Не вижу астериск на фаерволе
zeone
Re: Не вижу астериск на фаерволе
Сообщение zeone »
Вот такой лог получаю, ничего понять не могу, по логу ип, вроде как нормально, но по логу звонка лажа 8(
Лог вызова:
  == Using SIP RTP TOS bits 184
    -- Executing [90937454951@from-internal:1] ResetCDR("SIP/300-0000001d", "") in new stack
    -- Executing [90937454951@from-internal:2] NoCDR("SIP/300-0000001d", "") in new stack
    -- Executing [90937454951@from-internal:3] Progress("SIP/300-0000001d", "") in new stack
    -- Executing [90937454951@from-internal:4] Wait("SIP/300-0000001d", "1") in new stack
    -- Executing [90937454951@from-internal:5] Progress("SIP/300-0000001d", "") in new stack
    -- Executing [90937454951@from-internal:6] Playback("SIP/300-0000001d", "silence/1&cannot-complete-as-dialed&check-number-dial-again,noanswer") in new stack
    -- <SIP/300-0000001d> Playing 'silence/1.gsm' (language 'en')
    -- <SIP/300-0000001d> Playing 'cannot-complete-as-dialed.gsm' (language 'en')
    -- <SIP/300-0000001d> Playing 'check-number-dial-again.gsm' (language 'en')
    -- Executing [90937454951@from-internal:7] Wait("SIP/300-0000001d", "1") in new stack
    -- Executing [90937454951@from-internal:8] Congestion("SIP/300-0000001d", "20") in new stack
  == Spawn extension (from-internal, 90937454951, 8) exited non-zero on 'SIP/300-0000001d'
    -- Executing [h@from-internal:1] Macro("SIP/300-0000001d", "hangupcall") in new stack
    -- Executing [s@macro-hangupcall:1] GotoIf("SIP/300-0000001d", "1?endmixmoncheck") in new stack
    -- Executing [s@macro-hangupcall:9] NoOp("SIP/300-0000001d", "End of MIXMON check") in new stack
    -- Executing [s@macro-hangupcall:10] GotoIf("SIP/300-0000001d", "1?nomeetmemon") in new stack
    -- Goto (macro-hangupcall,s,28)
    -- Executing [s@macro-hangupcall:28] NoOp("SIP/300-0000001d", "End of MEETME check") in new stack
    -- Executing [s@macro-hangupcall:29] GotoIf("SIP/300-0000001d", "1?noautomon") in new stack
    -- Goto (macro-hangupcall,s,34)
    -- Executing [s@macro-hangupcall:34] NoOp("SIP/300-0000001d", "TOUCH_MONITOR_OUTPUT=") in new stack
    -- Executing [s@macro-hangupcall:35] GotoIf("SIP/300-0000001d", "1?noautomon2") in new stack
    -- Goto (macro-hangupcall,s,41)
    -- Executing [s@macro-hangupcall:41] NoOp("SIP/300-0000001d", "MONITOR_FILENAME=") in new stack
    -- Executing [s@macro-hangupcall:42] GotoIf("SIP/300-0000001d", "1?skiprg") in new stack
    -- Goto (macro-hangupcall,s,45)
    -- Executing [s@macro-hangupcall:45] GotoIf("SIP/300-0000001d", "1?skipblkvm") in new stack
    -- Goto (macro-hangupcall,s,48)
    -- Executing [s@macro-hangupcall:48] GotoIf("SIP/300-0000001d", "1?theend") in new stack
    -- Goto (macro-hangupcall,s,50)
    -- Executing [s@macro-hangupcall:50] AGI("SIP/300-0000001d", "hangup.agi") in new stack
    -- Launched AGI Script /var/lib/asterisk/agi-bin/hangup.agi
    -- <SIP/300-0000001d>AGI Script hangup.agi completed, returning 0
    -- Executing [s@macro-hangupcall:51] Hangup("SIP/300-0000001d", "") in new stack
  == Spawn extension (macro-hangupcall, s, 51) exited non-zero on 'SIP/300-0000001d' in macro 'hangupcall'
  == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/300-0000001d'
Дебаг ип провайдера
Reliably Transmitting (NAT) to 193.138.185.238:5060:
OPTIONS sip:193.138.185.238 SIP/2.0
Via: SIP/2.0/UDP 94.45.41.14:5060;branch=z9hG4bK6106897c;rport
From: "Unknown" <sip:3511977@94.45.41.14>;tag=as522bf42d
To: <sip:193.138.185.238>
Contact: <sip:3511977@94.45.41.14:5060>
Call-ID: 2bc93fde55003dc85bfe593c18ca1231@94.45.41.14:5060
CSeq: 102 OPTIONS
User-Agent: FPBX-2.8.1(1.8.20.0)
Date: Wed, 09 Oct 2013 11:57:10 GMT
<--- SIP read from UDP:193.138.185.238:5060 --->
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.2.107:5060;branch=z9hG4bK6106897c;received=192.168.2.107;rport=5060
From: "Unknown" <sip:3511977@192.168.2.107:5060>;tag=as522bf42d
To: <sip:193.138.185.238>;tag=as2db93d72
CSeq: 102 OPTIONS
Server: FPBX-2.11.0(10.12.0)
Contact: <sip:193.138.185.238:5060>
Accept: application/sdp
--- (12 headers 0 lines) ---
Really destroying SIP dialog '2bc93fde55003dc85bfe593c18ca1231@94.45.41.14:5060' Method: OPTIONS
Что самое интересное, когда набираю пытаюсь позвонить то слышу просто тишину, ни гудков, ничего помолчало и вырубило
У Вас нет исходящего мершрута или он неверный.
