Asterisk в роли SIP клиента
Re: Asterisk в роли SIP клиента
gofer_k писал(а):Не помогло картина та же самая
В платный суппорт.
gofer_k
Сообщение gofer_k »
server*CLI> sip set debug on
SIP Debugging enabled
<--- SIP read from UDP:ip_addr_NEC:5070 --->
INVITE sip:213@ip_addr_asterisk:5060 SIP/2.0
From: "BeloglazovAV"<sip:234@ip_addr_NEC>;tag=96B73246313536410001C245
To: <sip:213@ip_addr_asterisk>
Contact: <sip:ip_addr_NEC:5070>
Session-Expires: 180;refresher=uac
Min-SE: 180
Expires: 180
Allow: INVITE,ACK,BYE,CANCEL,PRACK,REFER,NOTIFY
Supported: 100rel,timer
Date: Wed, 11 May 2011 12:11:03 GMT
Call-ID: 01FFE492A981400000000070@ip_addr_NEC
CSeq: 1 INVITE
User-Agent: NEC-i SV8100-GE 04.00
Via: SIP/2.0/UDP ip_addr_NEC:5070;branch=z9hG4bKC3714DDB633AD713
Content-Length: 296
v=0
o=- 0 0 IN IP4 ip_addr_NEC
s=-
c=IN IP4 ip_addr_NEC_IPLA
t=0 0
m=audio 10020 RTP/AVP 8 2 18 9 96
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:2 G726-32/8000
a=ptime:30
a=rtpmap:18 G729/8000
a=ptime:20
a=rtpmap:9 G722/8000
a=ptime:30
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
--- (17 headers 16 lines) ---
Sending to ip_addr_NEC : 5070 (NAT)
Using INVITE request as basis request - 01FFE492A981400000000070@ip_addr_NEC
Found peer '213' for '234' from ip_addr_NEC:5070
<--- Reliably Transmitting (NAT) to ip_addr_NEC:5070 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP ip_addr_NEC:5070;branch=z9hG4bKC3714DDB633AD713;received=ip_addr_NEC
To: <sip:213@ip_addr_asterisk>;tag=as063fd638
CSeq: 1 INVITE
Server: Asterisk PBX 1.6.2.17
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="700abdd7"
Scheduling destruction of SIP dialog '01FFE492A981400000000070@ip_addr_NEC' in 32000 ms (Method: INVITE)
ACK sip:213@ip_addr_asterisk:5060 SIP/2.0
CSeq: 1 ACK
--- (9 headers 0 lines) ---
INVITE sip:213@ip_addr_asterisk SIP/2.0
From: "BeloglazovAV"<sip:234@ip_addr_NEC>;tag=96BC3246313536410001C246
To: <sip:213@ip_addr_asterisk:5060>
Contact: <sip:234@ip_addr_NEC:5070>
CSeq: 2 INVITE
Authorization: Digest username="",realm="asterisk",algorithm=MD5,nonce="700abdd7",opaque="",uri="sip:213@ip_addr_asterisk",response="2026e20dc1f2c7081531a934b9ea705a"
Expires: 180
Date: Wed, 11 May 2011 12:11:04 GMT
Min-SE: 180
Via: SIP/2.0/UDP ip_addr_NEC:5070;branch=z9hG4bK59B4C951767FC6EE
Content-Length: 296
v=0
s=-
t=0 0
a=ptime:20
a=ptime:30
a=ptime:20
a=ptime:30
a=fmtp:96 0-15
--- (18 headers 16 lines) ---
[2011-05-11 16:11:09] WARNING[15949]: chan_sip.c:12872 check_auth: username mismatch, have <213>, digest has <>
[2011-05-11 16:11:09] NOTICE[15949]: chan_sip.c:20235 handle_request_invite: Failed to authenticate device "BeloglazovAV"<sip:234@ip_addr_NEC>;tag=96BC3246313536410001C246
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP ip_addr_NEC:5070;branch=z9hG4bK59B4C951767FC6EE;received=ip_addr_NEC
To: <sip:213@ip_addr_asterisk:5060>;tag=as063fd638
CSeq: 2 INVITE
ACK sip:213@ip_addr_asterisk SIP/2.0
CSeq: 2 ACK
server*CLI> sip set debug off
SIP Debugging Disabled
server*CLI>
gofer_k
Сообщение gofer_k »
Ну насчет выбрасывать это вы погарячились.Что сие значит
ddkprog писал(а): Authorization: Digest username="",realm="asterisk",algorithm=MD5,nonce="700abdd7",opaque="",uri="sip:213@ip_addr_asterisk",response="2026e20dc1f2c7081531a934b9ea705a"
Наверняка на nec нужно где-то допилить это.
gofer_k
Сообщение gofer_k »
Стыковал NEC по такой же схеме с другими девайсами типа IAD и D-link да и с другими АТС все нормально звонки ходят в обе стороны.А с астериском типа
ddkprog писал(а):выбрасывайте свой NEС
:D
Исходящая связь то есть.
