 2347...
пришлось заменить
*pos++ = 080 | Q932_PROTOCOL_EXTENSIONS;
на
*pos++ = 080 | Q932_PROTOCOL_ROSE;
после пересборки libpri проблема частично рассосалась...
Астериск стал отправлять CAllerid с правильным FACILITY, который понимает PANASONIC.
Но появилась новая трабла. Если мы с Панасоника позвоним на Астериск и когда абонент на астериске поднимет трубку то при соединении информацию о поднявшем трубку передается астериском в UTF8 и на ПАНАСОНИКЕ который работает только с cp1251 и мы получаем кракозябры.
1g0r
Сообщение 1g0r »
НЕ факт что тут все правильно но вот...
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: chan_dahdi.conf
[trunkgroups]
[channels]
language=ru
switchtype = qsig
signalling = pri_cpe
pridialplan = private
prilocaldialplan = private
mohinterpret=default
mohsuggest=default
pritimer => t303,10000
resetinterval=43200
overlapdial=no
;overlapdial=yes
priindication = inband
facilityenable = yes
usecallerid = yes
hidecallerid = no
hidecalleridname = no
callerid = asreceived
usecallingpres = yes
rxwink = 300
cidsignalling = dtmf
cidstart = ring
callwaiting = yes
callwaitingcallerid = yes
nsf = none
sendcalleridafter = 2
threewaycalling = yes
transfer = yes
canpark = yes
cancallforward = yes
callreturn = yes
echocancel = 256
echocancelwhenbridged = no
echotraining = no
relaxdtmf = yes
useincomingcalleridondahditransfer=yes
rxgain=+7.5
txgain=+7.5
callprogress=no
immediate=no
group=1
callgroup=1
context = FROM_PRI
channel => 1-15,17-31
faxdetect=no
cidsignalling=v23
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: system.conf
span=1,1,0,ccs,hdb3,crc4
bchan=1-15,17-31
dchan=16
echocanceller=mg2,1-15,17-31
loadzone=ru
defaultzone=ru
весть фокус - это переключить на панасе PRI в режим QSIG-Master
http://zamal.ru/howto/asterisk+freepbx+ ... _tda600ru/
1g0r
Сообщение 1g0r »
Где бы найти человека, который бы пропатчил libpri так что бы сообщения конвертировались самой библиотекой а не из диалплана
Paguk
Сообщение Paguk »
awsswa писал(а):весть фокус - это переключить на панасе PRI в режим QSIG-Master
так и работает...
1g0r
Сообщение 1g0r »
В этой теме, вроде бы исчерпывающая информация...
DenisNSK
Сообщение DenisNSK »
Случайно не в курсе, кто-нибудь пробовал передать CALLERID между Asterisk и HICOM (HiPath) ?
