Blind transfer + NAT = Retransmission timeout
sadm
Re: Blind transfer + NAT = Retransmission timeout
Сообщение sadm »
awsswa писал(а):nat=yes раз у вас все за натом, ставиться глобально и на каждого
directmedia=no - тоже
Сделал глобально и на всех юзерах персонально.
rtp set debug on - звоните и смотрите адреса, внутренних не должно быть
А почему внутренних не должно быть? Астериск и клиенты за натом. У клиентов нет адресов кроме внутренних.
  == Using SIP RTP TOS bits 184
    -- Executing [PravOrgRus1@arctel1_out:1] Dial("SIP/arctel1_out-000002d0", "SIP/15&SIP/17&SIP/14&SIP/12,,rTt") in new stack
    -- Called SIP/15
    -- Called SIP/17
[Dec  5 15:58:34] WARNING[507]: app_dial.c:2341 dial_exec_full: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
    -- Called SIP/12
    -- SIP/15-000002d1 connected line has changed. Saving it until answer for SIP/arctel1_out-000002d0
    -- SIP/17-000002d2 connected line has changed. Saving it until answer for SIP/arctel1_out-000002d0
    -- SIP/12-000002d3 connected line has changed. Saving it until answer for SIP/arctel1_out-000002d0
    -- SIP/17-000002d2 is ringing
    -- SIP/15-000002d1 is ringing
    -- SIP/12-000002d3 is ringing
    -- SIP/12-000002d3 answered SIP/arctel1_out-000002d0
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005436, ts 023475, len 000033)
    -- fixed jitterbuffer created on channel SIP/arctel1_out-000002d0
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005437, ts 023635, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005438, ts 023795, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005439, ts 023955, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005440, ts 024115, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005441, ts 024275, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005442, ts 024435, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005443, ts 024595, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003816, ts 023472, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005444, ts 024755, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003817, ts 023632, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005445, ts 024915, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003818, ts 023792, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005446, ts 025075, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003819, ts 023952, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005447, ts 025235, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003820, ts 024112, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 016967, ts 651387072, len 000020)
    -- fixed jitterbuffer created on channel SIP/12-000002d3
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005448, ts 025395, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003821, ts 024272, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 016968, ts 651387232, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005449, ts 025555, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003822, ts 024432, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 016969, ts 651387392, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005450, ts 025715, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 003823, ts 024592, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 016970, ts 651387552, len 000020)
[SKIP]
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004015, ts 055312, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017162, ts 651418272, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018987, ts 651417152, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005643, ts 056595, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004016, ts 055472, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017163, ts 651418432, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018988, ts 651417312, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005644, ts 056755, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004017, ts 055632, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017164, ts 651418592, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018989, ts 651417472, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005645, ts 056915, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004018, ts 055792, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017165, ts 651418752, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018990, ts 651417632, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005646, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005646, ts 057075, len 000004, mark 1, event 0000000b, end 0, duration 00160)
[Dec  5 15:58:40] DEBUG[507]: res_rtp_asterisk.c:1547 process_dtmf_rfc2833: - RTP 2833 Event: 0000000b (len = 4)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005647, ts 057075, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017166, ts 651418912, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005648, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005648, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 00320)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005649, ts 057235, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017167, ts 651419072, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005650, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005650, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 00480)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005651, ts 057395, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017168, ts 651419232, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005652, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005652, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 00640)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005653, ts 057555, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017169, ts 651419392, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005654, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005654, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 00800)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005655, ts 057715, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017170, ts 651419552, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005656, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005656, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 00960)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005657, ts 057875, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017171, ts 651419712, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005658, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005658, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 01120)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005659, ts 058035, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017172, ts 651419872, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005660, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005660, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 01280)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005661, ts 058195, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017173, ts 651420032, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018991, ts 651418912, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005662, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005662, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 01440)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005663, ts 058355, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017174, ts 651420192, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018992, ts 651419072, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005664, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005664, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 01600)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005665, ts 058515, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017175, ts 651420352, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018993, ts 651419232, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005666, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005666, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 01760)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005667, ts 058675, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017176, ts 651420512, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018994, ts 651419392, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005668, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005668, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 01920)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005669, ts 058835, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017177, ts 651420672, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018995, ts 651419552, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005670, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005670, ts 057075, len 000004, mark 0, event 0000000b, end 0, duration 02080)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005671, ts 058995, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017178, ts 651420832, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018996, ts 651419712, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005672, ts 057075, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005672, ts 057075, len 000004, mark 0, event 0000000b, end 1, duration 02240)
