sipnet входящие в софтфоны asterisk
Re: sipnet входящие в софтфоны asterisk
а в консоле есть какой то выхлоп - звонок до вас доходит - сам входящий то ?!
Ferrum
Сообщение Ferrum »
Проверяем настройки транка.
Trunk Description
sipnet.ru
Outbound Caller ID:
1234567
PEER Details:
host=sipnet.ru
fromdomain=sipnet.ru
fromuser=1234567
username=1234567
secret=mypassword
dtmfmode=rfc2833
type=peer
conext=contex-internal
nat=yes
allow=ulaw&alaw
insecure=very
USER Context:
1234567
USER Details:
secret=mysecret
type=user
insecure=very
Register String:
1234567:mysecret@sipnet.ru/1234567
Что в логах пишет при входящем звонке ?
Скопируйте Сюда.
it_tech
Сообщение it_tech »
транк проверил все ок
лог если перенаправление делаю на extension 1000
[Nov  9 14:30:43] VERBOSE[4546] netsock2.c:   == Using SIP RTP TOS bits 184
[Nov  9 14:30:43] VERBOSE[4546] netsock2.c:   == Using SIP RTP CoS mark 5
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk-sip-out:1] Set("SIP/out-00000020", "GROUP()=OUT_2") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk-sip-out:2] Goto("SIP/out-00000020", "from-trunk,sipid,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (from-trunk,sipid,1)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk:1] Set("SIP/out-00000020", "__FROM_DID=sipid") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk:2] Gosub("SIP/out-00000020", "app-blacklist-check,s,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@app-blacklist-check:1] GotoIf("SIP/out-00000020", "0?blacklisted") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@app-blacklist-check:2] Set("SIP/out-00000020", "CALLED_BLACKLIST=1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@app-blacklist-check:3] Return("SIP/out-00000020", "") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk:3] ExecIf("SIP/out-00000020", "0 ?Set(CALLERID(name)=0041762633)") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk:4] Set("SIP/out-00000020", "__CALLINGPRES_SV=allowed_not_screened") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk:5] Set("SIP/out-00000020", "CALLERPRES()=allowed_not_screened") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [sipid@from-trunk:6] Goto("SIP/out-00000020", "from-did-direct,1000,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (from-did-direct,1000,1)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [1000@from-did-direct:1] Macro("SIP/out-00000020", "exten-vm,novm,1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:1] Macro("SIP/out-00000020", "user-callerid,") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:1] Set("SIP/out-00000020", "AMPUSER=0041762633") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:2] GotoIf("SIP/out-00000020", "0?report") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:3] ExecIf("SIP/out-00000020", "1?Set(REALCALLERIDNUM=0041762633)") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:4] Set("SIP/out-00000020", "AMPUSER=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:5] Set("SIP/out-00000020", "AMPUSERCIDNAME=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:6] GotoIf("SIP/out-00000020", "1?report") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-user-callerid,s,10)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:10] GotoIf("SIP/out-00000020", "0?continue") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:11] Set("SIP/out-00000020", "__TTL=64") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:12] GotoIf("SIP/out-00000020", "1?continue") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-user-callerid,s,19)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:19] Set("SIP/out-00000020", "CALLERID(number)=0041762633") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:20] Set("SIP/out-00000020", "CALLERID(name)=0041762633") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-user-callerid:21] NoOp("SIP/out-00000020", "Using CallerID "0041762633" <0041762633>") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:2] Set("SIP/out-00000020", "RingGroupMethod=none") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:3] Set("SIP/out-00000020", "VMBOX=novm") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:4] Set("SIP/out-00000020", "__EXTTOCALL=1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:5] Set("SIP/out-00000020", "CFUEXT=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:6] Set("SIP/out-00000020", "CFBEXT=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:7] Set("SIP/out-00000020", "RT=""") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:8] Macro("SIP/out-00000020", "record-enable,1000,IN") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:1] GotoIf("SIP/out-00000020", "1?check") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-record-enable,s,4)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:4] ExecIf("SIP/out-00000020", "0?MacroExit()") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:5] GotoIf("SIP/out-00000020", "0?Group:OUT") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-record-enable,s,15)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:15] GotoIf("SIP/out-00000020", "1?IN") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-record-enable,s,20)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:20] ExecIf("SIP/out-00000020", "0?MacroExit()") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:21] NoOp("SIP/out-00000020", "Recording enable for 1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:22] Set("SIP/out-00000020", "CALLFILENAME=20121109-143043-1352457043.32") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:23] MixMonitor("SIP/out-00000020", "20121109-143043-1352457043.32.wav,,") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:24] Set("SIP/out-00000020", "CDR(userfield)=audio:20121109-143043-1352457043.32.wav") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-record-enable:25] MacroExit("SIP/out-00000020", "") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:9] Macro("SIP/out-00000020", "dial-one,"",tr,1000") in new stack