gofer_k
Сообщение gofer_k »
Все победил добавил в sip.conf для [213] insecure=port,invite
[213]
secret=password
username=213
host=xxx.xxx.xxx.xxx
port=5070
fromuser=213
context=incoming
gofer_k
Сообщение gofer_k »
Ну да убрал вообще secret.
gofer_k
Сообщение gofer_k »
Продолжение темы.Состыковал asterisk с операторам по sip по такой же схеме.Оператор для подключения выдал 3 акаутнта (мне непонятно только зачем если можно было через один сделать регистрация и там call лимитом к примеру ограничивать а caalerid я бы подставлял).Короче зарегистрировал эти акаунты все нормально
*CLI> sip show registry
Host                           dnsmgr Username       Refresh State                Reg.Time
10.16.18.2:5060                N      784XXXXXX1        285 Registered           Tue, 17 May 2011 16:00:20
10.16.18.2:5060                N      784XXXXXX2        285 Registered           Tue, 17 May 2011 16:00:20
10.16.18.2:5060                N      784XXXXXX3        285 Registered           Tue, 17 May 2011 16:00:20
Начал настраивать dialplan прописал правила для входящих все нормаль работает.
Теперь нужно настроить исходящую связь и тут возник вопрос каким образом сделать перебор этих sip транков то есть если к примеру 784XXXXXX1 не доступен или через него звонят то звонок шел через 784XXXXXX2 и т.д.
Сделал так
static=yes
writeprotect=no
autofallthrough=yes
clearglobalvars=no
[globals]
CONSOLE=Console/dsp
IAXINFO=guest
TRUNK=DAHDI/G2
TRUNKMSD=1
Trunk77 = SIP/784XXXXXX1
Trunk78 = SIP/784XXXXXX2
Trunk82 = SIP/7784XXXXX3
Mobile = _89XXXXXXXXX
[outgoing]
exten => ${Mobile},1,Answer
same => n,Dial(${Trunk77}/${EXTEN})
same => n,Dial(${Trunk78}/${EXTEN})
same => n,Dial(${Trunk82}/${EXTEN})
same => n,Hangup
Вроде как заработало но при такой схеме к примеру если звонишь на мобильный same => n,Dial(${Trunk77}/${EXTEN}) и на мобильном сбрасываешь, то от мобильного оператора воспроизводиться фраза типа абонент занят и т.п и далее asterisk не отбивается и преходит к следующему шагу same => n,Dial(${Trunk78}/${EXTEN}).
Записал дамп в итоге видно что при первом звонке после фразы абонент занят и т.п оператор присылает 480 Temporarily not avaible.
Короче я так понимаю нужно заставить asterisk понимать 480 или я чё то не понимаю?
Нужно не заставлять asterisk понимать 480, а описать GotoIf => Hangup.
gofer_k
Сообщение gofer_k »
Намек понял.
Погуглил и нашел похожую тему на asterisk-support
ded писал(а):
Re: Нужен обработчик hangupcause-ов для trix 2.6 /2.8
 ISUP Cause value                        SIP response
  1  unallocated number                   404 Not Found
  2  no route to network                  404 Not found
  3  no route to destination              404 Not found
  16 normal call clearing                 --- (*)
  17 user busy                            486 Busy here
  18 no user responding                   408 Request Timeout
  19 no answer from the user              480 Temporarily unavailable
  20 subscriber absent                    480 Temporarily unavailable
  21 call rejected                        403 Forbidden (+)
  22 number changed (w/o diagnostic)      410 Gone
  22 number changed (w/ diagnostic)       301 Moved Permanently
  23 redirection to new destination       410 Gone
  26 non-selected user clearing           404 Not Found (=)
  27 destination out of order             502 Bad Gateway
  28 address incomplete                   484 Address incomplete
  29 facility rejected                    501 Not implemented
  31 normal unspecified                   480 Temporarily unavailable
Q.931 cause 28 address incomplete = SIP 484 Address incomplete = AST_CAUSE_INVALID_NUMBER_FORMAT
Значит можно без AGI -
exten => s,n,NoOp(HANGUPCAUSE is ${HANGUPCAUSE})
exten => s,n,gotoif,($[${HANGUPCAUSE} = 28]?s-INVALID,1)
exten => s-INVALID,1,Playback(invalid)
Правда это надо вставлять в macro-dialout-trunk-predial-hook, потому что macro-dialout-trunk - динамический, находится в extensions_additional.conf и перепишется при первом Apply.
Сделал так:
extensions.conf
[outgoing]
same => n,NoOp(HANGUPCAUSE is ${HANGUPCAUSE})
same => n,gotoif,($[${HANGUPCAUSE} = 19]?yes:no)
same => n(yes),Congestion(5)
same => n(no),Dial(${Trunk78}/${EXTEN})
Вроде работает.
Только не понял насчет вот этого:
ded писал(а):равда это надо вставлять в macro-dialout-trunk-predial-hook, потому что macro-dialout-trunk - динамический, находится в extensions_additional.conf и перепишется при первом Apply
gofer_k писал(а):Только не понял насчет вот этого:
ded писал(а):
Бывает!
