a400p freebsd
Sfinx
Re: a400p freebsd
Сообщение Sfinx »
shadow_mag писал(а):А где гарантии?
Там же где и пиво ;)
Rus
SfinxSoft
http://sfinxsoft.com
shadow_mag
Re: a400p freebsd
Сообщение shadow_mag »
Ну воткнул я эту плату в CentOs
dahdi_scan
[1]
active=yes
alarms=OK
description=Wildcard TDM400P REV E/F Board 5
name=WCTDM/4
manufacturer=Digium
devicetype=Wildcard TDM400P REV E/F
location=PCI Bus 01 Slot 01
basechan=1
totchans=4
irq=0
type=analog
port=1,none
port=2,FXO
port=3,FXS FAILED
port=4,none
почему 3-й порт failed?
shadow_mag
Re: a400p freebsd
dahdi_cfg -vv
DAHDI Tools Version - 2.6.2
DAHDI Version: 2.6.2
Echo Canceller(s): HWEC
Configuration
Channel map:
Channel 02: FXO Kewlstart (Default) (Echo Canceler: none) (Slaves: 02)
Channel 03: FXS Loopstart (Default) (Echo Canceler: none) (Slaves: 03)
2 channels to configure.
Changing signalling on channel 2 from FXS Kewlstart to FXO Kewlstart
DAHDI_CHANCONFIG failed on channel 2: Invalid argument (22)
Selected signaling not supported
Possible causes:
FXO signaling is being used on a FXO interface (use a FXS signaling variant)
RBS signaling is being used on a E1 CCS span
Signaling is being assigned to channel 16 of an E1 CAS span
shadow_mag
Re: a400p freebsd
system.conf
fxoks=1
fxsks=2
echocanceller=mg2,2
# channel 3, WCTDM/4/2, no module.
# channel 4, WCTDM/4/3, no module.
# Global data
loadzone = us
defaultzone = us
shadow_mag
Re: a400p freebsd
# Digium TE205P/TE207P/TE210P/TE212P: PCI dual-port T1/E1/J1
# Digium TE405P/TE407P/TE410P/TE412P: PCI quad-port T1/E1/J1
# Digium TE220: PCI-Express dual-port T1/E1/J1
# Digium TE420: PCI-Express quad-port T1/E1/J1
#wct4xxp
# Digium TE120P: PCI single-port T1/E1/J1
# Digium TE121: PCI-Express single-port T1/E1/J1
# Digium TE122: PCI single-port T1/E1/J1
#wcte12xp
# Digium T100P: PCI single-port T1
# Digium E100P: PCI single-port E1
#wct1xxp
# Digium TE110P: PCI single-port T1/E1/J1
#wcte11xp
# Digium TDM2400P/AEX2400: up to 24 analog ports
# Digium TDM800P/AEX800: up to 8 analog ports
# Digium TDM410P/AEX410: up to 4 analog ports
#wctdm24xxp
# X100P - Single port FXO interface
# X101P - Single port FXO interface
#wcfxo
# Digium TDM400P: up to 4 analog ports
wctdm
# Digium B410P: 4 NT/TE BRI ports
#wcb4xxp
# Digium TC400B: G729 / G723 Transcoding Engine
#wctc4xxp
# Xorcom Astribank Devices
#xpp_usb
Re: a400p freebsd
а нахуа вы ручками редактируете ?
service asterisk stop
service dahdi stop
dahdi_getconf modules
service dahdi start
dahdi_getconf
service dahdi restart
service asterisk start
идете в /etc/asterisk
редактируете chan_dahdi.conf дописывая нужную строчку в конец
shadow_mag
Re: a400p freebsd
Спасибо помогло, ну а на счет freebsd остается вопрос открытый.
Aven
Re: a400p freebsd
Сообщение Aven »
Платы модулей рекомендуется ставить начиная с первого слота и не забыть подключить кабель питания.
shadow_mag
Re: a400p freebsd
Ясно.
Еще вопрос.
Как настроить ее в системе.
FreePBX?
shadow_mag
Re: a400p freebsd
Ну это понятно.
Я имею ввиду прописать в транк и тд. Хотяб чтоб гудок в трубке был.