ИП лог провайдера - ничто, это пакеты OPTIONS, которыми обмениваются РВХ и SIP устройства, типа nat keepalive, только с другой стороны.
zeone писал(а):Что самое интересное, когда набираю пытаюсь позвонить то слышу просто тишину, ни гудков, ничего помолчало и вырубило
Вы уж простите за прямоту - это совершенно не интересно. То же самое будет, например, если Вы попытаетесь что-то проговорить в подушку.
Вам бы разобраться лучше почему Вы не слышите голосовые сообщения -
zeone
Сообщение zeone »
я сообщения слышу, молчание было в мобильном телефоне, простите что не конкретизировал
monstr
Сообщение monstr »
Вы по схеме прошлись которая Выше приложена?
Давайте Ваш диалплан сюда.
1) У него freepbx
2) у него нет исходящего мершрута или он неверный.
zeone
Сообщение zeone »
Прошелся но потерялся на том что делать дальше, в логах не вижу за что зацепится 8(
вот что интересно:
localhost*CLI> sip show registry
Host                                    dnsmgr Username       Refresh State                Reg.Time
193.138.185.238:5060                    N      3511977            120 No Authentication
1 SIP registrations.
Так как новичек не уверен что такое диал план думаю это:
host=193.138.__.__
username=35_____7
secret=R______7
fromuser=3______7
fromdomain=3_____7
1)да
2) есть но не уверен что правильный
исходящий сид: номер_телефона
префикс: 9
транк: тот который на мир смотрит
Даже не заглядывая в ваши шаблоны номеров: ваш транк не зарегистрирован, не аутентифицирутется.
при это Вы зачем то пытетесь тут же этот адрес киевского провайдера SilverTelecom скрыть:
host=193.138.__.__
Давайте так: провайдеру платите - он и настривает, или помогает, или платит нам, если заинтересован в аутсорсе. Ибо на всех провайдеров рекомендаций не напасёшься.
zeone
Сообщение zeone »
Да с шифрованостю тупонул 8)
Провайдер молодец просто, я за весь день к нему дозвонится не могу просто морозится 8)
fromdomain=193.138.185.238
и накой пытаться шифровать IP оператора?
боитесь что его взломают?
zeone
Сообщение zeone »
Не, боялся что засвечу пароль и кто то менее криворукий настроит для себя 8)
Вот еще какой то интересный лог пришел
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: лог
Really destroying SIP dialog '690e277c0f75005641fea9ff48a3fec9@МОЙ_ИП:5060' Method: OPTIONS
    -- Executing [00972592594535@from-sip-external:1] NoOp("SIP/192.168.2.107-00000035", "Received incoming SIP connection from unknown peer to 00972592594535") in new stack
    -- Executing [00972592594535@from-sip-external:2] Set("SIP/192.168.2.107-00000035", "DID=00972592594535") in new stack
    -- Executing [00972592594535@from-sip-external:3] Goto("SIP/192.168.2.107-00000035", "s,1") in new stack
    -- Goto (from-sip-external,s,1)
    -- Executing [s@from-sip-external:1] GotoIf("SIP/192.168.2.107-00000035", "0?checklang:noanonymous") in new stack
    -- Goto (from-sip-external,s,5)
    -- Executing [s@from-sip-external:5] Set("SIP/192.168.2.107-00000035", "TIMEOUT(absolute)=15") in new stack
Channel will hangup at 2013-10-09 18:18:48.886 EEST.
    -- Executing [s@from-sip-external:6] Answer("SIP/192.168.2.107-00000035", "") in new stack
  == Spawn extension (from-sip-external, s, 6) exited non-zero on 'SIP/192.168.2.107-00000035'
    -- Executing [h@from-sip-external:1] Hangup("SIP/192.168.2.107-00000035", "") in new stack
  == Spawn extension (from-sip-external, h, 1) exited non-zero on 'SIP/192.168.2.107-00000035'
    -- Executing [000972592594535@from-sip-external:1] NoOp("SIP/192.168.2.107-00000036", "Received incoming SIP connection from unknown peer to 000972592594535") in new stack
    -- Executing [000972592594535@from-sip-external:2] Set("SIP/192.168.2.107-00000036", "DID=000972592594535") in new stack
    -- Executing [000972592594535@from-sip-external:3] Goto("SIP/192.168.2.107-00000036", "s,1") in new stack
    -- Executing [s@from-sip-external:1] GotoIf("SIP/192.168.2.107-00000036", "0?checklang:noanonymous") in new stack
    -- Executing [s@from-sip-external:5] Set("SIP/192.168.2.107-00000036", "TIMEOUT(absolute)=15") in new stack
Channel will hangup at 2013-10-09 18:18:49.807 EEST.
