Запись конференции meetme
shumiloff
Re: Запись конференции meetme
Сообщение shumiloff »
С какого-то момента перестал загружаться модуль dahdi. В чём проблема - понять не могу, так как конфиги остались такие же, как были в первом сообщении темы.
Теперь ситуация следующая:
[root@ats01:/usr/local/sbin]# dahdi_cfg -vv
DAHDI Tools Version - 2.4.0-rc1
DAHDI Version: 2.4.0-rc5
Echo Canceller(s):
Configuration
Channel map:
0 channels to configure.
При звонке:
    -- Executing [2000@office:1] Set("SIP/1020-000006d1", "MEETME_RECORDINGFILE=/home/audio/conference/2011-07-15_13-43-14") in new stack
    -- Executing [2000@office:2] NoOp("SIP/1020-000006d1", "/home/audio/conference/2011-07-15_13-43-14") in new stack
    -- Executing [2000@office:3] MeetMe("SIP/1020-000006d1", "2000,rM,555") in new stack
  == Parsing '/usr/local/etc/asterisk/meetme.conf':   == Found
[Jul 15 13:43:15] WARNING[25067]: channel.c:4324 ast_request: No channel type registered for 'DAHDI'
    -- Created MeetMe conference 1023 for conference '2000'
[Jul 15 13:43:15] WARNING[25067]: app_meetme.c:3726 find_conf: No DAHDI channel available for conference, conference recording disabled (is chan_dahdi loaded?)
    -- <SIP/1020-000006d1> Playing 'conf-onlyperson.gsm' (language 'en')
[Jul 15 13:43:17] NOTICE[25067]: rtp.c:1809 ast_rtp_read: Unknown RTP codec 126 received from '178.161.146.107'
    -- Started music on hold, class 'default', on SIP/1020-000006d1
    -- Stopped music on hold on SIP/1020-000006d1
  == Spawn extension (office, 2000, 3) exited non-zero on 'SIP/1020-000006d1'
Ну и наконец, модуль:
ats01*CLI> module show like dahdi
Module                         Description                              Use Count
chan_dahdi.so                  DAHDI Telephony Driver w/PRI             0
app_dahdibarge.so              Barge in on DAHDI channel application    0
app_dahdiras.so                DAHDI ISDN Remote Access Server          0
app_dahdiscan.so               Scan DAHDI channels application          0
codec_dahdi.so                 Generic DAHDI Transcoder Codec Translato 0
res_timing_dahdi.so            DAHDI Timing Interface                   4
6 modules loaded
ats01*CLI> dahdi
No such command 'dahdi' (type 'core show help dahdi' for other possible commands)
ats01*CLI> core show help dahdi
No such command 'dahdi'.
ats01*CLI> module load chan_dahdi.so
Unable to load module chan_dahdi.so
Command 'module load chan_dahdi.so' failed.
[Jul 15 14:33:00] WARNING[86147]: pbx.c:5129 ast_register_application2: Already have an application 'DAHDISendKeypadFacility'
  == Parsing '/usr/local/etc/asterisk/chan_dahdi.conf':   == Found
  == Parsing '/usr/local/etc/asterisk/users.conf':   == Found
[Jul 15 14:33:00] WARNING[86147]: chan_dahdi.c:2161 dahdi_open: Unable to specify channel 1: Device not configured
[Jul 15 14:33:00] ERROR[86147]: chan_dahdi.c:10420 mkintf: Unable to open channel 1: Device not configured
here = 0, tmp->channel = 1, channel = 1
[Jul 15 14:33:00] ERROR[86147]: chan_dahdi.c:16415 build_channels: Unable to register channel '1'
Странно, с учётом того, что конфиги не менялись...
Останавливаем Астериск и рестартим сервис -
service dahdi restart
Смотрим что в dmesg.
Запускаем Астериск.
Ставим вербозность пожирнее
CLI> core set verbose 10
CLI>core show channeltypes - появился chan_dahdi?
CLI>module load chan_dahdi.so
и анализируем конец /var/log/asterisk/full
shumiloff
На всякий случай
1. Склонировал сервер
2. Проверил, что на клоне симптомы не изменились.
3. Сделал апдейт и пересобрал из портов:
asterisk16-1.6.2.18
asterisk16-addons-1.6.2.3_2
dahdi-2.4.0rc5_5
dahdi-kmod-2.4.0rc5
4.
[root@ats02:/home/evgeniy]# /usr/local/etc/rc.d/asterisk stop
Stopping asterisk
[root@ats02:/home/evgeniy]# /usr/local/etc/rc.d/dahdi restart
 dahdiStarting dahdi.
