Настройка 2-х портовой платы.
Paguk
Re: Настройка 2-х портовой платы.
Сообщение Paguk »
localhost*CLI> dahdi show status
Description Alarms IRQ bpviol CRC Fra Codi Options LBO
WCTE23X (PCI) Card 0 Span 1 LB 0 0 0 CCS HDB3 CRC4 0 db (CSU)/0-133 feet (DSX-1)
WCTE23X (PCI) Card 0 Span 2 OK 0 0 0 CCS HDB3 CRC4 0 db (CSU)/0-133 feet (DSX-1)
Опять же сам на себя.
Позвонить удаётся, но сразу отбивает.
-- Executing [6122@from-dahdiuln:6] MeetMe("DAHDI/i2/3701-1", "6122,TL(14800000:60000)") in new stack
== Parsing '/etc/asterisk/meetme.conf': Found
== Parsing '/etc/asterisk/meetme_additional.conf': Found
-- Created MeetMe conference 1023 for conference '6122'
-- Setting conference duration limit to: 14800000ms.
-- Setting warning time to 60000ms from the conference duration limit.
-- <DAHDI/i2/3701-1> Playing 'conf-onlyperson.alaw' (language 'ru')
[2014-06-05 18:26:48] WARNING[3286]: chan_sip.c:4176 retrans_pkt: Retransmission timeout reached on transmission Mzc4MDgxYTVhY2FiZGU2ZWVjZDI2MGEzZWQ1YjM3YWY. for seqno 2 (Critical Response) -- See https://wiki.asterisk.org/wiki/display/ ... nsmissions
Packet timed out after 6400ms with no response
[2014-06-05 18:26:48] WARNING[3286]: chan_sip.c:4205 retrans_pkt: Hanging up call Mzc4MDgxYTVhY2FiZGU2ZWVjZDI2MGEzZWQ1YjM3YWY. - no reply to our critical packet (see https://wiki.asterisk.org/wiki/display/ ... nsmissions).
-- Executing [h@macro-dialout-trunk:1] Macro("SIP/3701-00000005", "hangupcall,") in new stack
-- Executing [s@macro-hangupcall:1] GotoIf("SIP/3701-00000005", "1?theend") in new stack
-- Executing [s@macro-hangupcall:3] ExecIf("SIP/3701-00000005", "0?Set(CDR(recordingfile)=)") in new stack
-- Executing [s@macro-hangupcall:4] Hangup("SIP/3701-00000005", "") in new stack
== Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'SIP/3701-00000005' in macro 'hangupcall'
== Spawn extension (macro-dialout-trunk, h, 1) exited non-zero on 'SIP/3701-00000005'
-- Hungup 'DAHDI/i1/6122-1'
== Spawn extension (macro-dialout-trunk, s, 22) exited non-zero on 'SIP/3701-00000005' in macro 'dialout-trunk'
== Spawn extension (from-internal, 1996122, 5) exited non-zero on 'SIP/3701-00000005'
-- Span 2: Channel 0/1 got hangup request, cause 16
== Spawn extension (from-dahdiuln, 6122, 6) exited non-zero on 'DAHDI/i2/3701-1'
-- Hungup 'DAHDI/i2/3701-1'
1) Вам рано звонить. У вас Layer 1 даже не поднимается при тесте "сам на себя"
Статус
говорит что правильно поднялся только Span 2 - OK
2) А зачем на Meetme звонить? Разве некда больше? Эхотест например? И зачем там ещё
В платный суппорт, иначе будет ещё 5 страниц всякой ерунды.
Paguk
Сообщение Paguk »
я и сам хотел бы знать откуда берётся. и какого он таймоут этот берёт.
В диалплане ничего такого нет.
Retransmission скорее всего не относится к этому звонку, а к какой-то, видимо, SIP регистрации.
Вы книжку читали?
Paguk
Сообщение Paguk »
Прочитал всю:))
спасибо за советы. А какие есть мысли, почему плата так себя ведёт?
До этого стояла плата te121 также связь с панасоником. Никаких трабл не было, кроме отсутвия нормального эходава - но это не всегда нужно.
Мысль такая: нужно правильно сконфигурировать (выложить свой конфиг с вопросом - что у меня не так? - это уже бы-было).
Либо осмысленно, руководствуясь знаниями и мануалами, или методом тыка. Так тоже получается.
Paguk
Сообщение Paguk »
и всё-таки я её победил.
Алгоритм действия следующий:
- пересобрал астериск и dahdi из исходников.
- вместо первого порта использовал второй, (первый настроил как мастер и он не задействован)
- обновил прошивку платы pri на мини-АТС.
ИТОГ: пока работает без проблем.
