Трудно не заметить!Уважаемые, чего я не замечаю ? подскажите плиз!
Apr 26 16:59:45 maral kernel: dahdi: Registered tone zone 0 (United States / North America)
Apr 26 16:59:45 maral kernel: NOTICE-dahdi: 3: dahdi_ioctl_chanconfig: bad sigtype. sigcap: 157f8, sigtype: 2004.
Apr 26 16:59:45 maral kernel: NOTICE-dahdi: 4: dahdi_ioctl_chanconfig: bad sigtype. sigcap: 16785, sigtype: 1020.
Apr 26 16:59:45 maral kernel: dahdi: Unregistering tone zone 0 (United States / North America)
Apr 26 16:59:45 maral kernel: dahdi: Registered tone zone 0 (United States / North America)Код: Выделить всё
fxoks=3
echocanceller=mg2,3
fxsks=4
echocanceller=mg2,4
# Global data
loadzone = ru
defaultzone = ru
[ru]
; References:
; http://www.minsvyaz.ru/site.shtml?id=1806
; http://www.aboutphone.info/lib/gost/45-223-2001.html
description = Russian Federation / ex Soviet Union
ringcadence = 1000,4000
dial = 425
busy = 425/350,0/350
ring = 425/1000,0/4000
congestion = 425/175,0/175
callwaiting = 425/200,0/5000
record = 1400/400,0/15000
info = 950/330,1400/330,1800/330,0/1000
dialrecall = 425/400,0/40
stutter = !425/100,!0/100,!425/100,!0/100,!425/100,!0/100,!425/100,!0/100,!425/100,!0/100,!425/100,!0/100,425
Loading DAHDI hardware modules:
wctdm24xxp: [ OK ]
wctdm: [ OK ]
Running dahdi_cfg: [ OK ]
Apr 26 20:42:07 maral kernel: dahdi: Telephony Interface Registered on major 196
Apr 26 20:42:07 maral kernel: dahdi: Version: 2.6.1
Apr 26 20:42:07 maral kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0003)
Apr 26 20:42:07 maral kernel: ACPI: PCI Interrupt 0000:01:01.0[A] -> GSI 22 (level, low) -> IRQ 209
Apr 26 20:42:08 maral kernel: wctdm24xxp 0000:01:01.0: ProSLIC on module 2 failed to powerup within 503 ms (0 mV only)
Apr 26 20:42:08 maral kernel: -- DID YOU REMEMBER TO PLUG IN THE HD POWER CABLE TO THE TDM CARD??
Apr 26 20:42:08 maral kernel: wctdm24xxp 0000:01:01.0: Unable to do INITIAL ProSLIC powerup on module 2
Apr 26 20:42:08 maral kernel: wctdm24xxp 0000:01:01.0: vpmoct: Detected firmware v1.12 Serial: 5VPMOCT032LF-B DM99134770067
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: ProSLIC on module 2 failed to powerup within 504 ms (0 mV only)
Apr 26 20:42:09 maral kernel: -- DID YOU REMEMBER TO PLUG IN THE HD POWER CABLE TO THE TDM CARD??
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: Unable to do INITIAL ProSLIC powerup on module 2
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: Port 3: FAILED FXS (FCC)
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: Port 1: Not installed
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: Port 2: Not installed
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: Port 3: Installed -- AUTO FXS/DPO
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: Port 4: Installed -- AUTO FXO (FCC mode)
Apr 26 20:42:09 maral kernel: dahdi: Registered Span 1 ('WCTDM/0') with 4 channels
Apr 26 20:42:09 maral kernel: dahdi: Master changed to WCTDM/0
Apr 26 20:42:09 maral kernel: wctdm24xxp 0000:01:01.0: Found a Wildcard TDM: Wildcard TDM410P (0 BRI spans, 2 analog channels)
Apr 26 20:42:09 maral kernel: dahdi: Registered tone zone 0 (United States / North America)
Apr 26 20:42:09 maral kernel: NOTICE-dahdi: 3: dahdi_ioctl_chanconfig: bad sigtype. sigcap: 157f8, sigtype: 2004.
Apr 26 20:42:09 maral kernel: NOTICE-dahdi: 4: dahdi_ioctl_chanconfig: bad sigtype. sigcap: 16785, sigtype: 1020.
Apr 26 20:42:09 maral kernel: dahdi: Unregistering tone zone 0 (United States / North America)
Apr 26 20:42:09 maral kernel: dahdi: Registered tone zone 40 (Russian Federation)
[1]
active=yes
alarms=OK
description=Wildcard TDM410P
name=WCTDM/0
manufacturer=Digium
devicetype=Wildcard TDM410P (VPMOCT032)
location=PCI Bus 01 Slot 02
basechan=1
totchans=4
irq=0
type=analog
port=1,none
port=2,none
port=3,FXS
port=4,FXOКод: Выделить всё
;;; line="3 WCTDM/0/2 FXOKS (In use) (EC: VPMOCT032 - INACTIVE)"
signalling=fxo_ks
callerid="Channel 3" <4003>
mailbox=4003
group=5
context=from-internal
channel => 3
callerid=
mailbox=
group=
context=default
;;; line="4 WCTDM/0/3 FXSKS (In use) (EC: VPMOCT032 - INACTIVE)"
signalling=fxs_ks
callerid=asreceived
group=0
context=from-pstn
channel => 4
callerid=
group=
context=default
[logfiles]
console => notice,warning,error,debug
messages => notice,warning,error
full => notice,warning,error,debug,verbose,dtmf,fax
maral*CLI> core set debug 10
Core debug was 0 and is now 10
maral*CLI> core set verbose 10
Verbosity was 3 and is now 10
maral*CLI> core show channeltypes
Type Description Devicestate Indications Transfer
Console OSS Console Channel Driver no yes no
Phone Standard Linux Telephony API Driver no yes no
Local Local Proxy Channel Driver yes yes no
SIP Session Initiation Protocol (SIP) yes yes yes
DAHDI DAHDI Telephony Driver w/PRI & SS7 yes yes no
Jingle Jingle Channel Driver no yes no
Gtalk Gtalk Channel Driver no yes no
MulticastR Multicast RTP Paging Channel Driver no no no
Bridge Bridge Interaction Channel no no no
Agent Call Agent Proxy Channel yes yes no
10 channel drivers registered.
