Asterisk 16 and Asterisk 13 с PJSIP. extensions.conf
olegsenin
Re: Asterisk 16 and Asterisk 13 с PJSIP. extensions.conf
Сообщение olegsenin »
Нашел я таки единомышленников ))
Проблема не только у меня
https://community.asterisk.org/t/cid-ma ... 6/82744/33
Ток вот отписаться не могу там, аккаунт заблочили сразу почему то ((( :evil:
olegsenin
Итого:
1. Пробовал на версии 16.0 и 16.8
2. Почему то при наличии общей строки "обезличенной", без фильтра по CID, все начинает работать
3. ...
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: pjsip_wizard.conf
[user_defaults](!)
type = wizard
transport = ipv4
accepts_registrations = yes
sends_registrations = no
accepts_auth = yes
sends_auth = no
has_hint = yes
hint_context = DLPN_DialPlan1
hint_application = Gosub(stdexten,${EXTEN},1(${HINT}))
endpoint/context = DLPN_DialPlan1
endpoint/allow_subscribe = yes
endpoint/allow = !all,alaw
endpoint/direct_media = yes
endpoint/force_rport = yes
endpoint/disable_direct_media_on_nat = yes
endpoint/direct_media_method = invite
endpoint/ice_support = yes
endpoint/moh_suggest = default
endpoint/send_rpid = yes
endpoint/rewrite_contact = yes
endpoint/send_pai = yes
endpoint/allow_transfer = yes
endpoint/trust_id_inbound = yes
endpoint/device_state_busy_at = 1
endpoint/trust_id_outbound = yes
endpoint/send_diversion = yes
aor/qualify_frequency = 30
aor/authenticate_qualify = no
aor/max_contacts = 1
aor/remove_existing = yes
aor/minimum_expiration = 30
aor/support_path = yes
[bob](user_defaults)
hint_exten = 1000
inbound_auth/username = bob
inbound_auth/password = bobspassword
[alice](user_defaults)
hint_exten = 1001
endpoint/callerid = Alice <1001>
endpoint/allow = !all,ulaw
inbound_auth/username = alice
inbound_auth/password = alicespassword
has_phoneprov = yes
phoneprov/MAC = deadbeef4dad
При наличии строки
exten => _8[89]XXXXXXXXX,1,NoOp(${CALLERID(all)} arg1 ${ARG1} arg2 ${ARG2} arg3 ${ARG3})
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: extensions.conf
[DLPN_DialPlan1]
exten => _8[89]XXXXXXXXX/_2[3-5]XX,1,GoSub(sub-dial-out,${EXTEN},1(484848${CALLERID(num)}))
exten => _8[89]XXXXXXXXX/bob,1,NoOp(${CALLERID(all)} arg1 ${ARG1} arg2 ${ARG2} arg3 ${ARG3})
same => n,NoOp(Dialing out from ${CALLERID(all)} to (${EXTEN}))
same => n,Dial(PJSIP/${EXTEN}@smg-rostelecom)
same => n,Goto(dial-status,${DIALSTATUS},1)
exten => _8[89]XXXXXXXXX/1000,1,NoOp(${CALLERID(all)} arg1 ${ARG1} arg2 ${ARG2} arg3 ${ARG3})
exten => _8[89]XXXXXXXXX/2685,1,GoSub(sub-dial-out,${EXTEN},1(484848${CALLERID(num)},4848484848))
[dial-status]
exten => BUSY,1,NoCDR()
same => n,Playback(ru/number)
same => n,Playback(ru/vm-isonphone)
same => n,Playback(ru/pls-try-call-later)
same => n,Hangup
exten => NOANSWER,1,NoCDR()
same => n,Playback(ru/number-not-answering)
same => n,Hangup
exten => CANCEL,1,NoCDR()
same => n,,Playback(vympel/call-cancelled)
same => n,Hangup
exten => CONGESTION,1,NoCDR()
same => n,Playback(ru/something-terribly-wrong)
same => n,Playback(ru/check-number-dial-again)
same => n,Hangup
exten => CHANUNAVAIL,1,NoCDR()
same => n,Hangup
exten => DONTCALL,1,NoCDR()
same => n,Playback(vympel/call-cancelled)
same => n,Hangup
exten => TORTURE,1,NoCDR()
same => n,Hangup
exten => INVALIDARGS,1,Playback(ru/cancelled)
same => n,Hangup
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: Выхлоп такой
== Setting global variable 'SIPDOMAIN' to '10.40.8.162'
-- Executing [89051333333@DLPN_DialPlan1:1]NoOp("PJSIP/bob-00000001", ""bob" <bob> arg1 arg2 arg3 ") in new stack
-- Executing [89051333333@DLPN_DialPlan1:2] NoOp("PJSIP/bob-00000001", "Dialing out from "bob" <bob> to (89051333333)") in new stack
