cisco 1750 + asterisk
natrox
Re: cisco 1750 + asterisk
Сообщение natrox »
Изменил настройки циски, теперь звонок приходит на циску, но до астериска не доходит. Где я ошибся?
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: cisco conf
version 12.3
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname VGate
boot-start-marker
boot-end-marker
logging cns-events debugging
memory-size iomem 25
clock timezone IRKT 9
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
aaa new-model
aaa session-id common
ip subnet-zero
ip cef
ip name-server 91.219.136.4
ip name-server 91.219.137.4
no ftp-server write-enable
voice echo-canceller extended
voice rtp send-recv
voice service pots
supported-language ru
voice service voip
fax protocol pass-through g711alaw
sip
bind all source-interface FastEthernet0
min-se 60
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class busyout 1
voice class dualtone-detect-params 1
cadence-variation 50
voice class custom-cptone RU
dualtone busy
frequency 570 640
cadence 500 500
voice translation-profile VoiceTraPro
gw-accounting aaa
ip address 192.168.128.73 255.255.255.0
speed auto
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip default-gateway 192.168.128.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.128.1
no ip http server
voice-port 1/0
no comfort-noise
cptone RU
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 1300
timing digit 200
timing inter-digit 200
timing guard-out 500
connection plar 5001
supervisory disconnect dualtone mid-call
supervisory dualtone-detect-params 1
no battery-reversal
voice-port 1/1
no comfort-noise
cptone RU
timing digit 200
connection plar 5002
no battery-reversal
mgcp
dial-peer voice 1 pots
destination-pattern .T
no digit-strip
direct-inward-dial
port 1/0
forward-digits 0
ial-peer voice 2 pots
no digit-strip
direct-inward-dial
port 1/1
forward-digits 0
dial-peer voice 10 voip
huntstop
destination-pattern 5T
progress_ind setup enable 3
voice-class sip url sip
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
codec g711alaw
no vad
sip-ua
calling-info sip-to-pstn name set SIPTOPSTN
max-forwards 15
codec g711alaw
no vad
sip-ua
max-forwards 15
sip-server ipv4:91.219.137.26:5060
line con 0
line aux 0
line vty 0 4
exec-timeout 60 0
logging synchronous
transport input telnet
no scheduler allocate
ntp master 3
ntp server 192.168.128.6 source FastEthernet0
end
Вот что показывает debug ccsip all. Честно скажу, дебаг для меня темный лес. Как понимаю проблема указана тут: "SIP/2.0 401 Unauthorized"
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: debug ccsip all
05:39:20: 0x826B3BE0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
05:39:20: adding call id 48 to table
05:39:20: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
05:39:20: CCSIP-SPI-CONTROL: act_idle_call_setup
05:39:20: act_idle_call_setup:Not using Voice Class Codec
05:39:20: act_idle_call_setup: preferred_codec set[0] type :g711alaw bytes: 160
05:39:20: sipSPICopyPeerDataToCCB: From CLI: Modem NSE payload = 100, Passthroug
h = 0,Modem relay = 0, Gw-Xid = 1
SPRT latency 200, SPRT Retries = 12, Dict Size = 1024
String Len = 32, Compress dir = 3
05:39:20: sipSPIValidateGtd: Signal Forward disabled
05:39:20: sipSPICanSetFallbackFlag - Local Fallback is not active
05:39:20: Queued event from SIP SPI : SIPSPI_EV_CREATE_CONNECTION
05:39:20: 0x826B3BE0 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_CONNECTING)
05:39:20: 0x826B3BE0 : State change from (STATE_IDLE, SUBSTATE_CONNECTING) to (STATE_IDLE, SUBSTATE_CONNECTING)
05:39:20: sipSPIUsetBillingProfile: sipCallId for billing records =
05:39:20: ****Adding to UAC table. ccb=0x826B3BE0 key=8572186C-F88411E3-8091BD2C
-C0A5147F@192.168.128.73
05:39:20: CCSIP-SPI-CONTROL: act_idle_connection_created
05:39:20: CCSIP-SPI-CONTROL: act_idle_connection_created: Connid(1) created to
91.219.137.26:5060, local_port 50689
05:39:20: CCSIP-SPI-CONTROL: sipSPIOutgoingCallSDP
05:39:20: sipSPISetMediaSrcAddr: media src addr for stream 1 = 192.168.128.73
05:39:20: sipSPIReserveRtpPort: reserved port 18492 for stream 1
05:39:20: Preferred method of dtmf relay is: 6, with payload : 101
05:39:20: convert_codec_bytes_to_ptime: Values :Codec: g711alaw codecbytes :160, ptime: 20
05:39:20: sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
05:39:20: CCSIP-SPI-CONTROL: Converting TimeZone IRKT to SIP default timezone = GMT
05:39:20: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
05:39:20: sipSPIAddLocalContact
05:39:20: Queued event from SIP SPI : SIPSPI_EV_SEND_MESSAGE
05:39:20: sip_stats_method
05:39:20: sipSPIProcessRtpSessions
05:39:20: sipSPIAddStream: Adding stream 1 (callid 72) to the VOIP RTP library
05:39:20: sipSPIUpdateRtcpSession: for m-line 1
05:39:20: sipSPIUpdateRtcpSession: rtcp_session info
laddr = 192.168.128.73, lport = 18492, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 72, dest_callid = -1, stream type = 1
05:39:20: sipSPIUpdateRtcpSession: No rtp session, creating a new one
05:39:20: sipSPIAddStream: AddStream in idle state to open a 'recvonly' media session
05:39:20: act_idle_connection_created: Transaction active. Facilities will be queued.