    -- Started music on hold, class 'default', on SIP/arctel1_out-000002d0
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018997, ts 651420944, len 000033)
    -- <SIP/12-000002d3> Playing 'pbx-transfer.gsm' (language 'ru')
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005673, ts 059155, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017179, ts 651420992, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005674, ts 059315, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004019, ts 059360, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018998, ts 651421104, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017180, ts 651421152, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005675, ts 059475, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004020, ts 059520, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 018999, ts 651421264, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017181, ts 651421312, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005676, ts 059635, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004021, ts 059680, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019000, ts 651421424, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017182, ts 651421472, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005677, ts 059795, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004022, ts 059840, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019001, ts 651421584, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017183, ts 651421632, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005678, ts 059955, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004023, ts 060000, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019002, ts 651421744, len 000033)
[SKIP]
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005697, ts 062995, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004042, ts 063040, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019021, ts 651424784, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017203, ts 651424832, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004043, ts 063200, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019022, ts 651424944, len 000033)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005698, ts 063155, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017204, ts 651424992, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005699, ts 063315, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004044, ts 063360, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019023, ts 651425104, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017205, ts 651425152, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005700, ts 063475, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004045, ts 063520, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019024, ts 651425264, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017206, ts 651425312, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005701, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005701, ts 063635, len 000004, mark 1, event 00000001, end 0, duration 00160)
[Dec  5 15:58:41] DEBUG[507]: res_rtp_asterisk.c:1547 process_dtmf_rfc2833: - RTP 2833 Event: 00000001 (len = 4)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005702, ts 063635, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004046, ts 063680, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019025, ts 651425424, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017207, ts 651425472, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005703, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005703, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 00320)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005704, ts 063795, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004047, ts 063840, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019026, ts 651425584, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017208, ts 651425632, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005705, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005705, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 00480)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005706, ts 063955, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004048, ts 064000, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019027, ts 651425744, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017209, ts 651425792, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005707, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005707, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 00640)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005708, ts 064115, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004049, ts 064160, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019028, ts 651425904, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017210, ts 651425952, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005709, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005709, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 00800)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005710, ts 064275, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004050, ts 064320, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019029, ts 651426064, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017211, ts 651426112, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005711, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005711, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 00960)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005712, ts 064435, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004051, ts 064480, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017212, ts 651426272, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005713, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005713, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 01120)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005714, ts 064595, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004052, ts 064640, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019030, ts 651426224, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017213, ts 651426432, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005715, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005715, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 01280)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005716, ts 064755, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004053, ts 064800, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019031, ts 651426384, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017214, ts 651426592, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005717, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005717, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 01440)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005718, ts 064915, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004054, ts 064960, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019032, ts 651426544, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017215, ts 651426752, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005719, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005719, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 01600)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005720, ts 065075, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004055, ts 065120, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019033, ts 651426704, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017216, ts 651426912, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005721, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005721, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 01760)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005722, ts 065235, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004056, ts 065280, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019034, ts 651426864, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017217, ts 651427072, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005723, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005723, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 01920)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005724, ts 065395, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004057, ts 065440, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019035, ts 651427024, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017218, ts 651427232, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005725, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005725, ts 063635, len 000004, mark 0, event 00000001, end 0, duration 02080)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005726, ts 065555, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004058, ts 065600, len 000020)