    -- Executing [s@from-sip-external:6] Answer("SIP/192.168.2.107-00000036", "") in new stack
  == Spawn extension (from-sip-external, s, 6) exited non-zero on 'SIP/192.168.2.107-00000036'
    -- Executing [h@from-sip-external:1] Hangup("SIP/192.168.2.107-00000036", "") in new stack
  == Spawn extension (from-sip-external, h, 1) exited non-zero on 'SIP/192.168.2.107-00000036'
    -- Executing [900972592594535@from-sip-external:1] NoOp("SIP/192.168.2.107-00000037", "Received incoming SIP connection from unknown peer to 900972592594535") in new stack
    -- Executing [900972592594535@from-sip-external:2] Set("SIP/192.168.2.107-00000037", "DID=900972592594535") in new stack
    -- Executing [900972592594535@from-sip-external:3] Goto("SIP/192.168.2.107-00000037", "s,1") in new stack
    -- Executing [s@from-sip-external:1] GotoIf("SIP/192.168.2.107-00000037", "0?checklang:noanonymous") in new stack
    -- Executing [s@from-sip-external:5] Set("SIP/192.168.2.107-00000037", "TIMEOUT(absolute)=15") in new stack
Channel will hangup at 2013-10-09 18:18:50.424 EEST.
    -- Executing [s@from-sip-external:6] Answer("SIP/192.168.2.107-00000037", "") in new stack
  == Spawn extension (from-sip-external, s, 6) exited non-zero on 'SIP/192.168.2.107-00000037'
    -- Executing [h@from-sip-external:1] Hangup("SIP/192.168.2.107-00000037", "") in new stack
  == Spawn extension (from-sip-external, h, 1) exited non-zero on 'SIP/192.168.2.107-00000037'
    -- Executing [972592594535@from-sip-external:1] NoOp("SIP/192.168.2.107-00000038", "Received incoming SIP connection from unknown peer to 972592594535") in new stack
    -- Executing [972592594535@from-sip-external:2] Set("SIP/192.168.2.107-00000038", "DID=972592594535") in new stack
    -- Executing [972592594535@from-sip-external:3] Goto("SIP/192.168.2.107-00000038", "s,1") in new stack
    -- Executing [s@from-sip-external:1] GotoIf("SIP/192.168.2.107-00000038", "0?checklang:noanonymous") in new stack
    -- Executing [s@from-sip-external:5] Set("SIP/192.168.2.107-00000038", "TIMEOUT(absolute)=15") in new stack
Channel will hangup at 2013-10-09 18:18:52.310 EEST.
    -- Executing [s@from-sip-external:6] Answer("SIP/192.168.2.107-00000038", "") in new stack
  == Spawn extension (from-sip-external, s, 6) exited non-zero on 'SIP/192.168.2.107-00000038'
    -- Executing [h@from-sip-external:1] Hangup("SIP/192.168.2.107-00000038", "") in new stack
  == Spawn extension (from-sip-external, h, 1) exited non-zero on 'SIP/192.168.2.107-00000038'
    -- Executing [9900972592594535@from-sip-external:1] NoOp("SIP/192.168.2.107-00000039", "Received incoming SIP connection from unknown peer to 9900972592594535") in new stack
    -- Executing [9900972592594535@from-sip-external:2] Set("SIP/192.168.2.107-00000039", "DID=9900972592594535") in new stack
    -- Executing [9900972592594535@from-sip-external:3] Goto("SIP/192.168.2.107-00000039", "s,1") in new stack
    -- Executing [s@from-sip-external:1] GotoIf("SIP/192.168.2.107-00000039", "0?checklang:noanonymous") in new stack
    -- Executing [s@from-sip-external:5] Set("SIP/192.168.2.107-00000039", "TIMEOUT(absolute)=15") in new stack
Channel will hangup at 2013-10-09 18:18:53.588 EEST.
    -- Executing [s@from-sip-external:6] Answer("SIP/192.168.2.107-00000039", "") in new stack
  == Spawn extension (from-sip-external, s, 6) exited non-zero on 'SIP/192.168.2.107-00000039'
    -- Executing [h@from-sip-external:1] Hangup("SIP/192.168.2.107-00000039", "") in new stack
  == Spawn extension (from-sip-external, h, 1) exited non-zero on 'SIP/192.168.2.107-00000039'