-- Executing [89051333333@DLPN_DialPlan1:3] Dial("PJSIP/bob-00000001", "PJSIP/89051333333@smg-rostelecom") in new stack
[Mar 3 13:45:58] ERROR[42656]: chan_pjsip.c:2486 request: Unable to create PJSIP channel - endpoint 'smg-rostelecom' was not found
[Mar 3 13:45:58] WARNING[42962][C-00000002]: app_dial.c:2516 dial_exec_full: Unable to create channel of type 'PJSIP' (cause 3 - No route to destination)
-- Executing [89051333333@DLPN_DialPlan1:4] Goto("PJSIP/bob-00000001", "dial-status,CHANUNAVAIL,1") in new stack
-- Goto (dial-status,CHANUNAVAIL,1)
-- Executing [CHANUNAVAIL@dial-status:1] NoCDR("PJSIP/bob-00000001", "") in new stack
-- Executing [CHANUNAVAIL@dial-status:2] Playback("PJSIP/bob-00000001", "ru/number") in new stack
> 0x7f0540039e00 -- Strict RTP learning after remote address set to: 10.40.4.223:62778
> 0x7f0540039e00 -- Strict RTP switching to RTP target address 10.40.4.223:62778 as source
-- <PJSIP/bob-00000001> Playing 'ru/number.alaw' (language 'en')
-- Executing [CHANUNAVAIL@dial-status:3] Playback("PJSIP/bob-00000001", "ru/vm-isonphone") in new stack
-- <PJSIP/bob-00000001> Playing 'ru/vm-isonphone.alaw' (language 'en')
-- Executing [CHANUNAVAIL@dial-status:4] Playback("PJSIP/bob-00000001", "ru/pls-try-call-later") in new stack
-- <PJSIP/bob-00000001> Playing 'ru/pls-try-call-later.alaw' (language 'en')
-- Executing [CHANUNAVAIL@dial-status:5] Hangup("PJSIP/bob-00000001", "") in new stack
== Spawn extension (dial-status, CHANUNAVAIL, 5) exited non-zero on 'PJSIP/bob-00000001']
При закомментированной строке exten => _8[89]XXXXXXXXX,1,NoOp(${CALLERID(all)} arg1 ${ARG1} arg2 ${ARG2} arg3 ${ARG3})
[DLPN_DialPlan1]
; exten => _8[89]XXXXXXXXX,1,NoOp(${CALLERID(all)} arg1 ${ARG1} arg2 ${ARG2} arg3 ${ARG3})
[dial-status]
same => n,Hangup
same => n,Hangup
same => n,Hangup
same => n,Hangup
same => n,Hangup
same => n,Hangup
same => n,Hangup
same => n,Hangup
[Mar 3 13:46:24] NOTICE[42656]: res_pjsip_session.c:2963 new_invite: Call from 'bob' (UDP:10.40.4.223:51873) to extension '89051333333' rejected because extension not found in context 'DLPN_DialPlan1'.
Перевести на русский?
olegsenin
Zavr2008, это тестовый сервер и транк там заведомо не рабочий.
Проблема в другом, в том что шаблон вида _Z./ZXXX с драйвером PJSIP работает только тогда когда есть в этом же контексте строка без фильтра, т.е. просто _Z.
Правильный синтаксис - залог успеха.
exten => _Z./_ZXXX,1,далее куда надо
Павлины говорите)
Нужно правильные тесты ставить. Да еще и книжку почитать, чтобы не орать "Asterisk - глючит".
olegsenin
Да пожалуйста:
[DLPN_DialPlan1]
exten => _8[89]XXXXXXXXX/_2000,1,Answer()
same => n,Verbose(111111111111111111 CID ${CALLERID(num)})
same => n,Dumpchan()
same => n,Wait(1)
same => n,Hangup
exten => _8[89]XXXXXXXXX/2000,1,Answer()
same => n,Verbose(44444444444 CID ${CALLERID(num)})
same => n,Wait(1)
same => n,Hangup
exten => _8[89]XXXXXXXXX,1,Answer()
same => n,Verbose(!!!!!!!!!!!! CID ${CALLERID(num)})
same => n,Wait(1)
same => n,Hangup
-- Executing [89051333333@DLPN_DialPlan1:1] Answer("PJSIP/2000-00000004", "") in new stack
> 0x7f262405f0d0 -- Strict RTP learning after remote address set to: 10.40.4.223:50836
> 0x7f262405f0d0 -- Strict RTP switching to RTP target address 10.40.4.223:50836 as source
-- Executing [89051333333@DLPN_DialPlan1:2] Verbose("PJSIP/2000-00000004", "44444444444 CID 2000") in new stack
-- Executing [89051333333@DLPN_DialPlan1:3] DumpChan("PJSIP/2000-00000004", "") in new stack
Dumping Info For Channel: PJSIP/2000-00000004:
Info:
Name= PJSIP/2000-00000004
Type= PJSIP
UniqueID= 1583394430.6
LinkedID= 1583394430.6
CallerIDNum= 2000
CallerIDName= Ananas
ConnectedLineIDNum= (N/A)
ConnectedLineIDName=(N/A)
