[root@localhost ~]# asterisk -r
Asterisk 1.8.22.0, Copyright (C) 1999 - 2012 Digium, Inc. and others.
Created by Mark Spencer <markster@digium.com>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
Connected to Asterisk 1.8.22.0 currently running on localhost (pid = 1660)
Verbosity is at least 3
== Using SIP RTP TOS bits 184
-- Executing [110XXXX@from-trunk-sip-MSM7495797XXXX:1] Set("SIP/MSM7495797XXXX-00000134", "GROUP()=OUT_1") in new stack
-- Executing [110XXXX@from-trunk-sip-MSM7495797XXXX:2] Goto("SIP/MSM7495797XXXX-00000134", "from-trunk,110XXXX,1") in new stack
-- Goto (from-trunk,110XXXX,1)
-- Executing [110XXXX@from-trunk:1] Set("SIP/MSM7495797XXXX-00000134", "__FROM_DID=110XXXX") in new stack
-- Executing [110XXXX@from-trunk:2] Goto("SIP/MSM7495797XXXX-00000134", "s,1") in new stack
-- Goto (from-trunk,s,1)
-- Executing [s@from-trunk:1] ExecIf("SIP/MSM7495797XXXX-00000134", "0?Set(__FROM_DID=s)") in new stack
-- Executing [s@from-trunk:2] Gosub("SIP/MSM7495797XXXX-00000134", "app-blacklist-check,s,1()") in new stack
-- Executing [s@app-blacklist-check:1] GotoIf("SIP/MSM7495797XXXX-00000134", "0?blacklisted") in new stack
-- Executing [s@app-blacklist-check:2] Set("SIP/MSM7495797XXXX-00000134", "CALLED_BLACKLIST=1") in new stack
-- Executing [s@app-blacklist-check:3] Return("SIP/MSM7495797XXXX-00000134", "") in new stack
-- Executing [s@from-trunk:3] Set("SIP/MSM7495797XXXX-00000134", "CHANNEL(language)=ru") in new stack
-- Executing [s@from-trunk:4] Set("SIP/MSM7495797XXXX-00000134", "CDR(did)=110XXXX") in new stack
-- Executing [s@from-trunk:5] ExecIf("SIP/MSM7495797XXXX-00000134", "0 ?Set(CALLERID(name)=+7495787XXXX)") in new stack
-- Executing [s@from-trunk:6] Set("SIP/MSM7495797XXXX-00000134", "__CALLINGPRES_SV=allowed_not_screened") in new stack
-- Executing [s@from-trunk:7] Set("SIP/MSM7495797XXXX-00000134", "CALLERPRES()=allowed_not_screened") in new stack
-- Executing [s@from-trunk:8] Goto("SIP/MSM7495797XXXX-00000134", "disa,3,1") in new stack
-- Goto (disa,3,1)
-- Executing [3@disa:1] Answer("SIP/MSM7495797XXXX-00000134", "") in new stack
-- Executing [3@disa:2] Set("SIP/MSM7495797XXXX-00000134", "_DISA=disa^3^newcall") in new stack
-- Executing [3@disa:3] Set("SIP/MSM7495797XXXX-00000134", "_DISACONTEXT=from-internal-disa-rec") in new stack
-- Executing [3@disa:4] Set("SIP/MSM7495797XXXX-00000134", "_KEEPCID=TRUE") in new stack
-- Executing [3@disa:5] Set("SIP/MSM7495797XXXX-00000134", "_HANGUP=Tt") in new stack
-- Executing [3@disa:6] Set("SIP/MSM7495797XXXX-00000134", "TIMEOUT(digit)=5") in new stack
-- Digit timeout set to 5.000
-- Executing [3@disa:7] Set("SIP/MSM7495797XXXX-00000134", "TIMEOUT(response)=30") in new stack
-- Response timeout set to 30.000
-- Executing [3@disa:8] DISA("SIP/MSM7495797XXXX-00000134", "no-password,disa-dial") in new stack
-- Executing [8925371XXXX@disa-dial:1] NoOp("SIP/MSM7495797XXXX-00000134", "called 8925371XXXX in from-internal-disa-rec by ID: 3") in new stack
-- Executing [8925371XXXX@disa-dial:2] Dial("SIP/MSM7495797XXXX-00000134", "Local/8925371XXXX@from-internal-disa-rec,300,Tt") in new stack
-- Called Local/8925371XXXX@from-internal-disa-rec
-- Executing [8925371XXXX@from-internal-disa-rec:1] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "AUDIOHOOK_INHERIT(MixMonitor)=yes") in new stack
-- Executing [8925371XXXX@from-internal-disa-rec:2] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CALLFILENAME=DISA-1372314475.630.wav") in new stack
-- Executing [8925371XXXX@from-internal-disa-rec:3] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "FOLDER=/var/spool/asterisk/monitor/2013/06/27") in new stack
-- Executing [8925371XXXX@from-internal-disa-rec:4] MixMonitor("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "/var/spool/asterisk/monitor/2013/06/27/DISA-1372314475.630.wav,a,") in new stack
-- Executing [8925371XXXX@from-internal-disa-rec:5] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CDR(recordingfile)=DISA-1372314475.630.wav") in new stack
== Begin MixMonitor Recording Local/8925371XXXX@from-internal-disa-rec-0000009b;2
-- Executing [8925371XXXX@from-internal-disa-rec:6] Goto("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "from-internal,8925371XXXX,1") in new stack