05:39:20: 0x826B3BE0 : State change from (STATE_IDLE, SUBSTATE_CONNECTING) to (STATE_SENT_INVITE, SUBSTATE_NONE)
05:39:20: Sent:
INVITE sip:5002@91.219.137.26:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.128.73:5060
To: <sip:5002@91.219.137.26>
Date: Sat, 21 Jun 2014 14:09:40 GMT
Call-ID: 8572186C-F88411E3-8091BD2C-C0A5147F@192.168.128.73
Supported: timer,100rel
Min-SE: 60
Cisco-Guid: 2238607076-4169404899-2156838188-3232044159
User-Agent: Cisco-SIPGateway/IOS-12.x
Accept-Language: ru
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO
CSeq: 101 INVITE
Max-Forwards: 15
Remote-Party-ID: <sip:192.168.128.73>;party=calling;screen=no;privacy=off
Timestamp: 1403359780
Contact: <sip:192.168.128.73:5060>
Expires: 180
Allow-Events: telephone-event
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 4417 4004 IN IP4 192.168.128.73
s=SIP Call
c=IN IP4 192.168.128.73
t=0 0
m=audio 18492 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=ptime:20
05:39:20: Received:
Via: SIP/2.0/UDP 192.168.128.73:5060;received=192.168.128.73;rport=50689
To: <sip:5002@91.219.137.26>;tag=as0db22b12
CSeq: 101 INVITE
Server: Asterisk PBX 11.5.0
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="67d59dc0"
05:39:20: HandleUdpSocketReads :Msg enqueued for SPI with IPaddr: 91.219.137.26:5060
05:39:20: CCSIP-SPI-CONTROL: act_sentinvite_new_message
05:39:20: CCSIP-SPI-CONTROL: sipSPICheckResponse
05:39:20: sip_stats_status_code
05:39:20: Roundtrip delay 24 milliseconds for method INVITE
05:39:20: ccsip_set_release_source_for_peer:ownCallId[72], src[4]
05:39:20: CCSIP-SPI-CONTROL: sipSPIInitiateCallDisconnect : Initiate call disconnect(57) for outgoing call
05:39:20: 0x826B3BE0 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
05:39:20: Sent:
ACK sip:5002@91.219.137.26:5060 SIP/2.0
Max-Forwards: 15
CSeq: 101 ACK
05:39:20: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
05:39:20: CCSIP-SPI-CONTROL: act_disconnecting_disconnect
05:39:20: CCSIP-SPI-CONTROL: sipSPICallCleanup
05:39:20: sipSPIIcpifUpdate :CallState: 2 Playout: 0 DiscTime:2036083 ConnTime 0
05:39:20: 0x826B3BE0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
05:39:20: The Call Setup Information is :
Call Control Block (CCB) : 0x826B3BE0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number :
Called Number : 5002
Number of Media Streams : 1
05:39:20: Media Stream 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0
Source IP Address (Media): 192.168.128.73
Source IP Port (Media): 18492
Destn IP Address (Media): 0.0.0.0
Destn IP Port (Media): 0
05:39:20: Orig Destn IP Address:Port (Media): 0.0.0.0:0
05:39:20:
Source IP Address (Sig ): 192.168.128.73
Destn SIP Req Addr:Port : 91.219.137.26:5060
Destn SIP Resp Addr:Port : 0.0.0.0:0
Destination Name : 91.219.137.26
05:39:20:
Disconnect Cause (CC) : 57
Disconnect Cause (SIP) : 401
05:39:20: ****Deleting from UAC table. ccb=0x826B3BE0 key=8572186C-F88411E3-8091BD2C-C0A5147F@192.168.128.73
05:39:20: Removing call id 48
05:39:20: RequestCloseConnection: Closing connid 1 Local Port 50689
05:39:20: Queued event from SIP SPI : SIPSPI_EV_CLOSE_CONNECTION
05:39:20: sipSPIFlushEventBufferQueue: There are 0 events on the internal queue
that are going to be free'd
05:39:20: freeing ccb 826B3BE0
05:39:20: udpsock_close_connect: Socket fd: 1 closed for connid 1 with remote port: 5060
Ах да, sip.conf на астериске изменил
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: sip.conf
[cisco]
directmedia=no
context=from-fxo
dtmfmode=info
host=192.168.128.73
permit=0.0.0.0/0.0.0.0
call-limit=4
canreinvite=no
;allow=gsm
natrox
Сообщение natrox »
Нашел вот тут http://wiki.sipnet.ru/index.php/SIP_%D0 ... 0%B8%D1%8F
SIP/2.0 401 Unauthorized - нормальный ответ сервера о том, что пользователь еще не авторизировался; обычно после этого абонентское оборудование отправляет на сервер новый запрос, содержащий логин и пароль
Т.е. при подключении циски к астериску необходима авторизация? Что-то я запутался. Ни в одном конфиге такого не помню...