Sent RTP packet to      192.168.0.101:40046 (type 03, seq 019036, ts 651427184, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017219, ts 651427392, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005727, ts 063635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005727, ts 063635, len 000004, mark 0, event 00000001, end 1, duration 02240)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005728, ts 065715, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004059, ts 065760, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017220, ts 651427552, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005729, ts 065875, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004060, ts 065920, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017221, ts 651427712, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005730, ts 066035, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004061, ts 066080, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017222, ts 651427872, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005731, ts 066195, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004062, ts 066240, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017223, ts 651428032, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005732, ts 066355, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004063, ts 066400, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017224, ts 651428192, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004064, ts 066560, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005733, ts 066515, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017225, ts 651428352, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004065, ts 066720, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005734, ts 066675, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017226, ts 651428512, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005735, ts 066835, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004066, ts 066880, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017227, ts 651428672, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005736, ts 066995, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004067, ts 067040, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017228, ts 651428832, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005737, ts 067155, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004068, ts 067200, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017229, ts 651428992, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005738, ts 067315, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004069, ts 067360, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017230, ts 651429152, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005739, ts 067475, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004070, ts 067520, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017231, ts 651429312, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005740, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005740, ts 067635, len 000004, mark 1, event 00000007, end 0, duration 00160)
[Dec  5 15:58:41] DEBUG[507]: res_rtp_asterisk.c:1547 process_dtmf_rfc2833: - RTP 2833 Event: 00000007 (len = 4)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005741, ts 067635, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004071, ts 067680, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017232, ts 651429472, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005742, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005742, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 00320)
[Dec  5 15:58:42] DEBUG[507]: res_rtp_asterisk.c:1547 process_dtmf_rfc2833: - RTP 2833 Event: 00000007 (len = 4)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005743, ts 067795, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004072, ts 067840, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017233, ts 651429632, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005744, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005744, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 00480)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005745, ts 067955, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004073, ts 068000, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017234, ts 651429792, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005746, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005746, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 00640)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005747, ts 068115, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004074, ts 068160, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017235, ts 651429952, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005748, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005748, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 00800)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005749, ts 068275, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004075, ts 068320, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017236, ts 651430112, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005750, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005750, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 00960)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005751, ts 068435, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004076, ts 068480, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017237, ts 651430272, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005752, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005752, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 01120)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005753, ts 068595, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004077, ts 068640, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017238, ts 651430432, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005754, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005754, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 01280)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005755, ts 068755, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004078, ts 068800, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017239, ts 651430592, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005756, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005756, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 01440)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005757, ts 068915, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004079, ts 068960, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017240, ts 651430752, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005758, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005758, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 01600)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005759, ts 069075, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004080, ts 069120, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017241, ts 651430912, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005760, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005760, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 01760)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005761, ts 069235, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004081, ts 069280, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017242, ts 651431072, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005762, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005762, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 01920)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005763, ts 069395, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004082, ts 069440, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017243, ts 651431232, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005764, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005764, ts 067635, len 000004, mark 0, event 00000007, end 0, duration 02080)
Got  RTP packet from    192.168.0.101:40046 (type 03, seq 005765, ts 069555, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004083, ts 069600, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017244, ts 651431392, len 000020)
Got  RTP packet from    192.168.0.101:40046 (type 101, seq 005766, ts 067635, len 000004)
Got  RTP RFC2833 from   192.168.0.101:40046 (type 101, seq 005766, ts 067635, len 000004, mark 0, event 00000007, end 1, duration 02240)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004084, ts 069760, len 000020)
    -- Blind transferring SIP/arctel1_out-000002d0 to '17' (context office) priority 1
    -- Stopped music on hold on SIP/arctel1_out-000002d0
    -- fixed jitterbuffer destroyed on channel SIP/12-000002d3
    -- Executing [17@office:1] Dial("SIP/arctel1_out-000002d0", "SIP/17,,rTt") in new stack
    -- Called SIP/17
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017245, ts 651431552, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004085, ts 069920, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017246, ts 651431712, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004086, ts 070080, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017247, ts 651431872, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004087, ts 070240, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017248, ts 651432032, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004088, ts 070400, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017249, ts 651432192, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004089, ts 070560, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017250, ts 651432352, len 000020)