-- Goto (from-internal,8925371XXXX,1)
-- Executing [8925371XXXX@from-internal:1] Macro("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "user-callerid,LIMIT,") in new stack
-- Executing [s@macro-user-callerid:1] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "TOUCH_MONITOR=1372314475.630") in new stack
-- Executing [s@macro-user-callerid:2] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "AMPUSER=+7495787XXXX") in new stack
-- Executing [s@macro-user-callerid:3] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?report") in new stack
-- Executing [s@macro-user-callerid:4] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?Set(REALCALLERIDNUM=+7495787XXXX)") in new stack
-- Executing [s@macro-user-callerid:5] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "AMPUSER=") in new stack
-- Executing [s@macro-user-callerid:6] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "AMPUSERCIDNAME=") in new stack
-- Executing [s@macro-user-callerid:7] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?report") in new stack
-- Goto (macro-user-callerid,s,15)
-- Executing [s@macro-user-callerid:15] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?continue") in new stack
-- Goto (macro-user-callerid,s,28)
-- Executing [s@macro-user-callerid:28] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CALLERID(number)=+7495787XXXX") in new stack
-- Executing [s@macro-user-callerid:29] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CALLERID(name)=+7495787XXXX") in new stack
-- Executing [s@macro-user-callerid:30] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CDR(cnum)=+7495787XXXX") in new stack
-- Executing [s@macro-user-callerid:31] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CDR(cnam)=+7495787XXXX") in new stack
-- Executing [s@macro-user-callerid:32] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CHANNEL(language)=ru") in new stack
-- Executing [8925371XXXX@from-internal:2] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "MOHCLASS=default") in new stack
-- Executing [8925371XXXX@from-internal:3] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "_NODEST=") in new stack
-- Executing [8925371XXXX@from-internal:4] Gosub("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "sub-record-check,s,1(out,8925371XXXX,)") in new stack
-- Executing [s@sub-record-check:1] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "REC_POLICY_MODE_SAVE=") in new stack
-- Executing [s@sub-record-check:2] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?check") in new stack
-- Goto (sub-record-check,s,7)
-- Executing [s@sub-record-check:7] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__MON_FMT=wav") in new stack
-- Executing [s@sub-record-check:8] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?next") in new stack
-- Goto (sub-record-check,s,11)
-- Executing [s@sub-record-check:11] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Return()") in new stack
-- Executing [s@sub-record-check:12] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(__REC_POLICY_MODE=)") in new stack
-- Executing [s@sub-record-check:13] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?out,1") in new stack
-- Executing [s@sub-record-check:14] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__REC_STATUS=INITIALIZED") in new stack
-- Executing [s@sub-record-check:15] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "NOW=1372314475") in new stack
-- Executing [s@sub-record-check:16] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__DAY=27") in new stack
-- Executing [s@sub-record-check:17] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__MONTH=06") in new stack
-- Executing [s@sub-record-check:18] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__YEAR=2013") in new stack
-- Executing [s@sub-record-check:19] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__TIMESTR=20130627-102755") in new stack
-- Executing [s@sub-record-check:20] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__FROMEXTEN=+7495787XXXX") in new stack
-- Executing [s@sub-record-check:21] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "__CALLFILENAME=out-8925371XXXX-+7495787XXXX-20130627-102755-1372314475.630") in new stack