natrox писал(а):Необходимо обладать и понимать. А Вы, как я понимаю, с рождения с этими знаниями? Не нужно думать что я не пытаюсь сам разобраться. Я не рассчитываю что за меня тут все сделают, прошу лишь помочь советом.
Совет: продолжайте разбираться. Ещё совет: меньше писать, больше читать. А то много пороху уходит на волнообразование. Когда-то этих знаний в интернете не было, и форумов тоже, только иностранные чаты и листы подписки, и тогда было больше надежды на себя, а не на сообщество.
natrox писал(а):Изменил настройки циски, теперь звонок приходит на циску, но до астериска не доходит. Где я ошибся?
Найти где ошибся.
Авторизация по user name & secret не нужна, если цыска и астериск в одной подсети.
natrox
Сообщение natrox »
:-) спасибо на добром слове товарищ дед! Конечно я попробую разобраться сам, только этим и занимаюсь. Просто если есть возможность сократить затрачиваемое время, это было бы плюсом огромным. По результатам отпишусь, может кому полезно будет.
Aven
Сообщение Aven »
Вы бы хоть советы читали...
natrox
Сообщение natrox »
Будьте уверены, читаю все что мне пишут :-)
natrox
Сообщение natrox »
Попробовал сделать настройку по этому примеру http://asterisk-support.ru/forum/topics/5843/
При попытке сделать звонок на свой номер, идет сначала один длинный гудок, за тем несколько коротких и после этого вызов завершается. В логе Asterisk ничего не появляется.
version 12.3
hostname VGate
boot-start-marker
boot-end-marker
no mmi pvc
aaa new-model
ip subnet-zero
ip cef
voice rtp send-recv
voice service pots
voice service voip
sip
min-se 60
voice class codec 1
codec preference 3 g729br8
dualtone busy
frequency 570 640
cadence 500 500
gw-accounting aaa
speed auto
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip classless
no ip http server
voice-port 1/0
input gain 5
no comfort-noise
cptone RU
timing digit 200
no battery-reversal
voice-port 1/1
input gain 5
no comfort-noise
cptone RU
timing digit 200
no battery-reversal
mgcp
dial-peer voice 100 pots
no digit-strip
direct-inward-dial
port 1/0
forward-digits 0
dial-peer voice 101 pots
no digit-strip
direct-inward-dial
port 1/1
forward-digits 0
dial-peer voice 102 pots
destination-pattern ..........
port 1/0
prefix 9,,
dial-peer voice 103 pots
description 10-num outgoing port1/1
port 1/1
prefix 9,,
dial-peer voice 110 pots
port 1/0
prefix 9,,
dial-peer voice 111 pots
port 1/1
prefix 9,,
dial-peer voice 200 voip
description INBOUND-TO-ASTERISK
huntstop
dtmf-relay rtp-nte
codec g711alaw
no vad
sip-ua
max-forwards 15
line con 0
line aux 0
line vty 0 4
exec-timeout 60 0
password password
absolute-timeout 90
logging synchronous
line vty 5 15
absolute-timeout 90
logging synchronous
ntp clock-period 17180042
ntp master 3
end
Уже все что можно перепроверил, не вижу проблему и все тут. Через D'Link все работает, а через Cisco не хочет :(
natrox писал(а): А Вы, как я понимаю, с рождения с этими знаниями?