[Nov  9 14:30:43] VERBOSE[10731] app_mixmonitor.c:   == Begin MixMonitor Recording SIP/out-00000020
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:1] Set("SIP/out-00000020", "DEXTEN=1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:2] Set("SIP/out-00000020", "DIALSTATUS_CW=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:3] GosubIf("SIP/out-00000020", "0?screen,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:4] GosubIf("SIP/out-00000020", "0?cf,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:5] GotoIf("SIP/out-00000020", "1?skip1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-dial-one,s,8)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:8] GotoIf("SIP/out-00000020", "0?nodial") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:9] GotoIf("SIP/out-00000020", "0?continue") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:10] Set("SIP/out-00000020", "EXTHASCW=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:11] GotoIf("SIP/out-00000020", "1?next1:cwinusebusy") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-dial-one,s,12)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:12] GotoIf("SIP/out-00000020", "0?docfu:skip3") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-dial-one,s,16)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:16] GotoIf("SIP/out-00000020", "1?next2:continue") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-dial-one,s,17)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:17] GotoIf("SIP/out-00000020", "1?continue") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-dial-one,s,25)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:25] GotoIf("SIP/out-00000020", "0?nodial") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:26] GosubIf("SIP/out-00000020", "1?dstring,1:dlocal,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:1] Set("SIP/out-00000020", "DSTRING=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:2] Set("SIP/out-00000020", "DEVICES=1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:3] ExecIf("SIP/out-00000020", "0?Return()") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:4] ExecIf("SIP/out-00000020", "0?Set(DEVICES=000)") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:5] Set("SIP/out-00000020", "LOOPCNT=1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:6] Set("SIP/out-00000020", "ITER=1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:7] Set("SIP/out-00000020", "THISDIAL=SIP/1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:8] GosubIf("SIP/out-00000020", "1?zap2dahdi,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:1] ExecIf("SIP/out-00000020", "0?Return()") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:2] Set("SIP/out-00000020", "NEWDIAL=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:3] Set("SIP/out-00000020", "LOOPCNT2=1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:4] Set("SIP/out-00000020", "ITER2=1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:5] Set("SIP/out-00000020", "THISPART2=SIP/1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:6] ExecIf("SIP/out-00000020", "0?Set(THISPART2=DAHDI/1000)") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:7] Set("SIP/out-00000020", "NEWDIAL=SIP/1000&") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:8] Set("SIP/out-00000020", "ITER2=2") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:9] GotoIf("SIP/out-00000020", "0?begin2") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:10] Set("SIP/out-00000020", "THISDIAL=SIP/1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [zap2dahdi@macro-dial-one:11] Return("SIP/out-00000020", "") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:9] Set("SIP/out-00000020", "DSTRING=SIP/1000&") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:10] Set("SIP/out-00000020", "ITER=2") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:11] GotoIf("SIP/out-00000020", "0?begin") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:12] Set("SIP/out-00000020", "DSTRING=SIP/1000") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [dstring@macro-dial-one:13] Return("SIP/out-00000020", "") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:27] GotoIf("SIP/out-00000020", "0?nodial") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:28] GotoIf("SIP/out-00000020", "1?skiptrace") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-dial-one,s,30)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:30] Set("SIP/out-00000020", "D_OPTIONS=tr") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:31] ExecIf("SIP/out-00000020", "0?SIPAddHeader(Alert-Info: )") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:32] ExecIf("SIP/out-00000020", "0?SIPAddHeader()") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:33] ExecIf("SIP/out-00000020", "0?Set(CHANNEL(musicclass)=)") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:34] GosubIf("SIP/out-00000020", "0?qwait,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:35] Set("SIP/out-00000020", "__CWIGNORE=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:36] Set("SIP/out-00000020", "__KEEPCID=TRUE") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:37] Dial("SIP/out-00000020", "SIP/1000,"",tr") in new stack