-- Executing [s@sub-record-check:22] Goto("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "out,1") in new stack
-- Executing [out@sub-record-check:1] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?Set(__REC_POLICY_MODE=)") in new stack
-- Executing [out@sub-record-check:2] GosubIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?record,1(exten,8925371XXXX,+7495787XXXX)") in new stack
-- Executing [out@sub-record-check:3] Return("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "") in new stack
-- Executing [8925371XXXX@from-internal:5] Macro("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "dialout-trunk,1,8925371XXXX,,off") in new stack
-- Executing [s@macro-dialout-trunk:1] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "DIAL_TRUNK=1") in new stack
-- Executing [s@macro-dialout-trunk:2] GosubIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?sub-pincheck,s,1()") in new stack
-- Executing [s@macro-dialout-trunk:3] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?disabletrunk,1") in new stack
-- Executing [s@macro-dialout-trunk:4] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "DIAL_NUMBER=8925371XXXX") in new stack
-- Executing [s@macro-dialout-trunk:5] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "DIAL_TRUNK_OPTIONS=Ttr") in new stack
-- Executing [s@macro-dialout-trunk:6] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "OUTBOUND_GROUP=OUT_1") in new stack
-- Executing [s@macro-dialout-trunk:7] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?nomax") in new stack
-- Executing [s@macro-dialout-trunk:8] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?chanfull") in new stack
-- Executing [s@macro-dialout-trunk:9] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?skipoutcid") in new stack
-- Executing [s@macro-dialout-trunk:10] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "DIAL_TRUNK_OPTIONS=Tt") in new stack
-- Executing [s@macro-dialout-trunk:11] Macro("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "outbound-callerid,1") in new stack
-- Executing [s@macro-outbound-callerid:1] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?Set(CALLERPRES()=allowed_not_screened)") in new stack
-- Executing [s@macro-outbound-callerid:2] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(REALCALLERIDNUM=+7495787XXXX)") in new stack
-- Executing [s@macro-outbound-callerid:3] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?normcid") in new stack
-- Executing [s@macro-outbound-callerid:4] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "USEROUTCID=+7495787XXXX") in new stack
-- Executing [s@macro-outbound-callerid:5] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?bypass") in new stack
-- Goto (macro-outbound-callerid,s,7)
-- Executing [s@macro-outbound-callerid:7] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "EMERGENCYCID=") in new stack
-- Executing [s@macro-outbound-callerid:8] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "TRUNKOUTCID=110XXXX") in new stack
-- Executing [s@macro-outbound-callerid:9] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?trunkcid") in new stack
-- Goto (macro-outbound-callerid,s,14)
-- Executing [s@macro-outbound-callerid:14] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?Set(CALLERID(all)=110XXXX)") in new stack
-- Executing [s@macro-outbound-callerid:15] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?Set(CALLERID(all)=+7495787XXXX)") in new stack
-- Executing [s@macro-outbound-callerid:16] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(CALLERID(all)=)") in new stack
-- Executing [s@macro-outbound-callerid:17] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(CALLERPRES()=prohib_passed_screen)") in new stack
-- Executing [s@macro-outbound-callerid:18] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CDR(outbound_cnum)=+7495787XXXX") in new stack
-- Executing [s@macro-outbound-callerid:19] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "CDR(outbound_cnam)=") in new stack
-- Executing [s@macro-dialout-trunk:12] GosubIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?sub-flp-1,s,1()") in new stack
