DAHDI неполадки
Flash709
Re: DAHDI неполадки
Сообщение Flash709 »
что имеем
# lsmod | grep dahdi
dahdi                 228088  2 oct612x,wct4xxp
crc_ccitt              12707  1 dahdi
# uname -a
Linux freepbx.sangoma.local 3.10.0-957.10.1.el7.x86_64 #1 SMP Mon Mar 18 15:06:45 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
# yum list installed | grep dahdi
asterisk16-dahdi.x86_64                16.3.0-1.sng7              @anaconda/1810
dahdi-firmware.noarch                  3.0.0-1.sng7               @anaconda/1810
dahdi-linux.x86_64                     2.11.1-50.sng7             @anaconda/1810
dahdi-tools.x86_64                     2.11.1-2.sng7              @anaconda/1810
kmod-dahdi-linux.x86_64                2.11.1-52.sng7             @anaconda/1810
# dahdi_span_assignments list
1:1:1    []             @Board_ID_Switch_0 /sys/devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0
2:2:32   []             @Board_ID_Switch_0 /sys/devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0
3:3:63   []             @Board_ID_Switch_0 /sys/devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0
4:4:94   []             @Board_ID_Switch_0 /sys/devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0
#dmesg
[   60.519388] dahdi: loading out-of-tree module taints kernel.
[   60.520958] dahdi: module verification failed: signature and/or required key missing - tainting kernel
[   60.523628] dahdi: Version: 2.11.1
[   60.523941] dahdi: Telephony Interface Registered on major 196
[   60.539313] wct4xxp 0000:07:00.0: Firmware Version: c01a016a
[   60.539922] wct4xxp 0000:07:00.0: FALC Framer Version: 2.1 or earlier
[   60.540087] wct4xxp 0000:07:00.0: Found a Wildcard: Wildcard TE410P (3rd Gen)
[   60.575179] VPM450: echo cancellation for 128 channels
[   60.644178] wct4xxp 0000:07:00.0: Not prepped yet!
[   60.772162] wct4xxp 0000:07:00.0: Not prepped yet!
[   61.348153] wct4xxp 0000:07:00.0: Not prepped yet!
[   61.468143] wct4xxp 0000:07:00.0: Not prepped yet!
[   61.516148] wct4xxp 0000:07:00.0: Not prepped yet!
[   61.604153] wct4xxp 0000:07:00.0: Not prepped yet!
[   61.900147] wct4xxp 0000:07:00.0: Not prepped yet!
[   61.988156] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.244148] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.332156] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.436147] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.572156] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.612146] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.708150] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.780145] wct4xxp 0000:07:00.0: Not prepped yet!
[   62.868148] wct4xxp 0000:07:00.0: Not prepped yet!
[   63.052146] wct4xxp 0000:07:00.0: Not prepped yet!
[   63.148152] wct4xxp 0000:07:00.0: Not prepped yet!
[   63.180146] wct4xxp 0000:07:00.0: Not prepped yet!
[   63.276149] wct4xxp 0000:07:00.0: Not prepped yet!
[   63.308145] wct4xxp 0000:07:00.0: Not prepped yet!
[   63.412151] wct4xxp 0000:07:00.0: Not prepped yet!
[   63.532184] wct4xxp 0000:07:00.0: Not prepped yet!
[   64.009027] wct4xxp 0000:07:00.0: VPM450: hardware DTMF disabled.
[   64.009037] wct4xxp 0000:07:00.0: VPM450: Present and operational servicing 4 span(s)
#cat /var/log/messages
Aug 28 13:58:55 freepbx fwconsole: Starting DAHDi for Digium Cards
Aug 28 13:58:55 freepbx systemd: Starting LSB: DAHDI kernel modules...
Aug 28 13:58:55 freepbx dahdi: Loading DAHDI hardware modules:
Aug 28 13:58:55 freepbx kernel: dahdi: loading out-of-tree module taints kernel.
Aug 28 13:58:55 freepbx kernel: dahdi: module verification failed: signature and/or required key missing - tainting kernel
Aug 28 13:58:55 freepbx kernel: dahdi: Version: 2.11.1
Aug 28 13:58:55 freepbx kernel: dahdi: Telephony Interface Registered on major 196
Aug 28 13:58:55 freepbx kernel: wct4xxp 0000:07:00.0: Firmware Version: c01a016a
Aug 28 13:58:55 freepbx kernel: wct4xxp 0000:07:00.0: FALC Framer Version: 2.1 or earlier
Aug 28 13:58:55 freepbx kernel: wct4xxp 0000:07:00.0: Found a Wildcard: Wildcard TE410P (3rd Gen)
Aug 28 13:58:56 freepbx kernel: VPM450: echo cancellation for 128 channels
Aug 28 13:58:56 freepbx kernel: wct4xxp 0000:07:00.0: Not prepped yet!
Aug 28 13:58:57 freepbx kernel: wct4xxp 0000:07:00.0: Not prepped yet!
Aug 28 13:58:58 freepbx kernel: wct4xxp 0000:07:00.0: Not prepped yet!
Aug 28 13:58:58 freepbx systemd: Stopped LSB: DAHDI kernel modules.
Aug 28 13:58:58 freepbx fwconsole: DAHDi Failed: The command "/etc/init.d/dahdi start" failed.