[Nov  9 14:30:43] WARNING[10730] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Unknown)
[Nov  9 14:30:43] VERBOSE[10730] app_dial.c:   == Everyone is busy/congested at this time (1:0/0/1)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:38] ExecIf("SIP/out-00000020", "0?Set(DIALSTATUS=)") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:39] GosubIf("SIP/out-00000020", "0?s-CHANUNAVAIL,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-dial-one:40] MacroExit("SIP/out-00000020", "") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:10] GotoIf("SIP/out-00000020", "0?exit") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:11] Set("SIP/out-00000020", "SV_DIALSTATUS=CHANUNAVAIL") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:12] GosubIf("SIP/out-00000020", "0?docfu,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:13] GosubIf("SIP/out-00000020", "0?docfb,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:14] Set("SIP/out-00000020", "DIALSTATUS=CHANUNAVAIL") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:15] NoOp("SIP/out-00000020", "Voicemail is 'novm'") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-exten-vm:16] GotoIf("SIP/out-00000020", "1?s-CHANUNAVAIL,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-exten-vm,s-CHANUNAVAIL,1)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s-CHANUNAVAIL@macro-exten-vm:1] NoOp("SIP/out-00000020", "IVR_RETVM:  IVR_CONTEXT: ") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s-CHANUNAVAIL@macro-exten-vm:2] GotoIf("SIP/out-00000020", "0?exit,1") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s-CHANUNAVAIL@macro-exten-vm:3] PlayTones("SIP/out-00000020", "congestion") in new stack
[Nov  9 14:30:43] WARNING[10730] translate.c: no samples for ulawtolin
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s-CHANUNAVAIL@macro-exten-vm:4] Congestion("SIP/out-00000020", "10") in new stack
[Nov  9 14:30:43] VERBOSE[10730] app_macro.c:   == Spawn extension (macro-exten-vm, s-CHANUNAVAIL, 4) exited non-zero on 'SIP/out-00000020' in macro 'exten-vm'
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:   == Spawn extension (from-did-direct, 1000, 1) exited non-zero on 'SIP/out-00000020'
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [h@from-did-direct:1] Macro("SIP/out-00000020", "hangupcall,") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:1] GotoIf("SIP/out-00000020", "0?endmixmoncheck") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:2] Set("SIP/out-00000020", "MIXMON_CALLFILENAME=/var/spool/asterisk/monitor/20121109-143043-1352457043.32.wav") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:3] GotoIf("SIP/out-00000020", "1?defaultmixmondir") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-hangupcall,s,5)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:5] System("SIP/out-00000020", "test -e /var/spool/asterisk/monitor/20121109-143043-1352457043.32.wav") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:6] NoOp("SIP/out-00000020", "SYSTEMSTATUS = APPERROR") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:7] GotoIf("SIP/out-00000020", "0?endmixmoncheck") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:8] Set("SIP/out-00000020", "CDR(userfield)=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:9] NoOp("SIP/out-00000020", "End of MIXMON check") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:10] GotoIf("SIP/out-00000020", "1?nomeetmemon") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-hangupcall,s,15)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:15] NoOp("SIP/out-00000020", "MEETME_RECORDINGFILE=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:16] GotoIf("SIP/out-00000020", "1?noautomon") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-hangupcall,s,18)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:18] NoOp("SIP/out-00000020", "TOUCH_MONITOR_OUTPUT=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:19] GotoIf("SIP/out-00000020", "1?noautomon2") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-hangupcall,s,25)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:25] NoOp("SIP/out-00000020", "MONITOR_FILENAME=") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:26] GotoIf("SIP/out-00000020", "1?skiprg") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-hangupcall,s,29)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:29] GotoIf("SIP/out-00000020", "1?skipblkvm") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-hangupcall,s,32)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:32] GotoIf("SIP/out-00000020", "1?theend") in new stack
