Проблема с Huawei E173
sis
Re: Проблема с Huawei E173
Сообщение sis »
Ну просто ограненное спасибо!!!!!
Решение проблемы:
Берем сборку с Digium Asteriks 11.9.0 с FreePBX (AsteriksNOW 3.0.1)
Сразу же ставим:
# yum install gcc
# yum install asterisk-devel
# cd /usr/local/src/
# wget https://github.com/jstasiak/asterisk-ch ... risk11.zip
# unzip asterisk11.zip
# cd asterisk-chan-dongle-asterisk11/
# aclocal
# autoconf
# automake -a
# ./configure
# make
# make install
# nano /etc/asterisk/dongle.conf
interval=15 ; Number of seconds between trying to connect to devices
;------------------------------ JITTER BUFFER CONFIGURATION --------------------------
;jbenable = yes ; Enables the use of a jitterbuffer on the receiving side of a
; Dongle channel. Defaults to "no". An enabled jitterbuffer will
; be used only if the sending side can create and the receiving
; side can not accept jitter. The Dongle channel can't accept jitter,
; thus an enabled jitterbuffer on the receive Dongle side will always
; be used if the sending side can create jitter.
;jbforce = no ; Forces the use of a jitterbuffer on the receive side of a Dongle
; channel. Defaults to "no".
;jbmaxsize = 200 ; Max length of the jitterbuffer in milliseconds.
;jbresyncthreshold = 1000 ; Jump in the frame timestamps over which the jitterbuffer is
; resynchronized. Useful to improve the quality of the voice, with
; big jumps in/broken timestamps, usually sent from exotic devices
; and programs. Defaults to 1000.
;jbimpl = fixed ; Jitterbuffer implementation, used on the receiving side of a Dongle
; channel. Two implementations are currently available - "fixed"
; (with size always equals to jbmaxsize) and "adaptive" (with
; variable size, actually the new jb of IAX2). Defaults to fixed.
;jbtargetextra = 40 ; This option only affects the jb when 'jbimpl = adaptive' is set.
; The option represents the number of milliseconds by which the new jitter buffer
; will pad its size. the default is 40, so without modification, the new
; jitter buffer will set its size to the jitter value plus 40 milliseconds.
; increasing this value may help if your network normally has low jitter,
; but occasionally has spikes.
;jblog = no ; Enables jitterbuffer frame logging. Defaults to "no".
[defaults]
; now you can set here any not required device settings as template
; sure you can overwrite in any [device] section this default values
context=from-pstn ; context for incoming calls
group=0 ; calling group
rxgain=0 ; increase the incoming volume; may be negative
txgain=0 ; increase the outgoint volume; may be negative
autodeletesms=yes ; auto delete incoming sms
resetdongle=yes ; reset dongle during initialization with ATZ command
u2diag=-1 ; set ^U2DIAG parameter on device (0 = disable everything except modem function) ; -1 not use ^U2DIAG command
usecallingpres=no ; use the caller ID presentation or not
callingpres=allowed_passed_screen ; set caller ID presentation by default use default network settings
disablesms=no ; disable of SMS reading from device when received
; chan_dongle has currently a bug with SMS reception. When a SMS gets in during a
; call chan_dongle might crash. Enable this option to disable sms reception.
; default = no
language=en ; set channel default language
smsaspdu=yes ; if 'yes' send SMS in PDU mode, feature implementation incomplete and we strongly recommend say 'yes'
mindtmfgap=45 ; minimal interval from end of previews DTMF from begining of next in ms
mindtmfduration=80 ; minimal DTMF tone duration in ms
mindtmfinterval=200 ; minimal interval between ends of DTMF of same digits in ms
callwaiting=auto ; if 'yes' allow incoming calls waiting; by default use network settings
; if 'no' waiting calls just ignored
disable=no ; OBSOLETED by initstate: if 'yes' no load this device and just ignore this section
initstate=start ; specified initial state of device, must be one of 'stop' 'start' 'remote'
; 'remove' same as 'disable=yes'
exten=+79255336559 ; exten for start incoming calls, only in case of Subscriber Number not available!, also set to CALLERID(ndid)
dtmf=relax ; control of incoming DTMF detection, possible values:
; off - off DTMF tones detection, voice data passed to asterisk unaltered
; use this value for gateways or if not use DTMF for AVR or inside dialplan
; inband - do DTMF tones detection
; relax - like inband but with relaxdtmf option
; default is 'relax' by compatibility reason
; dongle required settings
[MTS1] ;тут может быть любое имя хоть MEGAFON
audio=/dev/ttyUSB1 ; tty port for audio connection; no default value
data=/dev/ttyUSB2 ; tty port for AT commands; no default value
imei=352216045800436
;exten=79255336559
; if audio and data set together with imei and/or imsi audio and data has precedence
; you can use both imei and imsi together in this case exact match by imei and imsi required
Остальные настройки в web оболочке
Connectivity -> Trunk -> Add Trunk
Trunk Name: MTS1
Maximum Channels: 1
Maximum Channels: Dongle/MTS1/$OUTNUM$
Остальные настройки оставляем как есть.
Дальше создаем пользователей делаем Incoming Route и Outbound Route...
У меня была ошибка Maximum Channels: datacard/MTS1/$OUTNUM$; а надо Maximum Channels: Dongle/MTS1/$OUTNUM$ спасибо еще раз за помощь!!! Я потратил три дня с ночами для начального понимания но из за маленькой ошибки потратил более суток пока не пришел на форум... Спасибо вам, что так быстро откликнулись!!!