-- Executing [s@macro-dialout-trunk:13] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "OUTNUM=8925371XXXX") in new stack
-- Executing [s@macro-dialout-trunk:14] Set("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "custom=SIP/MSM7495797XXXX") in new stack
-- Executing [s@macro-dialout-trunk:15] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(DIAL_TRUNK_OPTIONS=M(setmusic^default)Tt)") in new stack
-- Executing [s@macro-dialout-trunk:16] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(DIAL_TRUNK_OPTIONS=TtM(confirm))") in new stack
-- Executing [s@macro-dialout-trunk:17] Macro("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "dialout-trunk-predial-hook,") in new stack
-- Executing [s@macro-dialout-trunk-predial-hook:1] MacroExit("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "") in new stack
-- Executing [s@macro-dialout-trunk:18] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?bypass,1") in new stack
-- Executing [s@macro-dialout-trunk:19] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(CONNECTEDLINE(num,i)=8925371XXXX)") in new stack
-- Executing [s@macro-dialout-trunk:20] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(CONNECTEDLINE(name,i)=CID:+7495787XXXX)") in new stack
-- Executing [s@macro-dialout-trunk:21] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?customtrunk") in new stack
-- Executing [s@macro-dialout-trunk:22] Dial("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "SIP/MSM7495797XXXX/8925371XXXX,300,Tt") in new stack
-- Called SIP/MSM7495797XXXX/8925371XXXX
-- SIP/MSM7495797XXXX-00000135 is ringing
-- Local/8925371XXXX@from-internal-disa-rec-0000009b;1 is ringing
-- SIP/MSM7495797XXXX-00000135 answered Local/8925371XXXX@from-internal-disa-rec-0000009b;2
-- Local/8925371XXXX@from-internal-disa-rec-0000009b;1 answered SIP/MSM7495797XXXX-00000134
-- Executing [h@macro-dialout-trunk:1] Macro("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "hangupcall,") in new stack
-- Executing [s@macro-hangupcall:1] GotoIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "1?theend") in new stack
-- Executing [s@macro-hangupcall:3] ExecIf("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "0?Set(CDR(recordingfile)=)") in new stack
-- Executing [s@macro-hangupcall:4] Hangup("Local/8925371XXXX@from-internal-disa-rec-0000009b;2", "") in new stack
== Spawn extension (macro-hangupcall, s, 4) exited non-zero on 'Local/8925371XXXX@from-internal-disa-rec-0000009b;2' in macro 'hangupcall'
== Spawn extension (macro-dialout-trunk, h, 1) exited non-zero on 'Local/8925371XXXX@from-internal-disa-rec-0000009b;2'
== Spawn extension (macro-dialout-trunk, s, 22) exited non-zero on 'Local/8925371XXXX@from-internal-disa-rec-0000009b;2' in macro 'dialout-trunk'
== Spawn extension (from-internal, 8925371XXXX, 5) exited non-zero on 'Local/8925371XXXX@from-internal-disa-rec-0000009b;2'
-- Executing [h@disa-dial:1] NoOp("SIP/MSM7495797XXXX-00000134", "called h in from-internal-disa-rec by ID: 3") in new stack
-- Executing [h@disa-dial:2] Dial("SIP/MSM7495797XXXX-00000134", "Local/h@from-internal-disa-rec,300,Tt") in new stack
[2013-06-27 10:28:08] NOTICE[9006]: chan_local.c:969 local_call: No such extension/context h@from-internal-disa-rec while calling Local channel
-- Couldn't call Local/h@from-internal-disa-rec
== Everyone is busy/congested at this time (0:0/0/0)
-- Executing [h@disa-dial:3] Gosub("SIP/MSM7495797XXXX-00000134", "s-CHANUNAVAIL,1()") in new stack
-- Executing [s-CHANUNAVAIL@disa-dial:1] NoOp("SIP/MSM7495797XXXX-00000134", "DISA Dial failed due to CHANUNAVAIL - returning to dial tone") in new stack
-- Executing [s-CHANUNAVAIL@disa-dial:2] PlayTones("SIP/MSM7495797XXXX-00000134", "congestion") in new stack
-- Executing [s-CHANUNAVAIL@disa-dial:3] Wait("SIP/MSM7495797XXXX-00000134", "3") in new stack
== Spawn extension (disa-dial, s-CHANUNAVAIL, 3) exited non-zero on 'SIP/MSM7495797XXXX-00000134'
== Spawn extension (disa-dial, 8925371XXXX, 2) exited non-zero on 'SIP/MSM7495797XXXX-00000134'
== MixMonitor close filestream
== End MixMonitor Recording Local/8925371XXXX@from-internal-disa-rec-0000009b;2
Большое спасибо за помощь.