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Goto (macro-hangupcall,s,34)
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:     -- Executing [s@macro-hangupcall:34] Hangup("SIP/out-00000020", "") in new stack
[Nov  9 14:30:43] VERBOSE[10730] app_macro.c:   == Spawn extension (macro-hangupcall, s, 34) exited non-zero on 'SIP/out-00000020' in macro 'hangupcall'
[Nov  9 14:30:43] VERBOSE[10730] pbx.c:   == Spawn extension (from-did-direct, h, 1) exited non-zero on 'SIP/out-00000020'
[Nov  9 14:30:43] VERBOSE[10731] app_mixmonitor.c:   == End MixMonitor Recording SIP/out-00000020
it_tech
Сообщение it_tech »
лог если перенаправление делаю на Ring Group 600, в которой добавлен 1000 и 1001
[Nov  9 14:35:25] VERBOSE[4546] netsock2.c:   == Using SIP RTP TOS bits 184
[Nov  9 14:35:25] VERBOSE[4546] netsock2.c:   == Using SIP RTP CoS mark 5
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk-sip-out:1] Set("SIP/out-00000021", "GROUP()=OUT_2") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk-sip-out:2] Goto("SIP/out-00000021", "from-trunk,sipid,1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (from-trunk,sipid,1)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk:1] Set("SIP/out-00000021", "__FROM_DID=sipid") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk:2] Gosub("SIP/out-00000021", "app-blacklist-check,s,1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@app-blacklist-check:1] GotoIf("SIP/out-00000021", "0?blacklisted") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@app-blacklist-check:2] Set("SIP/out-00000021", "CALLED_BLACKLIST=1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@app-blacklist-check:3] Return("SIP/out-00000021", "") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk:3] ExecIf("SIP/out-00000021", "0 ?Set(CALLERID(name)=0041762633)") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk:4] Set("SIP/out-00000021", "__CALLINGPRES_SV=allowed_not_screened") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk:5] Set("SIP/out-00000021", "CALLERPRES()=allowed_not_screened") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [sipid@from-trunk:6] Goto("SIP/out-00000021", "ext-group,600,1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (ext-group,600,1)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:1] Macro("SIP/out-00000021", "user-callerid,") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:1] Set("SIP/out-00000021", "AMPUSER=0041762633") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:2] GotoIf("SIP/out-00000021", "0?report") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:3] ExecIf("SIP/out-00000021", "1?Set(REALCALLERIDNUM=0041762633)") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:4] Set("SIP/out-00000021", "AMPUSER=") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:5] Set("SIP/out-00000021", "AMPUSERCIDNAME=") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:6] GotoIf("SIP/out-00000021", "1?report") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (macro-user-callerid,s,10)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:10] GotoIf("SIP/out-00000021", "0?continue") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:11] Set("SIP/out-00000021", "__TTL=64") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:12] GotoIf("SIP/out-00000021", "1?continue") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (macro-user-callerid,s,19)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:19] Set("SIP/out-00000021", "CALLERID(number)=0041762633") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:20] Set("SIP/out-00000021", "CALLERID(name)=0041762633") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-user-callerid:21] NoOp("SIP/out-00000021", "Using CallerID "0041762633" <0041762633>") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:2] GotoIf("SIP/out-00000021", "1?skipdb") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (ext-group,600,4)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:4] Set("SIP/out-00000021", "__NODEST=") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:5] Set("SIP/out-00000021", "__BLKVM_OVERRIDE=BLKVM/600/SIP/out-00000021") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:6] Set("SIP/out-00000021", "__BLKVM_BASE=600") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:7] Set("SIP/out-00000021", "DB(BLKVM/600/SIP/out-00000021)=TRUE") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:8] Set("SIP/out-00000021", "RRNODEST=") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:9] Set("SIP/out-00000021", "__NODEST=600") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:10] GosubIf("SIP/out-00000021", "0?sub-rgsetcid,s,1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:11] Set("SIP/out-00000021", "RecordMethod=Group") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:12] Macro("SIP/out-00000021", "record-enable,1000,Group") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:1] GotoIf("SIP/out-00000021", "1?check") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (macro-record-enable,s,4)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:4] ExecIf("SIP/out-00000021", "0?MacroExit()") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:5] GotoIf("SIP/out-00000021", "1?Group:OUT") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (macro-record-enable,s,6)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:6] Set("SIP/out-00000021", "LOOPCNT=1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:7] Set("SIP/out-00000021", "ITER=1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:8] GotoIf("SIP/out-00000021", "0?continue") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:9] Set("SIP/out-00000021", "TEXTEN=1000") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:10] NoOp("SIP/out-00000021", "Recording