[root@ats02:/home/evgeniy]# kldstat
Id Refs Address            Size     Name
 1   10 0xffffffff80100000 c9fe20   kernel
 2    1 0xffffffff80da0000 1cdc8    ipfw.ko
 3    2 0xffffffff80dbd000 141b8    libalias.ko
 4    1 0xffffffff81022000 31f6c    dahdi.ko
[root@ats02:/home/evgeniy]# ls -la /dev/dahdi/
total 1
dr-xr-xr-x  2 root  wheel       512 Jul 18 16:37 .
dr-xr-xr-x  7 root  wheel       512 Jul 18 22:36 ..
crw-rw-r--  1 root  dahdi    0, 101 Jul 19 09:24 channel
crw-rw-r--  1 root  dahdi    0,  99 Jul 19 09:24 ctl
crw-rw-r--  1 root  dahdi    0, 102 Jul 19 09:24 pseudo
crw-rw-r--  1 root  dahdi    0, 100 Jul 19 09:24 timer
[root@ats02:/home/evgeniy]# dahdi_test
Opened pseudo dahdi interface, measuring accuracy...
99.591% 99.432% 99.592% 99.592% 99.432% 99.593% 99.431% 99.593%
99.678% ^C
--- Results after 9 passes ---
Best: 99.678 -- Worst: 99.431 -- Average: 99.548197, Difference: 99.927085
При рестарте dahdi в dmesg имеем следующее:
dahdi: Telephony Interface Unloaded
Warning: memory type dahdi leaked memory on destroy (1 allocations, 256 bytes leaked).
dahdi: Telephony Interface Registered on major 196
dahdi: Version: 2.4.0-rc5
dahdi: Registered tone zone 0 (United States / North America)
5. Запускаем астериск, смотрим симптомы:
[root@ats02:/home/evgeniy]# /usr/local/etc/rc.d/asterisk start
Starting asterisk.
[root@ats02:/home/evgeniy]# asterisk -r
Asterisk 1.6.2.18, Copyright (C) 1999 - 2010 Digium, Inc. and others.
Created by Mark Spencer <markster@digium.com>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
Connected to Asterisk 1.6.2.18 currently running on ats02 (pid = 62862)
ats02*CLI> core set verbose 10
Verbosity was 0 and is now 10
ats02*CLI> core show channeltypes
Type        Description                              Devicestate  Indications  Transfer
Local       Local Proxy Channel Driver               yes          yes          no
MGCP        Media Gateway Control Protocol (MGCP)    yes          yes          no
Console     OSS Console Channel Driver               no           yes          no
Agent       Call Agent Proxy Channel                 yes          yes          no
Gtalk       Gtalk Channel Driver                     no           yes          no
Bridge      Bridge Interaction Channel               no           no           no
SIP         Session Initiation Protocol (SIP)        yes          yes          yes
IAX2        Inter Asterisk eXchange Driver (Ver 2)   yes          yes          yes
Skinny      Skinny Client Control Protocol (Skinny)  yes          yes          no
Jingle      Jingle Channel Driver                    no           yes          no
10 channel drivers registered.
ats02*CLI> module load chan_dahdi.so
Command 'module load chan_dahdi.so ' failed.
[Jul 19 09:36:11] WARNING[62862]: pbx.c:5132 ast_register_application2: Already have an application 'DAHDISendKeypadFacility'
[Jul 19 09:36:11] WARNING[62862]: chan_dahdi.c:2169 dahdi_open: Unable to specify channel 1: Device not configured
[Jul 19 09:36:11] ERROR[62862]: chan_dahdi.c:10502 mkintf: Unable to open channel 1: Device not configured
[Jul 19 09:36:11] ERROR[62862]: chan_dahdi.c:16647 build_channels: Unable to register channel '1'
По всей видимости, логирование у меня настроено как-то иначе на FreeBSD.
[evgeniy@ats02:~]> cd /var/log/asterisk/
[evgeniy@ats02:/var/log/asterisk]> find .
./cdr-csv
./cdr-csv/Master.csv
./cdr-custom
./messages
./event_log
./queue_log
./master.db
./cdr.db
Подозреваю, что full - это аналог моего messages. В messages появилось следующее:
[Jul 19 09:36:11] WARNING[62862] pbx.c: Already have an application 'DAHDISendKeypadFacility'
[Jul 19 09:36:11] WARNING[62862] chan_dahdi.c: Unable to specify channel 1: Device not configured
[Jul 19 09:36:11] ERROR[62862] chan_dahdi.c: Unable to open channel 1: Device not configured
[Jul 19 09:36:11] ERROR[62862] chan_dahdi.c: Unable to register channel '1'
Прозвучало ключевое слово
на FreeBSD.
. Даже не знаю что сказать.
Aven
Сообщение Aven »
Тоже сочувствую по этому поводу.
mxr
Сообщение mxr »
Ну что господа не осилили такую простую и логичную систему как freebsd? И теперь у вас реакция на красный цвет. Ну что ж могу только посочувствовать вам.
shumiloff
Кстати, разрулил проблему через ConfBridge и MixMonitor. Жду выхода 1.10, там уже будет нормальный модуль для конференций, который судя по описанию, будет работать из коробки и без танцев с бубном.
Что тут осиливать , если человек пытается работать с модулем ядра , который не описан в файле system.conf в папке /usr/local/etc/dahdi/ . Вывод dahdi_cfg это подтверждает.
ys1797
Сообщение ys1797 »
А где dahdi_dummy ?
dahdi.ko сам по себе ничего делать не будет, это прослой между asterisk, железячными модулями, и эходавами.
Ну может у него там карточка потоковая , откуда нам знать. Автор надеется на телепатов.
