Не собирается модуль chan_dongle
lone_wolf
Сообщение lone_wolf »
Всем привет, пытаюсь собрать модуль chan_dongle для использования с модемом huawei e1550
Делаю следующее:
cd /usr/src
wget https://github.com/jstasiak/asterisk-chan-dongle/archive/asterisk11.zip -O asterisk11.zip
unzip asterisk11.zip
cd asterisk-chan-dongle-asterisk11/
aclocal
получаю
configure.in:10: warning: AC_ARG_PROGRAM was called before AC_CANONICAL_TARGET
../../lib/autoconf/general.m4:1795: AC_CANONICAL_TARGET is expanded from...
../../lib/autoconf/general.m4:1819: AC_CANONICAL_SYSTEM is expanded from...
configure.in:10: the top level
autoconf
получаю
automake -a
получаю
configure.in:6: installing `./config.guess'
configure.in:6: installing `./config.sub'
configure.in:7: installing `./install-sh'
configure.in:7: installing `./missing'
automake: no `Makefile.am' found for any configure output
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: ./configure
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking target system type... (cached) x86_64-unknown-linux-gnu
checking host system type... (cached) x86_64-unknown-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... none
checking how to run the C preprocessor... gcc -E
checking for strip... strip
checking for rm... rm
checking for library containing iconv... none required
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking whether asterisk.h in ../include... no
checking whether asterisk.h in /usr/include... yes
checking asterisk.h usability... yes
checking asterisk.h presence... yes
checking for asterisk.h... yes
checking whether iconv.h in /usr/include... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking for iconv use const inbuf... no
checking for iconv_t in iconv.h... yes
checking for AST_CONTROL_SRCCHANGE in asterisk/frame.h... yes
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for size_t... yes
checking for ssize_t... yes
checking for uint64_t... yes
checking whether CC supports -fvisibility=hidden... yes
checking whether CC supports -fPIC... yes
checking whether CC supports -Wall... yes
checking whether CC supports -Wextra... yes
checking whether CC supports -MD -MT conftest.o -MF /dev/null -MP... yes
checking whether DESTDIR is /usr/lib/asterisk/modules... no
checking whether DESTDIR is /usr/local/lib/asterisk/modules... no
checking whether DESTDIR is /opt/local/lib/asterisk/modules... no
checking for working memcmp... yes
checking for memchr... yes
checking for memmove... yes
checking for memset... yes
checking for memmem... yes
checking for strcasecmp... yes
checking for strchr... yes
checking for strncasecmp... yes
checking for strtol... yes
checking for realpath... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
config.status: executing depfiles commands
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: make
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT app.o -MF .app.o.d -MP -o app.o -c app.c
app.c: В функции ‘app_status_exec’:
app.c:37: предупреждение: пропущен инициализатор
app.c:37: предупреждение: (где-то рядом с инициализацией для ‘args.resource’)
app.c: В функции ‘app_send_sms_exec’:
app.c:82: предупреждение: пропущен инициализатор
app.c:82: предупреждение: (где-то рядом с инициализацией для ‘args.device’)
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT at_command.o -MF .at_command.o.d -MP -o at_command.o -c at_command.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT at_parse.o -MF .at_parse.o.d -MP -o at_parse.o -c at_parse.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT at_queue.o -MF .at_queue.o.d -MP -o at_queue.o -c at_queue.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT at_read.o -MF .at_read.o.d -MP -o at_read.o -c at_read.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT at_response.o -MF .at_response.o.d -MP -o at_response.o -c at_response.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT chan_dongle.o -MF .chan_dongle.o.d -MP -o chan_dongle.o -c chan_dongle.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT channel.o -MF .channel.o.d -MP -o channel.o -c channel.c
channel.c:1437: предупреждение: несовместимый тип указателя в инициализации
channel.c:1438: предупреждение: несовместимый тип указателя в инициализации
channel.c:1447: предупреждение: несовместимый тип указателя в инициализации
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT char_conv.o -MF .char_conv.o.d -MP -o char_conv.o -c char_conv.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT cli.o -MF .cli.o.d -MP -o cli.o -c cli.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT helpers.o -MF .helpers.o.d -MP -o helpers.o -c helpers.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT manager.o -MF .manager.o.d -MP -o manager.o -c manager.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT memmem.o -MF .memmem.o.d -MP -o memmem.o -c memmem.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT ringbuffer.o -MF .ringbuffer.o.d -MP -o ringbuffer.o -c ringbuffer.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT cpvt.o -MF .cpvt.o.d -MP -o cpvt.o -c cpvt.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT dc_config.o -MF .dc_config.o.d -MP -o dc_config.o -c dc_config.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT pdu.o -MF .pdu.o.d -MP -o pdu.o -c pdu.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT mixbuffer.o -MF .mixbuffer.o.d -MP -o mixbuffer.o -c mixbuffer.c
gcc -g -O2 -O6 -I. -D_GNU_SOURCE -I/usr/include -I/usr/include -DASTERISK_VERSION_NUM=110000 -DHAVE_CONFIG_H -fvisibility=hidden -fPIC -Wall -Wextra -MD -MT pdiscovery.o -MF .pdiscovery.o.d -MP -o pdiscovery.o -c pdiscovery.c
gcc -shared -Xlinker -x -o chan_dongle.so app.o at_command.o at_parse.o at_queue.o at_read.o at_response.o chan_dongle.o channel.o char_conv.o cli.o helpers.o manager.o memmem.o ringbuffer.o cpvt.o dc_config.o pdu.o mixbuffer.o pdiscovery.o
PRIME_BBCODE_SPOILER_SHOW PRIME_BBCODE_SPOILER: make install
./config.status
config.status: config.h is unchanged
strip chan_dongle.so
/usr/bin/install -c -m 755 chan_dongle.so
/usr/bin/install: после «chan_dongle.so» пропущен операнд, задающий целевой файл
Попробуйте `/usr/bin/install --help' для получения более подробного описания.
make: *** [install] Ошибка 1
Re: Не собирается модуль chan_dongle
выполнить вместо make install
/usr/bin/install -c -m 755 chan_dongle.so /usr/lib/asterisk/modules
lone_wolf
эм кажись сработало, спасибо огромное
lone_wolf
сработь то сработало но это получается я только модуль подсунул астериску, ну конфиг ясно можно прямо скопировать тоже с /usr/src/asterisk-chan-dongle-asterisk11/etc/dongle.conf в /etc/asterisk/dongle.conf
но я думаю это есче не все, так как к примеру астериска не понимает команды
dongle show devices
lone_wolf
окей, почитаемс :)
panikovskij
Сообщение panikovskij »
Не будучи уверенным, что здесь не наказывают за ссылки на сторонние ресурсы, отправляю вам в личку линк на мануал с новгородского форума, по которому я успешно установил chan_dongle. И он после этого ещё и заработал. :)
