Отправка факса через Zoiper
lightman
Re: Отправка факса через Zoiper
Сообщение lightman »
april22 я писал что поставить не получается.
делаю по инструкции
./configure
Configuring HylaFAX (tm) (aka FlexFAX) 6.0.6.
If configure does the wrong thing, check the file config.log for
information that may help you understand what went wrong.
Reading site-wide parameters from ./config.site.
Gosh, aren't you lucky to have a powerpc-unknown-linux-gnu system!
Using /opt/bin/gcc for a C compiler (set CC to override).
Looks like /opt/bin/gcc supports the -g option.
Using " -g" for C compiler options.
Looks like /opt/bin/gcc has an ANSI C preprocessor.
... but __ANSI_CPP__ is not automatically defined, will compensate.
Looks like /opt/bin/gcc supports the -M option for generating make dependencies.
Using /opt/bin/gcc for a C++ compiler (set CXX to override).
Using " -g" for C++ compiler options.
No make located in the search path.
There was no make program in the search path used by this script.
If make is in a non-standard location, then set the MAKE environment
variable to the pathname of the appropriate program or change your
shell search path to include the directory where the program is located.
Unrecoverable error! Once you've corrected the problem rerun this script.
а там часом не FFP какой нибудь ?!
#>env
PATH= ????
# >gcc -v (под споллер )
lightman
SSH_CLIENT= XXX.XXX.XXX.XXX 54166 22
MAIL=/var/mail/user
USER=user
OLDPWD=/user
TERMINFO=/opt/share/terminfo
HOME=/user
SSH_TTY=/dev/pts/1
PAGER=more
LOGNAME=user
TERM=xterm
PATH=/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin:/usr/local/sbin:/usr/local/bin
SHELL=/bin/ash
PWD=/root/hylafax-6.0.6
SSH_CONNECTION=XXX.XXX.XXX.XXX 54166 XXX.XXX.XXX.XXX 22
PGDATA=/var/service/pgsql
TZ=EET-2EEST,M3.5.0/3,M10.5.0/4
gcc -v
Reading specs from /opt/lib/gcc/powerpc-linux-gnuspe/3.4.6/specs
Configured with: ../gcc-3.4.6/configure --build=i386-pc-linux-gnu --host=powerpc-linux-gnuspe --target=powerpc-linux-gnuspe --prefix=/opt --disable-nls --disable-static --with-as=/home/slug/optware/syno-e500/toolchain/gcc-3.4.3-glibc-2.3.4/powerpc-linux-gnuspe/bin/powerpc-linux-gnuspe-as --with-ld=/home/slug/optware/syno-e500/toolchain/gcc-3.4.3-glibc-2.3.4/powerpc-linux-gnuspe/bin/powerpc-linux-gnuspe-ld --enable-languages=c,c++ --disable-multilib
Thread model: posix
gcc driver version 3.4.6 executing gcc version 3.4.3
Sfinx
Сообщение Sfinx »
gcc есть - и этого уже достаточно. Все чего там не хватает ставится руками вместе с бутылочкой хорошего темного пивка
Rus
SfinxSoft
http://sfinxsoft.com