Aug 28 13:58:58 freepbx fwconsole: Exit Code: 1(General error)
Aug 28 13:58:58 freepbx fwconsole: Working directory: /
Aug 28 13:58:58 freepbx fwconsole: Output:
Aug 28 13:58:58 freepbx fwconsole: ================
Aug 28 13:58:58 freepbx fwconsole: Starting dahdi (via systemctl):  [FAILED]
Aug 28 13:58:58 freepbx fwconsole: Error Output:
Aug 28 13:58:58 freepbx fwconsole: Job for dahdi.service canceled.
Aug 28 13:58:59 freepbx fwconsole: Running Asterisk pre from Firewall module
Aug 28 13:58:59 freepbx systemd: Starting Fail2Ban Service...
Aug 28 13:58:59 freepbx kernel: wct4xxp 0000:07:00.0: VPM450: hardware DTMF disabled.
Aug 28 13:58:59 freepbx kernel: wct4xxp 0000:07:00.0: VPM450: Present and operational servicing 4 span(s)
Aug 28 13:58:59 freepbx dahdi: wct4xxp:
Aug 28 13:58:59 freepbx 'dahdi_handle_device'[4930]: add: /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0
Aug 28 13:58:59 freepbx 'dahdi_handle_device'[4933]: auto_assign_spans=1. Skip /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0
Aug 28 13:58:59 freepbx 'dahdi_span_config'[4967]: add: /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-1
Aug 28 13:58:59 freepbx 'dahdi_span_config'[4969]: add: /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-4
Aug 28 13:58:59 freepbx 'dahdi_span_config'[4965]: add: /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-3
Aug 28 13:58:59 freepbx 'dahdi_span_config'[4977]: auto_assign_spans=1. Skip /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-4
Aug 28 13:58:59 freepbx 'dahdi_span_config'[4978]: auto_assign_spans=1. Skip /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-3
Aug 28 13:58:59 freepbx 'dahdi_span_config'[4979]: auto_assign_spans=1. Skip /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-1
Aug 28 13:58:59 freepbx 'dahdi_span_config'[4988]: add: /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-2
Aug 28 13:58:59 freepbx 'dahdi_span_config'[5017]: auto_assign_spans=1. Skip /devices/pci0000:00/0000:00:1e.0/0000:07:00.0/pci:0000:07:00.0/span-2
Re: DAHDI неполадки
Linux freepbx.sangoma.local работает с цифроподписанными программными фалами - драйверами, библиотеками, и пр. При загрузке драйверов ядра - прямо говорит
Поэтому исследовать поведение проприетарной ОС с цифроподписанными и неподписанными модулями не имеет смысла.
Ставьте простую ОС - Debian, Ubuntu, CentOS, Fedora-server, и на ней экспериментируйте. Там даже на родных драйверах всё взлетит скорее всего. Типа
apt install dahdi* -y
dnf install dahdi* -y
Flash709
Re: DAHDI неполадки
Я то это понимаю, драва я не менял, всё из коробки. Не смотря на эту ошибку модуль есть и запускается. Вопрос в том что не работает :)
Чистая CentOS, поведение равнозначное. ставим, конфигурим, запускаем, зависаем.
Как же я люблю опенсорс :))
sasa
Re: DAHDI неполадки
Сообщение sasa »
чистая и старая центос со старым ядром и старыми dahdi драйверами
для начала все обновить
а потом разбираться
Re: DAHDI неполадки
Flash709 писал(а): Не смотря на эту ошибку модуль есть и запускается. Вопрос в том что не работает :)
Уточним: запускается и виснет (зависает), верно?
Или запускается и не работает? Это разные вещи.
Re: DAHDI неполадки
Flash709 писал(а):Чистая CentOS, поведение равнозначное. ставим, конфигурим, запускаем, зависаем.
Чистая CentOS не будет говоить
Flash709
Re: DAHDI неполадки
Чистая CentOS не будет говорить
Лога с чистой я не показывал, это то что из "коробки" samgoma os, без каких либо доработок. Тупо поставлена, запущена и разу такая ошибка.
Именно зависает. Но сейчас я добился того что он тупо ребутится сразу после загрузки.
Если бы не работала, я бы ковырял настройки и читал папирусы и не мучил бы вас на форуме :)
а потом разбираться
Этот вариант я тоже пробовал, но совсем древний центос не ставил. первым брал тот что с офф сайта 7 версия 1810 сборка, потом брал версию что валялась в дистрах на компе 1611. Пробовал с обновами и без. Эффект везде одинаков, service dahdi start и всё, привет.
В общем склоняюсь к древнему серверу HP и возможной аппаратной несовместимости, но воткнуть в другое место не могу, так как плата PCI 3.3 а у меня везде PCI 5 и выше :(
Ну не может быть что бы на разных системах, на разных дравах и настройках эффект был одинаков.
Re: DAHDI неполадки
Может проще плату сдать продавцу если еще 2 недели не прошло и взять шлюз наш взамен?
TDA200 подключаем "из коробки" и не нужно изголяться)
Так причины могут быть разные - например конфликт по pci (плата то древняя) или же еще что..
Ferrum
Re: DAHDI неполадки
Сообщение Ferrum »
Попробуйте на другом железе, с другой ОС, к примеру Debian, прежде чем плату сдавать.
Re: DAHDI неполадки
Если есть возможность сдать и купить дешевле и без гимора - зачем? :)
С учетом того что большинство сейчас новые астеры на виртуалках поднимает
