проблема с потоком E1
AndreyATC
Re: проблема с потоком E1
Сообщение AndreyATC »
zzuz писал(а):
2 - второй дебаг межгород 10 знаков тоже неудачный
- неправда , нет такого.
-- Called DAHDI/g0/0432XXXXXX
PRI Span: 1 -- Making new call for cref 32778
PRI Span: 1
PRI Span: 1 > DL-DATA request
PRI Span: 1 > Protocol Discriminator: Q.931 (8) len=39
PRI Span: 1 > TEI=0 Call Ref: len= 2 (reference 10/0xA) (Sent from originator)
PRI Span: 1 > Message Type: SETUP (5)
PRI Span: 1 TEI=0 Transmitting N(S)=80, window is open V(A)=80 K=7
PRI Span: 1
PRI Span: 1 > [04 03 80 90 a3]
PRI Span: 1 > Bearer Capability (len= 5) [ Ext: 1 Coding-Std: 0 Info transfer capability: Speech (0)
PRI Span: 1 > Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
PRI Span: 1 > User information layer 1: A-Law (35)
PRI Span: 1 > [18 03 a1 83 81]
PRI Span: 1 > Channel ID (len= 5) [ Ext: 1 IntID: Implicit Other(PRI) Spare: 0 Preferred Dchan: 0
PRI Span: 1 > ChanSel: As indicated in following octets
PRI Span: 1 > Ext: 1 Coding: 0 Number Specified Channel Type: 3
PRI Span: 1 > Ext: 1 Channel: 1 Type: CPE]
PRI Span: 1 > [6c 08 21 80 35 35 35 35 35 30]
PRI Span: 1 > Calling Party Number (len=10) [ Ext: 0 TON: National Number (2) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
PRI Span: 1 > Presentation: Presentation allowed, User-provided, not screened (0) '55XXXX' ]
PRI Span: 1 > [70 0b 80 30 34 33 32 35 30 37 36 37 38]
PRI Span: 1 > Called Party Number (len=13) [ Ext: 1 TON: Unknown Number Type (0) NPI: Unknown Number Plan (0) '0432XXXXXX' ]
PRI Span: 1 > [a1]
PRI Span: 1 > Sending Complete (len= 1)
PRI Span: 1 q931.c:6334 q931_setup: Call 32778 enters state 1 (Call Initiated). Hold state: Idle
PRI Span: 1 T303 timed out. cref:32778
PRI Span: 1
PRI Span: 1 TEI=0 Transmitting N(S)=81, window is open V(A)=81 K=7
PRI Span: 1
PRI Span: 1 > [a1]
PRI Span: 1 q931.c:6223 t303_expiry: Call 32778 enters state 0 (Null). Hold state: Idle
PRI Span: 1 Fake clearing. cref:32778
PRI Span: 1 q931.c:9606 pri_internal_clear: alive 1, hangupack 1
Span 1: Processing event PRI_EVENT_HANGUP
-- Span 1: Channel 0/1 got hangup, cause 18
PRI Span: 1 q931.c:7135 q931_hangup: Hangup other cref:32778
PRI Span: 1 q931.c:6892 __q931_hangup: ourstate Null, peerstate Null, hold-state Idle
PRI Span: 1 Destroying call 0x7f063818aa00, ourstate Null, peerstate Null, hold-state Idle
-- Hungup 'DAHDI/i1/0432XXXXXX-13'
AndreyATC
PRI Span: 1
PRI Span: 1
PRI Span: 1 > [a1]
PRI Span: 1
PRI Span: 1
PRI Span: 1 > [a1]
AndreyATC
Еще раз говорю с наборами у меня все ок! проблема не в єтом а в:
почему так не пойму!
AndreyATC
ded писал(а):Не понять мне - почему ваши звонки через локальный канал? Local/50XXXX@from-internal - это какк-то не верно, такое порождают call files, тут шестизнак всё равно, а не десять -DAHDI/i1/507678-3 (не надо закрываться ХХХ, номера ваши не секрет)
а прямые наборы будут выглядить в логе так:
Dial("SIP/0931500047-00000025", "DAHDI/g1/507678-3") in new stack
потому что звонки сделаны через дису
Последний раз редактировалось AndreyATC 08 июл 2013, 12:38, всего редактировалось 1 раз.
Ключевые строки.
AndreyATC
означает что мой CLID = 55XXXX - требование провайдера
говорит о том что мой набор 0432XXXXXX
в чем тут проблема?
AndreyATC писал(а):а прямые наборы будут выглядить в логе так:
Для тестов не надо дису, сделайте прямые наборы.
CLID = 55XXXX - требование провайдера? Попробуйте CLID = в национальном формате сделать 043557678 или как у вас там.
AndreyATC
пробовал провайдер косит
он код страны и код города сам добавляет!
я ж говорю что провайдер тоже дебажил поток звонки которые у меня cause 18 он в пинцыпе не видит и говорит что в поток они не попадают
AndreyATC
закрадывается мысль что карта глючит ...
В платный суппорт.