    -- SIP/17-000002d4 is ringing
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017251, ts 651432512, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004090, ts 070720, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017252, ts 651432672, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004091, ts 070880, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017253, ts 651432832, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004092, ts 071040, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017254, ts 651432992, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004093, ts 071200, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017255, ts 651433152, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004094, ts 071360, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017256, ts 651433312, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004095, ts 071520, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017257, ts 651433472, len 000020)
[SKIP]
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017409, ts 651457792, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004248, ts 096000, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017410, ts 651457952, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004249, ts 096160, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017411, ts 651458112, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004250, ts 096320, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004251, ts 096480, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004252, ts 096640, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017412, ts 651458272, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017413, ts 651458432, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017414, ts 651458592, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004253, ts 096800, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017415, ts 651458752, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004254, ts 096960, len 000020)
[SKIP]
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004307, ts 105440, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017469, ts 651467392, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004308, ts 105600, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017470, ts 651467552, len 000020)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004309, ts 105760, len 000020)
    -- SIP/17-000002d4 answered SIP/arctel1_out-000002d0
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017471, ts 651467712, len 000020)
    -- fixed jitterbuffer created on channel SIP/17-000002d4
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017472, ts 651467872, len 000020)
[Dec  5 15:58:46] DEBUG[507]: res_rtp_asterisk.c:2233 ast_rtp_read: RTP NAT: Got audio from other end. Now sending to address 192.168.0.117:40032
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019169, ts 062636, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017473, ts 651468032, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019170, ts 062796, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017474, ts 651468192, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019171, ts 062956, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017475, ts 651468352, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019172, ts 063116, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017476, ts 651468512, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019173, ts 063276, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017477, ts 651468672, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019174, ts 063436, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017478, ts 651468832, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019175, ts 063596, len 000033)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017479, ts 651468992, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019176, ts 063756, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030036, ts 651467872, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004310, ts 062632, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017480, ts 651469152, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019177, ts 063916, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030037, ts 651468032, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004311, ts 062792, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017481, ts 651469312, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019178, ts 064076, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030038, ts 651468192, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004312, ts 062952, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017482, ts 651469472, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019179, ts 064236, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030039, ts 651468352, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004313, ts 063112, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017483, ts 651469632, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019180, ts 064396, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030040, ts 651468512, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004314, ts 063272, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017484, ts 651469792, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019181, ts 064556, len 000033)
[SKIP]
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017560, ts 651481952, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019257, ts 076716, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030117, ts 651480832, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004391, ts 075592, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017561, ts 651482112, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019258, ts 076876, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030118, ts 651480992, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004392, ts 075752, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017562, ts 651482272, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019259, ts 077036, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030119, ts 651481152, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004393, ts 075912, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017563, ts 651482432, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019260, ts 077196, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030120, ts 651481312, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004394, ts 076072, len 000020)
Got  RTP packet from    86.110.4.148:27764 (type 18, seq 017564, ts 651482592, len 000020)
Got  RTP packet from    192.168.0.117:40032 (type 03, seq 019261, ts 077356, len 000033)
Sent RTP packet to      192.168.0.117:40032 (type 03, seq 030121, ts 651481472, len 000033)
Sent RTP packet to      86.110.4.148:27764 (type 18, seq 004395, ts 076232, len 000020)
[Dec  5 15:58:48] WARNING[15050]: chan_sip.c:3696 retrans_pkt: Retransmission timeout reached on transmission SBC1970ee3dadda60f749326f49f4aed3bc@172.21.0.2 for seqno 103 (Critical Request) -- See https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions
Packet timed out after 6400ms with no response
[Dec  5 15:58:48] WARNING[15050]: chan_sip.c:3725 retrans_pkt: Hanging up call SBC1970ee3dadda60f749326f49f4aed3bc@172.21.0.2 - no reply to our critical packet (see https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions).
    -- fixed jitterbuffer destroyed on channel SIP/17-000002d4
  == Spawn extension (office, 17, 1) exited non-zero on 'SIP/arctel1_out-000002d0'
    -- fixed jitterbuffer destroyed on channel SIP/arctel1_out-000002d0
rusgate*CLI> quit
Executing last minute cleanups
awsswa писал(а): и sip show peers сюда
Name/username              Host                                    Dyn Forcerport ACL Port     Status
10/11                      (Unspecified)                            D   N             0        UNKNOWN
11/11                      (Unspecified)                            D   N             0        UNKNOWN
12/12                      192.168.0.101                            D   N             63549    OK (109 ms)
13/13                      (Unspecified)                            D   N             0        UNKNOWN
14/14                      (Unspecified)                            D   N             0        UNKNOWN
15/15                      192.168.0.102                            D   N             52834    OK (119 ms)
16/16                      (Unspecified)                            D   N             0        UNKNOWN
17/17                      192.168.0.117                            D   N             49950    OK (112 ms)
arctel1_out/PORus1    86.110.4.148                                 N             5060     OK (19 ms)
arctel2_out/PORus2    86.110.4.148                                 N             5060     OK (19 ms)
sipmarket_out/111111       85.17.222.134                                N             5060     OK (60 ms)
172.21.0.2 - Это что у нас ?