DNIDDigits= 89051333333
RDNIS= (N/A)
Parkinglot=
Language= en
State= Up (6)
Rings= 1
NativeFormat= (alaw)
WriteFormat= alaw
ReadFormat= alaw
RawWriteFormat= alaw
RawReadFormat= alaw
WriteTranscode= No
ReadTranscode= No
1stFileDescriptor= -1
Framesin= 15
Framesout= 0
TimetoHangup= 0
ElapsedTime= 0h0m0s
BridgeID= (Not bridged)
Context= DLPN_DialPlan1
Extension= 89051333333
Priority= 3
CallGroup=
PickupGroup=
Application= DumpChan
Data= (Empty)
Blocking_in= (Not Blocking)
Variables:
-- Executing [89051333333@DLPN_DialPlan1:4] Wait("PJSIP/2000-00000004", "1") in new stack
-- Executing [89051333333@DLPN_DialPlan1:5] Hangup("PJSIP/2000-00000004", "") in new stack
== Spawn extension (DLPN_DialPlan1, 89051333333, 5) exited non-zero on 'PJSIP/2000-00000004'
Убираем нижнюю строку
[DLPN_DialPlan1]
same => n,Wait(1)
same => n,Hangup
same => n,Wait(1)
same => n,Hangup
; exten => _8[89]XXXXXXXXX,1,Answer()
; same => n,Verbose(!!!!!!!!!!!! CID ${CALLERID(num)})
; same => n,Dumpchan()
; same => n,Wait(1)
; same => n,Hangup
[Mar 5 10:53:05] NOTICE[2216]: res_pjsip_session.c:3078 new_invite: Call from '2000' (UDP:10.40.4.223:54005) to extension '89051333333' rejected because extension not found in context 'DLPN_DialPlan1'.
[user_defaults](!)
type = wizard
transport = ipv4
accepts_auth = yes
sends_auth = no
has_hint = yes
hint_exten = 1000
hint_exten = 1001
[2000](user_defaults)
hint_exten = 2000
endpoint/callerid = Ananas <2000>
inbound_auth/username = 2000
inbound_auth/password = Ananas2000
Просто проверяйте синтаксис командой
CLI> dialplan show [89051333333@DLPN_DialPlan1
По возможности не надо результаты экспериментов вываливать на всеобщий разбор, это же вы из любопытства там играетесь? Это не есть проблема.
olegsenin
ded, не очень понял что ты имеешь ввиду по поводу всеобщего обзора.
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: dialplan show
aster16*CLI> dialplan show 89051333333@DLPN_DialPlan1
[ Context 'DLPN_DialPlan1' created by 'res_pjsip_config_wizard' ]
'_8[89]XXXXXXXXX' (CID match '2000') => 1. Answer() [extensions.conf:7]
2. Verbose(44444444444 CID ${CALLERID(num)}) [extensions.conf:8]
3. Dumpchan() [extensions.conf:9]
4. Wait(1) [extensions.conf:10]
5. Hangup() [extensions.conf:11]
'_8[89]XXXXXXXXX' (CID match '_2000') => 1. Answer() [extensions.conf:2]
2. Verbose(111111111111111111 CID ${CALLERID(num)}) [extensions.conf:3]
3. Dumpchan() [extensions.conf:4]
4. Wait(1) [extensions.conf:5]
5. Hangup() [extensions.conf:6]
-= 2 extensions (10 priorities) in 1 context. =-
aster16*CLI> dialplan show DLPN_DialPlan1
'1000' => hint: PJSIP/bob [res_pjsip_config_wizard]
1. Gosub(stdexten,${EXTEN},1(${HINT})) [res_pjsip_config_wizard]
'1001' => hint: PJSIP/2000 [res_pjsip_config_wizard]
'2000' => hint: PJSIP/2000 [res_pjsip_config_wizard]
-= 5 extensions (16 priorities) in 1 context. =-
[Mar 5 11:23:58] NOTICE[2216]: res_pjsip_session.c:3078 new_invite: Call from '2000' (UDP:10.40.4.223:54005) to extension '89051333333' rejected because extension not found in context 'DLPN_DialPlan1'.
olegseninвот вижу, что просто играетесь:
olegsenin писал(а):Объективных причин нет. но думаю надо ж попробовать, не зря ж наверное программисты пилят pjsip?
При этом нет понимания в синтаксисе и терминах.
Знак подчёркивания, который говорит, что будет шаблон. А не нижняя строка! Нижняя строка вот тут -
7894г5щепшутозкыпщшозкуе89гь-9ц 45хк9ще4ц5ен9 ц4569ншц4950 6ене90 огцх4590 енпьами
И когда указываете _2000 то это не шаблон, а твёрдый CID такой для Астериска. Он и ищет его при звонке. Шаблон включает в себя буквы Z, N, X.
Вы в одном месте указываете так, в другом - эдак.
Занимайтесь этим не выгружая всё это сюда, ибо - зачем?
