Странный нето перехват, нето перевод звонка
Alteron
Сообщение Alteron »
Ситуация: asterisk18-1.8.4.4, городская проводная линия. На входе SPA-3102.
Наблюдаю следующее:
***** Исходящий звонок с телефона 101
[Feb  6 10:56:19] VERBOSE[43519] pbx.c:     -- Executing [2383627@INT_PHONES_ZVEZDA_:1] Verbose("SIP/101-000000e3", "1, <- Outgoing call through line 2377443.  ") in new stack
[Feb  6 10:56:19] VERBOSE[43519] app_verbose.c:   <- Outgoing call through line 2377443.
[Feb  6 10:56:19] VERBOSE[43519] pbx.c:     -- Executing [2383627@INT_PHONES_ZVEZDA_:2] Dial("SIP/101-000000e3", "SIP/2377443/2383627,120,Tt") in new stack
[Feb  6 10:56:19] VERBOSE[43519] app_dial.c:     -- Called 2377443/2383627
[Feb  6 10:56:19] VERBOSE[43519] app_dial.c:     -- SIP/2377443-000000e4 is ringing
[Feb  6 10:56:19] VERBOSE[43519] app_dial.c:     -- SIP/2377443-000000e4 answered SIP/101-000000e3
***** Соединение установлено, люди говорят
***** Звонок с телефона 103
[Feb  6 10:57:05] VERBOSE[43519] pbx.c:     -- Executing [89125999914@INT_PHONES_ZVEZDA_:1] Verbose("SIP/103-000000e5", "1, <- Outgoing call through line 2377443.  ") in new stack
[Feb  6 10:57:05] VERBOSE[43519] app_verbose.c:   <- Outgoing call through line 2377443.
[Feb  6 10:57:05] VERBOSE[43519] pbx.c:     -- Executing [89125999914@INT_PHONES_ZVEZDA_:2] Dial("SIP/103-000000e5", "SIP/2377443/89125999914,120,Tt") in new stack
[Feb  6 10:57:05] VERBOSE[43519] app_dial.c:     -- Called 2377443/89125999914
[Feb  6 10:57:05] VERBOSE[43519] chan_sip.c:     -- Got SIP response 503 "Service Unavailable" back from 192.168.15.30:5061
[Feb  6 10:57:05] VERBOSE[43519] app_dial.c:     -- SIP/2377443-000000e6 is circuit-busy
[Feb  6 10:57:05] VERBOSE[43519] app_dial.c:   == Everyone is busy/congested at this time (1:0/1/0)
[Feb  6 10:57:05] VERBOSE[43519] pbx.c:     -- Executing [89125999914@INT_PHONES_ZVEZDA_:3] Hangup("SIP/103-000000e5", "") in new stack
[Feb  6 10:57:05] VERBOSE[43519] pbx.c:   == Spawn extension (INT_PHONES_ZVEZDA_, 89125999914, 3) exited non-zero on 'SIP/103-000000e5'
***** Отбой звонка по "канал занят"
***** Тут разговор 101-го абонента с номером 2383627 обрывается, SPA делает какбы входящий звонок, абонент 2383627 слышит КПВ и вызов пошёл на 103-го
[Feb  6 10:57:37] VERBOSE[43519] pbx.c:     -- Executing [2377443@EXT_LINES_ZVEZDA_:1] Verbose("SIP/2377443-000000e7", "1, -> Incoming call through line 2377443.  ") in new stack
[Feb  6 10:57:37] VERBOSE[43519] app_verbose.c:   -> Incoming call through line 2377443.
[Feb  6 10:57:37] VERBOSE[43519] pbx.c:     -- Executing [2377443@EXT_LINES_ZVEZDA_:2] Dial("SIP/2377443-000000e7", "SIP/103,120,Tt") in new stack
[Feb  6 10:57:37] VERBOSE[43519] app_dial.c:     -- Called 103
[Feb  6 10:57:37] VERBOSE[43519] app_dial.c:     -- SIP/103-000000e8 is ringing
[Feb  6 10:57:44] VERBOSE[43519] app_dial.c:     -- SIP/103-000000e8 answered SIP/2377443-000000e7
[Feb  6 10:57:49] VERBOSE[43519] pbx.c:   == Spawn extension (INT_PHONES_ZVEZDA_, 2383627, 2) exited non-zero on 'SIP/101-000000e3'
[Feb  6 10:58:21] VERBOSE[43519] pbx.c:   == Spawn extension (EXT_LINES_ZVEZDA_, 2377443, 2) exited non-zero on 'SIP/2377443-000000e7'
Т.е. ещё раз:
1. 101-й звонит (это доп труба на Gigaset C610IP) на номер 2383627 через FXO на SPA-3102
2. устанавливается соединение
3. 103-й (телефон в FXS на SPA-3102) набирает номер
4. получает отбой по занятости канала и ложит трубку
5. разговор 101-го с 2383627 обрывается
6. SPA-3102 делает какбы входящий звонок из города: 2383627 слышит в трубке КПВ, а 103-й получает вызов
7. 103-й поднимает трубу и разговаривает с абонентом
На SIP линиях от провайдера и сипнете такого не наблюдаю.
Что такое может быть?
Alteron
Re: Странный нето перехват, нето перевод звонка
Сообщение Alteron »
Вот sip.conf
[2377443]
secret=*****
context=EXT_LINES_ZVEZDA_
nat=no
canreinvite=no
dtmfmode=auto           ;
allow=ulaw
allow=g729
deny=0.0.0.0/0.0.0.0
permit=192.168.15.0/24
Alteron
Сообщение Alteron »
В другой конторе стоит SPA-8800, происходит примерно то же самое. Тоже глюки SPA?