Что по новой не расписывать:
Для NAT - когда сервер и клиенты за NAT
Схема:
Сервер->Роутер->Интернет
Клиенты как из внутренней сети так и интернета
externip=Внешний адрес роутера - вид 212.33.234.44 - он может быть только один
Их должно быть два
domain=Внутренний адрес 192.168.0.22
domain=Внешний адрес роутера - вид 212.33.234.44
Схема вида (может быть несколько):
localnet = 192.168.0.0/16
localnet = 10.10.0.0/16
NAT пишеться глобальный в [default] sip.conf
nat=yes ; Старый вариант
nat=force_rport ; Новый вариант
directmedia=no - пишите везде, глобально и на клиентов
На клиентов из внутренней сети nat=no, из внешней nat=force_rport (или nat=yes)
qualify=yes пишите туда где надо потдерживать соединения за nat
sadm
Сообщение sadm »
awsswa писал(а):На клиентов из внутренней сети nat=no, из внешней nat=force_rport (или nat=yes)
Огромное спасибо за подробную инструкцию. Сделал в точности по писанному, но результат - 4 секунды разговора и обрыв:
    -- Started music on hold, class 'default', on SIP/arctel1_out-00000000
    -- Stopped music on hold on SIP/arctel1_out-00000000
    -- fixed jitterbuffer destroyed on channel SIP/17-00000001
  == Spawn extension (office, 12, 1) exited non-zero on 'SIP/arctel1_out-00000000'
    -- Executing [12@office:1] Dial("SIP/arctel1_out-00000000", "SIP/12,,rTt") in new stack
    -- Called SIP/12
    -- SIP/12-00000003 is ringing
    -- SIP/12-00000003 answered SIP/arctel1_out-00000000
    -- fixed jitterbuffer created on channel SIP/12-00000003
[Dec  6 14:26:33] WARNING[4749]: chan_sip.c:3696 retrans_pkt: Retransmission timeout reached on transmission SBC90c7fda630765521905c87c1ff9aee4a@172.21.0.2 for seqno 103 (Critical Request) -- See https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions
[Dec  6 14:26:33] WARNING[4749]: chan_sip.c:3725 retrans_pkt: Hanging up call SBC90c7fda630765521905c87c1ff9aee4a@172.21.0.2 - no reply to our critical packet (see https://wiki.asterisk.org/wiki/display/AST/SIP+Retransmissions).
    -- fixed jitterbuffer destroyed on channel SIP/12-00000003
    -- fixed jitterbuffer destroyed on channel SIP/arctel1_out-00000000
    -- Executing [17@office:1] Dial("SIP/12-00000004", "SIP/17,,rTt") in new stack
    -- Called SIP/17
    -- SIP/17-00000005 is ringing
Готов плакать и биться головой об стену.
Может у меня НАТ неправильно сделан?
У меня проброшены порты 5060 и 10000...20000 с сервера астериск наружу. И в rtp.conf соответствующие настройки сделаны.
rtpstart=10000
rtpend=20000
И что самое обидное, не понимаю откуда этот дебильный 172.21.0.2 берётся. С арктела чтоли прилетает?
Попробовал софтфон draytek - то же самое, только в профиль.
одними verbose логами здесь не обойтись
средствами отладки астера довольно сложно понять что происходит, т.к. в потоке ненужной инфы теряется все что нужно увидеть
что нужно сделать сказано в предпоследнем посте первой страницы
несмотря на это вы упорно продолжаете плясать с бубном и действовать методом тыка
172.21.0.2 прилетает с прописанной маршрутизации? поднят где то vpn?
IMHO: лога Астериска мало. Нужен SIP debug, лучше в аналитике wireshark, будет даже наглядней. Вот в этом месте что прибегает -
172.21.0.2 прилетает с роутера, на котором может есть ALG