enable for 1000") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:11] Set("SIP/out-00000021", "CALLFILENAME=g1000-20121109-143525-1352457325.33") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:12] Goto("SIP/out-00000021", "record") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (macro-record-enable,s,23)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:23] MixMonitor("SIP/out-00000021", "g1000-20121109-143525-1352457325.33.wav,,") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:24] Set("SIP/out-00000021", "CDR(userfield)=audio:g1000-20121109-143525-1352457325.33.wav") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-record-enable:25] MacroExit("SIP/out-00000021", "") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:13] Set("SIP/out-00000021", "RingGroupMethod=ringall") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:14] Macro("SIP/out-00000021", "dial,20,tr,1000") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-dial:1] GotoIf("SIP/out-00000021", "1?dial") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (macro-dial,s,3)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-dial:3] AGI("SIP/out-00000021", "dialparties.agi") in new stack
[Nov  9 14:35:25] VERBOSE[10973] app_mixmonitor.c:   == Begin MixMonitor Recording SIP/out-00000021
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:  dialparties.agi: Starting New Dialparties.agi
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:  dialparties.agi: Caller ID name is '0041762633' number is '0041762633'
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:  dialparties.agi: Methodology of ring is  'ringall'
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- dialparties.agi: Added extension 1000 to extension map
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- dialparties.agi: Extension 1000 cf is disabled
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- dialparties.agi: Extension 1000 do not disturb is disabled
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:  dialparties.agi: EXTENSION_STATE: 4 (UNAVAILABLE)
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:  dialparties.agi: Extension 1000 has ExtensionState: 4
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- dialparties.agi: Checking CW and CFB status for extension 1000
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- dialparties.agi: dbset CALLTRACE/1000 to 0041762633
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- dialparties.agi: Filtered ARG3: 1000
[Nov  9 14:35:25] VERBOSE[10968] res_agi.c:     -- <SIP/out-00000021>AGI Script dialparties.agi completed, returning 0
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-dial:7] Dial("SIP/out-00000021", "SIP/1000,20,trM(auto-blkvm)") in new stack
[Nov  9 14:35:25] WARNING[10968] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Unknown)
[Nov  9 14:35:25] VERBOSE[10968] app_dial.c:   == Everyone is busy/congested at this time (1:0/0/1)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-dial:8] Set("SIP/out-00000021", "DIALSTATUS=CHANUNAVAIL") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [s@macro-dial:9] GosubIf("SIP/out-00000021", "0?CHANUNAVAIL,1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:15] Set("SIP/out-00000021", "RingGroupMethod=") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:16] GotoIf("SIP/out-00000021", "0?nodest") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:17] Set("SIP/out-00000021", "__NODEST=") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:18] NoOp("SIP/out-00000021", "Deleting: BLKVM/600/SIP/out-00000021 TRUE") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [600@ext-group:19] Goto("SIP/out-00000021", "app-blackhole,ring,1") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Goto (app-blackhole,ring,1)
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [ring@app-blackhole:1] NoOp("SIP/out-00000021", "Blackhole Dest: Ring") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [ring@app-blackhole:2] Answer("SIP/out-00000021", "") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [ring@app-blackhole:3] PlayTones("SIP/out-00000021", "ring") in new stack
[Nov  9 14:35:25] VERBOSE[10968] pbx.c:     -- Executing [ring@app-blackhole:4] Wait("SIP/out-00000021", "300") in new stack
[Nov  9 14:35:52] VERBOSE[10968] pbx.c:   == Spawn extension (app-blackhole, ring, 4) exited non-zero on 'SIP/out-00000021'
[Nov  9 14:35:52] VERBOSE[10973] app_mixmonitor.c:   == MixMonitor close filestream
[Nov  9 14:35:52] VERBOSE[10973] app_mixmonitor.c:   == End MixMonitor Recording SIP/out-00000021
it_tech
Сообщение it_tech »
тема закрыта
разобрался
всем спасибо
опишите для потомков ?!
