Имена для входящих вызовов.
nickel82
Re: Имена для входящих вызовов.
Сообщение nickel82 »
проблема таже самая!
все это уже проделывал не помогает!
плиз хелп!
система:
Elastix
elastix 2.0.4 15
elastix-agenda 2.0.4 7
elastix-email_admin 2.0.4 10
elastix-addons 2.0.4 6
elastix-a2billing 1.3.0 4
elastix-my_extension 2.0.4 5
elastix-pbx 2.0.4 15
elastix-security 2.0.4 11
elastix-reports 2.0.4 8
elastix-vtigercrm 5.1.0 8
elastix-asterisk-sounds 1.2.3 1
elastix-firstboot 2.0.4 5
elastix-fax 2.0.4 5
elastix-system 2.0.4 9
Name Package Name Version Release
RounCubeMail
RoundCubeMail 0.3.1 7
Mail
postfix 2.3.3 2.1.el5_2
cyrus-imapd 2.3.7 7.el5_4.3
IM
openfire 3.5.1 3
FreePBX
freePBX 2.8.0 1
Asterisk
asterisk 1.6.2.16.1 0
asterisk-perl 0.10 2
asterisk-addons 1.6.2.2 0
FAX
hylafax 4.3.9 0rhel5
iaxmodem 1.2.0 1.1
DRIVERS
dahdi 2.4.0 1
rhino 0.99.4 0.rc1
wanpipe-util 3.5.18 1
Вот лог звонка:
== Using SIP RTP TOS bits 184
-- Executing [7199@from-internal:1] Macro("SIP/TrixBox1-0000004e", "exten-vm,novm,7199") in new stack
-- Executing [s@macro-exten-vm:1] Macro("SIP/TrixBox1-0000004e", "user-callerid,") in new stack
-- Executing [s@macro-user-callerid:1] Set("SIP/TrixBox1-0000004e", "AMPUSER=4230") in new stack
-- Executing [s@macro-user-callerid:2] GotoIf("SIP/TrixBox1-0000004e", "0?report") in new stack
-- Executing [s@macro-user-callerid:3] ExecIf("SIP/TrixBox1-0000004e", "1?Set(REALCALLERIDNUM=4230)") in new stack
-- Executing [s@macro-user-callerid:4] Set("SIP/TrixBox1-0000004e", "AMPUSER=") in new stack
-- Executing [s@macro-user-callerid:5] Set("SIP/TrixBox1-0000004e", "AMPUSERCIDNAME=") in new stack
-- Executing [s@macro-user-callerid:6] GotoIf("SIP/TrixBox1-0000004e", "1?report") in new stack
-- Goto (macro-user-callerid,s,10)
-- Executing [s@macro-user-callerid:10] GotoIf("SIP/TrixBox1-0000004e", "0?continue") in new stack
-- Executing [s@macro-user-callerid:11] Set("SIP/TrixBox1-0000004e", "__TTL=64") in new stack
-- Executing [s@macro-user-callerid:12] GotoIf("SIP/TrixBox1-0000004e", "1?continue") in new stack
-- Executing [s@macro-user-callerid:19] Set("SIP/TrixBox1-0000004e", "CALLERID(number)=4230") in new stack
-- Executing [s@macro-user-callerid:20] Set("SIP/TrixBox1-0000004e", "CALLERID(name)=4230") in new stack
-- Executing [s@macro-user-callerid:21] NoOp("SIP/TrixBox1-0000004e", "Using CallerID "4230" <4230>") in new stack
-- Executing [s@macro-exten-vm:2] Set("SIP/TrixBox1-0000004e", "RingGroupMethod=none") in new stack
-- Executing [s@macro-exten-vm:3] Set("SIP/TrixBox1-0000004e", "VMBOX=novm") in new stack
-- Executing [s@macro-exten-vm:4] Set("SIP/TrixBox1-0000004e", "__EXTTOCALL=7199") in new stack
-- Executing [s@macro-exten-vm:5] Set("SIP/TrixBox1-0000004e", "CFUEXT=") in new stack
-- Executing [s@macro-exten-vm:6] Set("SIP/TrixBox1-0000004e", "CFBEXT=") in new stack
-- Executing [s@macro-exten-vm:7] Set("SIP/TrixBox1-0000004e", "RT=""") in new stack
-- Executing [s@macro-exten-vm:8] Macro("SIP/TrixBox1-0000004e", "record-enable,7199,IN") in new stack
-- Executing [s@macro-record-enable:1] GotoIf("SIP/TrixBox1-0000004e", "1?check") in new stack
даже нет попытки его запустить!
во входящей маршрутизации "источник " стоит.
пробывал даже "CID Superfecta" - дебаг на модуле проходит на ура, а на звонок ни как не хочит ципляться!
слезно прошу ХЕЛППП!
Вы с внутреннего номера "AMPUSER=4230" набираете 7199
Звонок вообще не проходит через обработку входящей маршрутизации, где, собственно, и может происходить CID lookup.
nickel82
как прописать чтоб с локальной АТС шла обработка CID lookup.
суть: сеть АТС аналоговых. по потоку подключиль к Elastix. нодо чтоб из базы тел № выхватывало имена.
Подключайте поток в Астериск, а оттуда тем же потоком - в вашу АТС.
Тогда есть возможность обрабатывать входящие для поиска CallerID lookup.
nickel82
потоком и подключено!
контекст стоит from-internal
его наверно надо перевести from-pstn
Разумеется.
nickel82
dahdi-channels.conf
; Span 1: TE2/0/1 "T2XXP (PCI) Card 0 Span 1" (MASTER)
group=0,11
context=from-internal
switchtype = qsig
signalling = pri_cpe
channel => 1-15,17-31
context = default
group = 63
from-pstn не помогло!
nickel82
на группы вообще звонок не проходит!
на номера все так же!
Обратитесь с системному администратору?
nickel82
это вопрос или утверждение?