а) Ко мне можно на "ТЫ", я не гордый.
б ) нет, не с рождения. долго и много читал тех.литературу, ибо имею привычку сначала изучать, а потом настраивать, а не наоборот
в) и вообще я не понял к чему такая реакция. я лишь ответил на сообщение, ответил что нужно делать
natrox писал(а):Просто если есть возможность сократить затрачиваемое время, это было бы плюсом огромным
Т.е. нам предлагается затратить свое время, чтобы сократить твое ?
natrox писал(а): Конечно я попробую разобраться сам
Это конечно радует, но:
  • - где схема ?
    - где описание кто как и к кому подключен ?
    - где внятное описание того кто и кому звонит ?
    - где дебаг с астериска ? sip debug или tcpdump ?
    - и т.п.
Ведь внятное объяснение проблемы, это уже как минимум 50% её решения.
Так же копипаст чужих конфигов не засчитывается за попытку самостоятельно разобраться.
Затем:
natrox писал(а):При попытке сделать звонок на свой номер
Т.е. мы по дефолту должны понимать какой это номер ? Лишь по приведенному выше дебагу вызова с cisco, можно предположить что это номер 5002. Нам нужно гадать ?
Но дебаг был в другом сообщении и не факт что в этом сообщении звонок совершался так же. Т.е. опять не удосужились написать откуда и куда совершался вызов. Нам опять посидеть погадать ?
Лично мне играть в догадалки не хочется, этого "добра" мне с моими клиентами хватает.
natrox писал(а):Попробовал сделать настройку по этому примеру
Бездумный копипаст приведет только к одному - проблемам. Примеры это лишь примеры и это не означает что приведенный в примере конфиг подойдет к вашему случаю. Необходимо не копипастить конфиг, а взять литературу и понять, если необходимо построчно, что он означает.
Это была лирика, а теперь потрачу время на ответ по сабжу.
Cisco: 192.168.128.73
Asterisk: 91.219.137.26
Отсюда вопрос: Cisco за NAT`ом ?
Далее следует вопрос: Так как все же планируется совершать вызовы с Cisco на Asterisk ? С регистрацией или без оной ? (опять же это вопрос планируемой схемы)
Затем:
Это было прочитано ?
Можно самому ответить на этот вопрос исходя из постов ТС и ответ будет: Нет, даже не открывался.
Отсюда другой вопрос: Понятие "пытаюсь разобраться сам" теперь означает только "копирую разнообразные кофиги с форумов" ? Так что ли ?
Далее:
show dialplan number 5002
debug ccsip all
sip set debug peer cisco
Это можно считать советами ? Или нужно "водить за ручку" ?
natrox
Сообщение natrox »
В общем последовал вашему совету. Удалил весь конфиг и сделал все заново, но без копипаса. Проблема осталась таже. Вот такой получился конфиг:
version 12.3
hostname VGate
boot-start-marker
boot-end-marker
no mmi pvc
aaa new-model
ip subnet-zero
ip cef
voice rtp send-recv
voice service pots
voice service voip
sip
min-se 60
voice class codec 1
dualtone busy
frequency 570 640
cadence 500 500
gw-accounting aaa
speed auto
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip classless
no ip http server
voice-port 1/0
no comfort-noise
cptone RU
timeouts interdigit 2
connection plar opx 5001
description 5001
no battery-reversal
voice-port 1/1
no comfort-noise
cptone RU
connection plar opx 5002
description 5002
no battery-reversal
mgcp
dial-peer voice 1 voip
description to_asterisk
preference 2
destination-pattern 500[12]
session target ipv4:91.219.137.26:5060
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 6001 pots
description to_fxo_pstn
preference 7
progress_ind disconnect enable 8
port 1/0
dial-peer voice 6002 pots
preference 7
port 1/1
sip-ua
max-forwards 15
line con 0
line aux 0
line vty 0 4
exec-timeout 60 0
password password
absolute-timeout 90
logging synchronous
line vty 5 15
absolute-timeout 90
logging synchronous
ntp master 3
end
Посмотрел хорошо дебаг циски и кое что понял. Понял что именно в астериске дело. Сделал вот такой сип:
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: cisco sip
[cisco]
directmedia=no
insecure=port,invite
context=from-fxo
dtmfmode=rfc2833
host=192.168.128.73
call-limit=4
canreinvite=no
;allow=gsm
Звонки идут нормально, но номер не определяется. Вместо CallerID(num) возвращает пустое значение. Что посоветуете почитать? :D
