FreePBX intra-company route преобразование кодеков
Eugene
Re: FreePBX intra-company route преобразование кодеков
Сообщение Eugene »
Вот, для примера, удачный звонок, настройки теже, только на sip-транке стоит alaw
    -- Executing [s@macro-dialout-trunk:19] Dial("SIP/192.168.65.100-00000003", "DAHDI/g0/100,300,Ttr") in new stack
1 -- Making new call for cref 32772
1
1 > DL-DATA request
1 > Protocol Discriminator: Q.931 (8)  len=48
1 > TEI=0 Call Ref: len= 2 (reference 4/0x4) (Sent from originator)
1 > Message Type: SETUP (5)
1 TEI=0 Transmitting N(S)=9, window is open V(A)=9 K=7
1
1 > [04 03 80 90 a3]
1 > Bearer Capability (len= 5) [ Ext: 1  Q.931 Std: 0  Info transfer capability: Speech (0)
1 >                              Ext: 1  Trans mode/rate: 64kbps, circuit-mode (16)
1 >                                User information layer 1: A-Law (35)
1 > [18 03 a9 83 81]
1 > Channel ID (len= 5) [ Ext: 1  IntID: Implicit  Other(PRI)  Spare: 0  Exclusive  Dchan: 0
1 >                       ChanSel: As indicated in following octets
1 >                       Ext: 1  Coding: 0  Number Specified  Channel Type: 3
1 >                       Ext: 1  Channel: 1 Type: NET]
1 > [28 0a 33 35 31 39 33 34 32 30 30 32]
1 > Display (len=10) [ XXXXXXXX ]
1 > [6c 0c 21 81 33 35 31 39 33 34 32 30 30 32]
1 > Calling Number (len=14) [ Ext: 0  TON: National Number (2)  NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
1 >                           Presentation: Presentation permitted, user number passed network screening (1)  'XXXXXXXX' ]
1 > [70 04 a1 31 30 30]
1 > Called Number (len= 6) [ Ext: 1  TON: National Number (2)  NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)  '100' ]
1 > [a1]
1 > Sending Complete (len= 1)
1 q931.c:5039 q931_setup: Call 32772 enters state 1 (Call Initiated).  Hold state: Idle
    -- Called g0/100
1
1 < Protocol Discriminator: Q.931 (8)  len=10
1 < TEI=0 Call Ref: len= 2 (reference 4/0x4) (Sent to originator)
1 < Message Type: CALL PROCEEDING (2)
1 < [18 03 a9 83 81]
1 < Channel ID (len= 5) [ Ext: 1  IntID: Implicit  Other(PRI)  Spare: 0  Exclusive  Dchan: 0
1 <                       ChanSel: As indicated in following octets
1 <                       Ext: 1  Coding: 0  Number Specified  Channel Type: 3
1 <                       Ext: 1  Channel: 1 Type: NET]
1 Received message for call 0xb4541098 on 0x8a38f28 TEI/SAPI 0/0, call->pri is 0x8a38f28 TEI/SAPI 0/0
1 -- Processing IE 24 (cs0, Channel Identification)
1 q931.c:7104 post_handle_q931_message: Call 32772 enters state 3 (Outgoing Call Proceeding).  Hold state: Idle
Span: 1 Processing event: PRI_EVENT_PROCEEDING
    -- DAHDI/i1/100-4 is proceeding passing it to SIP/192.168.65.100-00000003
1
1 < Message Type: ALERTING (1)
1 q931.c:6983 post_handle_q931_message: Call 32772 enters state 4 (Call Delivered).  Hold state: Idle
Span: 1 Processing event: PRI_EVENT_RINGING
    -- DAHDI/i1/100-4 is ringing
Eugene писал(а):Как бы вам сказать, смущало бы, если б звонки в сторону LG не проходили совсем, однако они проходят с внутренних сипфонов астера, установке кодека сип-транка в alaw или снятии галки intra-company. Сменил на National, разницы никакой
Сделайте чистый эксперимент:
1. создайте прямой Dial в контексте from-pstn-custom хотя бы вида
exten => ТУТ_ВАШ_DID,1, Dial(SIP/100)
2. установите для сип-транка кодек только g729 и делайте звонок. При этом смотрим sip show channels для уверенности, sip debug IP_PROVIDER и pri debug span1 (это же у вас LG по Е1 соединяется?)
3. Потом для полноты картины переключайте на alaw, и то же самое.
Если даже при этом эксперименте будет наблюдаться эффект, - то это баг Asterisk 1.8
Если не будет наблюдаться - то это баг freePBX 2.8
Eugene
Сообщение Eugene »
Сделаю, только придется ждать выходных. Система рабочая
